Old 12-07-2002, 10:53 PM   #1
Ghomer1
Member#: 8091
2007 335i
Monaco Blue Metallic
Default Help w/ stripped motor mount bolt.....
I just wanted to know if there was a socket that was made to get out stripped nuts? I accidentally (whoops) stripped the nut that mounts the engine to the subframe.....
I know there is a way to get this off. Any ideas?
Garret
Ghomer1 is offline   Reply With Quote
Old 12-07-2002, 10:56 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
yes there are speciality sockets...were you using a 12 point or a 6 point socket??
jeremy
Old 12-07-2002, 11:32 PM   #3
Ghomer1
Member#: 8091
2007 335i
pretty sure it was hex.
Garret
Old 12-07-2002, 11:39 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
see if you can pound on the 13mm socket or an SAE size that is JUST a hare smaller then the 14mm, which IIRC would be like 9/16"
jeremy
Old 12-07-2002, 11:42 PM   #5
Ghomer1
Member#: 8091
2007 335i
I'll have to give that a try, but if not, what are these specialty sockets called? anything? or should I just go ask someone at a hardware store.
Garret
Old 12-08-2002, 04:15 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Garret
ask for them at the hardware store....not sure what places you have locally but some places will stock them.
jeremy
Old 12-08-2002, 03:32 PM   #7
il96
Gone... But not forgotten
Member#: 13082
Dremel works
You'll cut it in less than 5 minutes.
il96 is offline   Reply With Quote
Old 12-08-2002, 03:36 PM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Originally posted by il96
Dremel works
that too
Old 12-08-2002, 03:56 PM   #9
Ghomer1
Member#: 8091
2007 335i
Yeah, I never thought about that......I wonder why?
Garret
Old 12-08-2002, 05:16 PM   #10
rhdude
Member#: 6637
2009 Acura MDX Sport
Dremel will take forever and its hard to get at, if you slip, bye bye power steering!
plus, you will have to replace the stud in the motor mount.
Go to sears, and buy a stripped nut remover.
rhdude is offline   Reply With Quote
Old 12-09-2002, 01:43 PM   #11
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
This sounds like what I did. On my drivers side I stripped the head of the bolt closest to the firewall. I took a cold chisel and cut a V into the head of the bolt and tapped her on around. I bought one of those kits(bolt/screw extractor from Sears) and there just wasn't enough working room in that area. Now if it had been on the passenger side I would have been fine.
Buster
Doh I miss read, didnt realize it was the nut on the motor mount you were speaking of.
EvasionOfTruth is offline   Reply With Quote
Old 12-09-2002, 07:00 PM   #12
Ghomer1
Member#: 8091
2007 335i
Yeah Buster...I remember the trouble you had. I have the same deal....and I haven't even done anything with the passenger side....
Brian, yeah I'm going to go get one of those...
Garret
Old 12-10-2002, 10:27 AM   #13
Shinji N
Member#: 3987
1999 Miata
I did the same damn thing
Shinji N is offline   Reply With Quote
Old 12-27-2002, 06:15 PM   #14
fliz
Member#: 30342
Garret -
I just stripped my passenger side motor mount nut installing my uppipe. How did you end up getting the nut off?
I've heard use 13mm, dremel, or sears nut-tool thingy. Which did you try, or did you come up with something better?
Thanks,
Chad
fliz is offline   Reply With Quote
Old 12-27-2002, 10:07 PM   #15
rhdude
Member#: 6637
Sears Bolt-out™ Stripped bolt/nut remover set #1
Set #2
I now swear by these things, $20 for 5 of them, and I got the "add on" set (set2 above) for $20.... available at any sears. You'll thank me later
~Brian
Old 12-28-2002, 02:04 PM   #16
washyu
Member#: 16424
2004 STI
Originally posted by fliz
Garret -
Thanks,
Chad
Yes, but it would take a very confident man to walk into a sears store and ask for a "nut-tool thingy."
Washyu
washyu is offline   Reply With Quote
Stripped engine mount bolt!! ScoobySnacker Newbies & FAQs 4 05-11-2007 11:05 AM
Need Help With Stripped Bolt Please! buyos1717 General Community 18 02-06-2006 05:09 PM
Motor Mount Bolt Location chewbakarox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-22-2005 02:47 AM
stripped engine mount bolt voam Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 08-18-2003 12:12 PM
Uhoh! Stripped seat mounting bolt, maybe hole too. Help! garface Interior & Exterior Modification 2 01-29-2002 02:27 PM
