Old 12-09-2002, 08:49 AM   #1
Ghomer1
Member#: 8091
2007 335i
Monaco Blue Metallic
Default Borlas supposed to sound Raspy?
I just installed my borla gen 4 and I was just wondering if they are supposed to sound anything like a lawnmower. You know kinda raspy.....the way it sounds if air is seeping by there?
I reused the stock gaskets on this, and I'm wondering if I have a leak somewhere. Sounds good otherwise, I'm just not happy with the raspy sound. What's the best way to check for a leak? Baby powder.
Garret
Ghomer1 is offline   Reply With Quote
Old 12-09-2002, 09:12 AM   #2
RaceCarRiot
Member#: 6542
1997 Ver IV
i reused my 9 year old gaskets on my car when i installed them this weekend, and i don't have any leaks...if i rev it at WOT at a standstill, i can hear a bit more metallic noise coming from the front of the car; the exhaust pulses are a lot 'sharper' sounding. check it again for leaks, but keep in mind that the factory piece is made of a thicker, heavier metal (steel or cast iron or whatever), and has additional shielding around which all helps to help soak up noise. also, have someone else mechanically inclined listen to it before you go to all the trouble to spot a leak...when you're used to all the little subtleties of your car, you hear little things that make you paranoid and turn out to be nothing.
RaceCarRiot is offline   Reply With Quote
Old 12-09-2002, 10:13 AM   #3
Ghomer1
Member#: 8091
2007 335i
You're probably right. It's not a huge deal, but it doesn't sound as "mean" as people say it does. I'm not sure if I like the raspiness of it...sounds kinda R ICE.
G
Old 12-09-2002, 11:03 AM   #4
RaceCarRiot
Member#: 6542
1997 Ver IV
yeah, when i first put them on, i was kind of offset by the metallic 'hissy-ness' from the front of the car when i leaned out the window to hear how it sounded when i revved it up and make sure nothing was leaking, but it only seems to be really noticeable when there's no load on the engine (i.e. revving it up in neutral). in normal driving, i don't hear it. we put a couple sets of gt-spec headers on a pair of WRX's that morning, and they noticed the same thing, even with all the brand new gaskets included in the kit; you hear a lot more metallic noise from the engine bay.
but yeah, revving it up doesn't sound exactly like you think it would...it sounds mean, but like a louder version your exhaust before the headers went on. it sounds much better under load.
Old 12-09-2002, 11:36 AM   #5
awdwagon
Member#: 6585
1997 acura integra
champion white
the different sound is just from the different metal of the headers, instead of the heavy cast from the factory manifold. the way i look for leaks is i jack the car up when its the motor is cold and get someone to start it and feel around where the flanges are, you'll feel the air pulsating out of the gaskets if theres a leak. i really doubt you have a leak, its just a different sound.
awdwagon is offline   Reply With Quote
Old 12-09-2002, 12:55 PM   #6
Ghomer1
Member#: 8091
2007 335i
Not sure if I really like it or not. It really does resemble the sound from a riding lawn mower. Not the mean image I want to put out there.
Garret
Old 12-09-2002, 03:45 PM   #7
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
when i put my borla header on..i went ahead and got new head gaskets..they were like 7 bucks each..and went to pepboys and got some copper sealant to put inbetween the gaskets and header....i like the way mine sounds, but mine doesnt sound like a lawn mower though.
AustinSTi is offline   Reply With Quote
Old 12-09-2002, 04:30 PM   #8
Bob O
Member#: 1502
2000 2.5RS & SV1kS
BRP
Ghomer, I have gen3's and am in Towson everyday. If you want to meet up to hear mine to compare, let me know. I don't hear anything that I would call "raspy". Mine are more "throby" or "throaty"
bob
Bob O is offline   Reply With Quote
Old 12-09-2002, 05:41 PM   #9
six6sicks
Member#: 28876
2000 Impreza 2.5 RS
Blue Ridge Pearl
I put my Bolra header and cat back on last weekend and notice the same sound. I think it was just an exhaust leak cuz when I put my new hi-flow cat. on yesterday I noticed the gasket was leaking pretty bad and since I was going to have everything apart I replaced every gasket. The sound went away and I don't think it sounds like a lwan mower nor does it sound like RICE. Sounds like it has more balls to me. I like it way more than stock or ricey.
six6sicks is offline   Reply With Quote
Old 12-09-2002, 06:57 PM   #10
Ghomer1
Member#: 8091
2007 335i
I'll have to buy some new gaskets then.......any one else...I am semi-seriously considering taking them off and selling.....
Garret
Bob-O...where in Towson are you? I'd love to meet up sometime..
Garret
Old 12-09-2002, 08:26 PM   #11
rhdude
Member#: 6637
2009 Acura MDX Sport
You finnaly picked up the headers from Brian?
Bob lives in Felton, near octagon spares( )
Use copper gasket material on the exhaust manifold side, thats what solved my problem...
~Brian
rhdude is offline   Reply With Quote
Old 12-09-2002, 08:29 PM   #12
Ghomer1
Member#: 8091
2007 335i
Yeah Brian, I drove my ass all the way down to Norfolk....3 hours minimum each way......
Where can I get these copper gaskets?
Garret
Old 12-10-2002, 01:18 AM   #13
spshultz
Member#: 1415
2005 OBS 3.0R
'12 SantaFe
I've had the Gen3's on for over 30,000 miles and the only time they sounded raspy was when I hit a big piece of wood in the middle of the highway and it put a hole in them. Other than that with the Stromung it has a very deep growl to it. 100% not RICE that's for sure.
spshultz is offline   Reply With Quote
Old 12-10-2002, 03:04 AM   #14
rhdude
Member#: 6637
Copper gasket material, comes in a tube, buy it at any auto store, poissbly a super walmart.... use that on both sides of the gaskets on the manifold side, not the cat side.
Old 12-10-2002, 08:48 AM   #15
Bob O
Member#: 1502
2000 2.5RS & SV1kS
BRP
Garret, I work at Black and Decker, 701 East Joppa Road.
Let me know when and where.
Bob
Old 12-10-2002, 10:25 AM   #16
Teamugi
Member#: 7771
I have SYMS headers and they are pretty raspy too when I open the car up. i guess it is part of the design of the subaru. What type of system are you running Ghomer after the cat? I am using a Greddy EVo and it is not the best sound, but it is livable. Might try an american muffler if all else fails.
Teamugi is offline   Reply With Quote
Old 12-10-2002, 11:01 AM   #17
Bob O
Member#: 1502
2000 2.5RS & SV1kS
BRP
A'pexi N1 Can and rallispec piping. Stock cat pipe. It's stupid loud.
Bob
Old 12-14-2002, 11:47 AM   #18
Ghomer1
Member#: 8091
2007 335i
I think I'm going to take them off and sell them. The sound is getting worse, and even with the thermo tec header wrap, i'm still getting the CEL.
Boo.
Old 12-14-2002, 01:36 PM   #19
rhdude
Member#: 6637
get a MIL eliminator...
take the headers off.. visually look for cracks, when they are still pretty warm(not hot) run warm water thru them to check for cracks...
Old 12-14-2002, 04:19 PM   #20
Slack
Member#: 17548
Did you even think about your cat-section heat shields? They could be rattling. Just a thought.
Mick
Slack is online now   Reply With Quote
Old 12-16-2002, 03:44 PM   #21
Ghomer1
Member#: 8091
2007 335i
It's definitely NOT a rattling. It's a leak of some sort. I just have to figure out if it is from a crack from Brians accident, or is it from bad gaskets.
Garret
Old 12-17-2002, 01:44 AM   #22
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
What muffler are you running? Yes, it does matter.
What is our turbo whistle supposed to sound like?? silence2-38554 Factory 2.0L Turbo Powertrain 22 08-05-2009 12:14 PM
is bov really suppose to sound like this? bthomas Newbies & FAQs 11 05-08-2006 04:30 PM
is the typhoon supposed to sound like this? mpower22 Factory 2.5L Turbo Powertrain 5 05-18-2005 10:37 PM
Is it supposed to make this sound? shippy1 Factory 2.0L Turbo Powertrain 55 10-28-2002 06:18 PM
so that's what it is supposed to sound like...;) Basshead North West Impreza Club Forum -- NWIC 3 03-02-2002 10:36 PM
Message Board Statistics All times are GMT -4. The time now is 08:19 AM.
