Old 12-09-2002, 11:32 AM   #1
garie
Member#: 26607
2002 wrx wagon
Unhappy greddy turbo gauge install wiring help??!!
Hi, i'm gonna install my turbo gauge morrow...and i've been reading over the instructions, and browsing through forums to find out where i should tap the wires to?
like where is the best place to tap into the
12V powersource line?
the ignition line?
the parking light line?
and the ground line to?
these are the descriptions of where the wires should connect to on the greddy instructions....im kinda confused by that...could anyone explain specifically wat i should do? and where would be best? any help would be very much appreciated!! thanks alot!!
garie is offline   Reply With Quote
Old 12-09-2002, 12:00 PM   #2
dachoe
Member#: 16469
where are you installing it?
dachoe is offline   Reply With Quote
Old 12-09-2002, 12:04 PM   #3
garie
Member#: 26607
2002 wrx wagon
the gauge? on the steer column.....where should i put the live unit? and tap into the wires? thanks!
Old 12-09-2002, 12:55 PM   #4
tundra
Member#: 9290
02 Built 2.5L wrx
I wouldn't tap any lines, the dealer probably won't like that very much. You can get all of your power from the fusebox located underneath your steering column. For the ground, I ran a wire through the firewall and connected it to the factory ground point above the battery. For a point of reference on which fuses to use, check out the gauge installations on www.projectwrx.com
As far as the control module, I mounted that on one of the posts that hold down the battery, just find the right sized nut (I can't remember what size it was off the top of my head) and bolt it down.
Good luck with the install, you shouldn't have any problems.
-Matt
tundra is offline   Reply With Quote
Old 12-09-2002, 03:57 PM   #5
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
I tapped off of the clock with both of my Greddy gauges. I don't remember the color of the wires off the top of my head but if you searched, you will find it. If i get enough time after work, I will pop the clock out and check the wires for you.
Need4Boost is offline   Reply With Quote
Old 12-09-2002, 08:31 PM   #6
garie
Member#: 26607
2002 wrx wagon
tundra-u say that i can get all my power from the fuse box rite? how bout the illumination wire? where should that go so the gauge lights up when the headlights are turned on at nite?
Need4Boost-haha thanks for the help. I hope you dont have to take out ur clock cuz i dont want to be a hassle....but thanks for the offer!! do u know wat i should search for to find wiring instructions? i tried searching for "boost gauge wiring", and "boost gauge install"....but didnt really find anything that specific or helpful...thanks!
Old 12-10-2002, 03:46 AM   #7
garie
Member#: 26607
2002 wrx wagon
does anyone know how to open up the clock housing?? thanks alot!
Old 12-10-2002, 09:49 AM   #8
Dexter
Member#: 5179
I had asked these questions some time ago. My post should answer which wire goes to which, if you decide to tap the clock. Just do a search on my user name. The installation is pretty easy, yet, I could not find away to have the gauge dim with the rest of the console.
Dexter is offline   Reply With Quote
Old 12-10-2002, 10:40 AM   #9
tundra
Member#: 9290
02 Built 2.5L wrx
If you want the light to dim with the console, you have to grab the illumination wire from the radio. There is actually an empty harness coming off the main harness to the radio. I believe the wire is purple...... but I haven't been back there for awhile so don't quote me on that
Old 12-10-2002, 10:04 PM   #10
03 Silver Bullet
Member#: 27222
2o1o Audi S4
Imola Yellow
You can tap it to your turbo timer...
At least then you are not hacking up your factory wires.
03 Silver Bullet is offline   Reply With Quote
Old 12-10-2002, 10:24 PM   #11
garie
Member#: 26607
2002 wrx wagon
hi everyone, i got it to work.but i didnt use the clock....i ran the ground, 12V and illumination line from the fuse box. that seemed to work pretty good...and i didnt have to take out the clock panel.
Old 12-10-2002, 10:40 PM   #12
dachoe
Member#: 16469
cool! i just got my boost and oil pressure in tonite. they both work very well... gotta wait for the EGT gauge.
Old 01-03-2003, 09:11 PM   #13
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
check out this link to quantum racings site .. it will show you in fusebox where to tap for 12v always on, 12v with lights, 12v with ignition .. easy stuff!! im in the middle of installing some defi gauges and came in to find this info - your thread came up in the search .. this was the answer i found to be best!! good luck ..
Quantum Racing Help - Fusebox Wire Tap Info
ronaldwrx is offline   Reply With Quote
Old 01-23-2003, 02:47 AM   #14
Black-X
Member#: 31702
2013 WRX
ok. i'm still not sure where to tap the ignition and parking line to. can someone clear this up for me PLEASE! i have my monster tach installed and wired to the fuse box, so the 12v and ground aren't a problem. i'll just tap into those wires. but the ignition and parking brake wire have me confused?!?! someone help please.
thanx in advance!
Black-X is offline   Reply With Quote
Old 01-23-2003, 01:01 PM   #15
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
if you look at the link i posted above to quantum racings site it tells which is 12v ignition .. #4 on fusebox. why does a turbo gauge need a parking brake signal? is it a turbo timer? the brake wire for that is mentioned in lots of posts - search for turbo timer install .. good luck
http://www.quantum-racing.com/Wire_Tap.htm
Old 01-23-2003, 02:59 PM   #16
Black-X
Member#: 31702
2013 WRX
that's actually the way i have my monster tach installed. i too don't know why the boost gauge needs the parking brake wire tap, but that's what it says in the instructions. hmmm... i just don't know. does anybody know if the Greddy boost gauge will work correctly without the parking brake tap?
thanx again in advance!
Omori boost gauge install wiring help twizzstyle Electrical & Lighting 11 04-05-2009 06:03 PM
2006 STi Greddy Turbo Timer Install w/ Factory Alarm– Help Please Knight_Fall Car Audio, Video & Security 2 12-21-2008 10:45 AM
greddy gauges - need wiring help hybrid gti 2 Electrical & Lighting 7 09-13-2005 05:27 AM
Greddy turbo gauge nightmare...HELP! nottheliving Southern California Impreza Club Forum -- SCIC 25 05-14-2004 04:33 PM
Greddy Turbo Timer install help 2k3WRX Newbies & FAQs 0 03-28-2003 11:31 AM
