Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2014
Old 12-09-2002, 04:29 PM   #1
dpjef
Member#: 18984
2002 Impreza 2.0
dark blue
Question SOHC and DOHC
What's the advantage of having a DOHC against a SOHC ?
I myself drive an Impreza 2.0 N/A which is SOHC, the WRX is DOHC.
Thanx
dpjef is offline   Reply With Quote
Old 12-09-2002, 07:57 PM   #2
SJwrx
Member#: 14970
1997 GF8
multi
SOHC (single over-head cam)
DOHC (dual '')
DOHC's usually produce more power due to you can adjust the cams functions easier and more prcisely.
Thats the jist (I think )
Rich
SJwrx is offline   Reply With Quote
Old 12-10-2002, 08:42 AM   #3
dpjef
Member#: 18984
2002 Impreza 2.0
dark blue
I was just wondering because I read somewhere on the forum that Subaru went from DOHC to SOHC on the RS in 1997, I think.
Old 12-10-2002, 11:25 AM   #4
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
DOHC can have more tuning potential, due to ease of adjustment. You can adjust cam timing individually, affecting overlap. SOHC can be just as tuned, but it requires new cams. There's really no inherent advantage of DOHC, but it does sometimes make things easier. One subaru specific issue, though, is that the DOHC valves have a wider splay angle wrt each other and therefore a higher pent combustion chamber. This is probably more optimal for combustion, but may have other issues. Otherwise the SOHC would probably have the same angle.
mrbell is offline   Reply With Quote
Old 12-10-2002, 11:34 AM   #5
rhdude
Member#: 6637
2009 Acura MDX Sport
the RS changed over in '99 with the phase 2 motor. A few '99s still had the phase 1 DOHC 4cam motor.
everything has pretty much been said, I'll add two things..
1. DOHC motors you have to pull the cams to remove the head, SOHC you don't have to...
2. DOHC cams are obviously more expensive. They are more of a pain to time as well.
~Brian
rhdude is offline   Reply With Quote
Old 12-10-2002, 12:20 PM   #6
dpjef
Member#: 18984
2002 Impreza 2.0
dark blue
Thumbs up
Thanks for the input, all.
EJ20 SOHC and DOHC HEADS FOR SALE!!!!!! herbine2001 Engine/Power/Exhaust 6 04-26-2010 11:15 PM
sohc and dohc heads midnight2.5rs-t Subaru Conversions 3 01-19-2008 04:26 PM
difference between sohc and dohc oil pan? bryan_johnson Normally Aspirated Powertrain 2 02-16-2005 02:34 PM
EJ25 SOHC to DOHC and back again? JoShYo Normally Aspirated Powertrain 16 11-14-2003 11:24 AM
Technical differences b/w SOHC and DOHC engines 2.5GT Normally Aspirated Powertrain 1 12-07-2001 11:25 AM
