Old 12-10-2002, 12:15 AM   #1
JasonRan
Member#: 163
1999 2.5 RS
Rally Blue
Default Hesitation and rough idle
My WRX has about 13K miles and is bone stock. It idles very rough...almost feels like it is "camming" like a big meaty V8 does. It also hesitates a lot on acceleration...in every gear at just about every RPM. It is definitely not tubro lag, but more of a surge and delay of power throughout the RPM band. Can anyone offer any suggestions on what may be causing this? I always run 93 octane gas as well.
JasonRan is offline   Reply With Quote
Old 12-10-2002, 12:43 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Sounds like you may have a vacuum leak someplace. Check all the hoses going to the intake, manifold and turbo to see if any are loose or have come off. If you can't find anything yourself let the dealer have a look, what you describe is not normal.
Old 12-10-2002, 02:43 AM   #3
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
Default That could be earthing related too
http://www.lumine.net/subaru/legacyb4/index.html
Check the link out and look under DIY for Earthing stuff - it'll show a JDM car, but it is all the same layout.
For a few bucks it can't hurt - unless you forget to take off the plus lead when working on it, of course
HTH
anotherB4 is offline   Reply With Quote
Old 12-10-2002, 11:06 AM   #4
mdot
Member#: 15884
2002 wrx wagon
I have similar acceleration hesitations. I thought it might be what the grounding mod fixes, (I have yet to do it), but now I'm not sure.
Why would it be a "vaccume" leak? It happens even under boost. If it is a leak, could it be from where I tapped in the boost guage? I tapped into the blow off valve on the fwd side of the intercooler.
mdot is offline   Reply With Quote
Old 12-10-2002, 01:25 PM   #5
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
What does your boost guage say at idle? -18 inches or so of vacumn? It should (roughly -10 psi)... if it doesn't, you have a vacumn leak.
DarthChicken is offline   Reply With Quote
Old 12-10-2002, 01:31 PM   #6
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
my wrx is sometimes the same as yours. when i am at idle, my boost gauge is around 19 in. but it wavers up and down sometimes(between 18.5 and 19.5). sometimes it is rock solid. anyone know what that means. of course when the cooling fans turn on, it jumps around a bit, but then levels off. i read the page talking about chakcing for vaccuum leaks, sticky valves, bad rings, etc. but it just said if the needle moves, well, how much movement is ok. also, my car is stock and no boost control, so i have reason to think my valves are sticky, leaking, or whatever. it has done this since 10K, now it has 25K and is the same.
Wheeler Bement is offline   Reply With Quote
Purge Control Valve and rough idle LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-30-2010 11:48 AM
Cruise Control Recall and rough idle kensington Mid West Subaru Owners Club Forum -- MWSOC 12 04-30-2004 11:42 PM
Hard starts and rough idle Brooke Legacy Forum 3 12-12-2003 08:00 PM
quick Q, poor milage and rough idle - Fuel filter? jeffg Normally Aspirated Powertrain 9 03-13-2003 01:29 PM
Sputtering and rough idle in the cold? EEK! GooseMan Normally Aspirated Powertrain 6 02-15-2002 12:50 PM
