Old 12-09-2002, 11:28 PM   #1
subyruss
Member#: 26161
04 vw gli
smoke grey
Default how to put on stromung exhaust?
I havent got it yet but very soon. Its a stromung dual tip stainless steel for my 99 rs. I was wondering if its easy to put on myself. I could use the lifts at my school since we have the best auto program in the state. the
subyruss is offline   Reply With Quote
Old 12-10-2002, 03:01 AM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
unbolt stock exhaust from Cat section, unbolt exhaust hangers. Drop exhaust. Put new exhaust up, attach hangers, use new mid pipe to cat gasket, and bolt up.
There, you are done
rhdude is offline   Reply With Quote
Old 12-10-2002, 11:08 AM   #3
subyruss
Member#: 26161
04 vw gli
smoke grey
sounds easy! thanks
Old 12-10-2002, 12:45 PM   #4
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
The hardest part about it is getting the bolts undone from the flange, as they are all cooked together. If you can, put some bolt loosener or WD-40 on them the night before, and they should come off a bit easier. The rest is cake. And if you are skinny like me (6'0", 160lbs) and still have your car sitting at stock height, you could even do this with out lifting the car. I just put a big piece of cardboard underneath the car to slide around on, and did it all like that. Same way I did my rear swaybar and diff cover.
HondaH8er is offline   Reply With Quote
Old 12-10-2002, 01:11 PM   #5
99OBSter
Member#: 14324
1999 OBS 4eat
Here's a trick I use when I don't want to jack the car: drive the back wheels onto phone books. Raises the car just enough to work under comfortably. Well, sorta.
99OBSter is offline   Reply With Quote
Old 12-10-2002, 02:11 PM   #6
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
You may also want to have a good propane touch handy to help un freeze the stuborn nuts and bolts. I needed to do that on my RS when I put my mid pipe in a couple of weeks ago with 63k on it. After applying a little heat they came right off and I didn't strip anything.
Z
Zephyr is offline   Reply With Quote
Old 12-10-2002, 02:25 PM   #7
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
i shall be doing this soon too...
can you use factory gaskets? if not, what do you need?
DanzBorin is offline   Reply With Quote
Old 12-12-2002, 12:08 PM   #8
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Do yourselves a favor and buy stainless steel bolts from a hardware store to replace yours. Just in case you ever have to replace(likely with the Stromung) or take off your exhaust for any reason. And get longer ones for the midpipe to cat bolts to make that spring easier to install.
garface is offline   Reply With Quote
Old 12-12-2002, 01:20 PM   #9
rhdude
Member#: 6637
good tip garface, I forgot to mention i got all new bolts.
Danz- you can use factory gaskets, just buy new ones...
Spray liquid wrench or PB blaster on all the bolts the night before the install, and about 30min before the install.
Old 12-12-2002, 05:11 PM   #10
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
Wait, so you can't use the stock gasket from the midpipe to the cat that's already there?
DrBoy01 is offline   Reply With Quote
Old 12-12-2002, 06:51 PM   #11
DanzBorin
Member#: 7131
2015 Outback - Croc
thanks, now to find the part #s...
anyone got them handy?
Old 12-12-2002, 08:27 PM   #12
dcoty
Member#: 3149
01 V7 GC/R32 sky
Just call your dealer and tell then u need a stock mid pipe/cat gasket and they will have them in stock at around 3$ or something like that. Good luck!
Dan
dcoty is offline   Reply With Quote
Old 12-12-2002, 09:25 PM   #13
garface
Member#: 1581
MY00 RS/STi7
$3??? HAH, try like $10. It's like $8 for the muffler to mid, and $12 for the mid to cat. At least at my dealership.
Old 12-12-2002, 09:36 PM   #14
dcoty
Member#: 3149
01 V7 GC/R32 sky
Oh, bad guess on my part, I put mine on 2 years ago so i forgot by now.
I bought a throttle body gasket for 3$ canadian today so i based it on that
Dan
Old 12-12-2002, 09:48 PM   #15
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
I'm still kinda unclear...
Can you use the stock mid-to-cat gasket, or is it necessary that I buy a new one?
Old 12-14-2002, 02:09 PM   #16
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
<cough> anyone?
Old 12-14-2002, 05:44 PM   #17
rhdude
Member#: 6637
get a new one, unless you want leaks.. same with the mid-exhaust gasket...
Old 12-14-2002, 06:43 PM   #18
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Guess it's time for a trip to the dealer
The exhaust-to-mid gasket might not be necessary, since I bought the whole stromung catback system.
Old 12-14-2002, 07:42 PM   #19
DanzBorin
Member#: 7131
2015 Outback - Croc
they most likely come apart, and who knows if you are supplied with a gasket...
Old 12-14-2002, 07:57 PM   #20
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
I'm pretty sure they supply a gasket for the muffler-to-mid section. I'm going to have to buy a new mid-to-cat gasket.
Old 12-14-2002, 08:00 PM   #21
garface
Member#: 1581
MY00 RS/STi7
When I bought just the muffler it came with a gasket. So a full catback definately should have one.
How to put on an Autocross??? GreenMarine South East Region Forum 13 03-28-2005 10:37 PM
How to put on fog light covers cwb124 General Community 1 12-24-2002 12:09 PM
How to put on '02 WRX side skirts on a 2.5RS SCOOBYDOOD Interior & Exterior Modification 5 08-21-2002 04:22 PM
How to put on a spoiler? rhdude Mid Atlantic Impreza Club -- MAIC 18 01-13-2002 11:23 PM
Anyone know how to put on a shift knob for the RS? STi - IMPREZA Newbies & FAQs 3 04-19-2001 11:00 PM
