Old 12-10-2002, 09:30 AM   #1
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Angry Engine is eating Oil and Coolant but not leaking...
The past week or so my car has been eating coolant and oil like nothing. I don't get any heat when I am at idle (car is already fully warmed up) Every week I have to add a lot of coolant and I have to add about a 1/4qrt of oil a week. BTW-I run Mobil 1 syn. My car doesn't even have 7k miles on it but I am using TXS STG4 package along with a few other mics things. I have been running the STG4 for only about 2k miles now. The car doesn't feel as "peppy" anymore.
I sometimes can smell the coolant but never the oil burning. I don't see any signs of coolant in my oil at all either. There are no leaks on the ground. Do I have a cracked block?
Last night driving to the bar I noticed some white smoke coming from my turbo area. I checked it right away and there was no smoke anymore. I didn't smell any burning of oil.
So I continue to the bar and as soon as I pulled in and shut the car off, here came the white smoke. It smelled of coolant. At this point I checked the coolant levels and they were VERY low. I popped open the hood and didn't see smoke coming from the turbo. There was nothing leaking either. I did notice that the turbo sounded a bit funny last night. I figured this was from low coolant and oil. My oil was also about a 1qrt and a half low this morning after checking the oil 1 week ago.
I know the turbo might be going but can someone explain where all the coolant and oil is going? I am really puzzled. Any help would be great.
Need4Boost is offline   Reply With Quote
Old 12-10-2002, 09:45 AM   #2
Karl
Member#: 13110
What does your exhaust gas look like?
Karl is offline   Reply With Quote
Old 12-10-2002, 09:51 AM   #3
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
It is white.
Old 12-10-2002, 09:58 AM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
Unhappy sounds like trouble..
I'd check all the lines to turbo first.
If you haven't said if you have excessive
amounts of water vapor coming from your exhaust.
or it could be foul pcv line/valve...just guessing..
check for oil in the vaccum lines.
it might have blown a seal.
the sound could be bearing failure or
if you have bearing one, excessive friction
from turbo shaft..in other words have the turbo checked.
funnier things have happened from clogged pcv valve..
never melted one of these..flat 4 turbo's.
my 2 cents
Ben
Old 12-10-2002, 10:03 AM   #5
Pat Green
Member#: 5818
2002 WRX, '72 510
V is for Victory, Hippie!
Something to do with the head, either cracked or the headgasket is gone. Hopefully the latter. Any emulision in the the oil?
Pat Green is offline   Reply With Quote
Old 12-10-2002, 10:04 AM   #6
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
I am thinking the samething.
I will redrain the oil after work and check.
Yes, I have noticed that there was been excessive smoke out of the exhaust.
Old 12-10-2002, 10:16 AM   #7
MisterX
Member#: 17275
2002 wrx wagon
wr blue
Get out the wrenches.
MisterX is offline   Reply With Quote
Old 12-10-2002, 10:23 AM   #8
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
I think for the first time I am not going to be doing the work myself. I am going to try and find the problem though.
If this requires any kind of engine internal work, I am bringing this to Rallispec.
I just do not have the time to rip the block apart.
Old 12-10-2002, 10:25 AM   #9
desiwrx02
Member#: 20168
02 wrx
black and blue all over
Make sure you eliminate all the causes, because even just a head gasket job can be damn costly.
Ajay
desiwrx02 is offline   Reply With Quote
Old 12-10-2002, 12:37 PM   #10
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Any other ideas?
Old 12-10-2002, 12:47 PM   #11
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
puffin white smoke?
head gasket
blown cylinder
blown turbo (??? this i think you would know )
i'd take it in and get it diagnosed...
dont recommend driving around on it and perhaps increasing/compounding the problem...
good luck to ya.
jamie
www.subiegalracing.com
SubieGal Rally Posters available now
www.allsubaru.com
Old 12-10-2002, 01:32 PM   #12
Quick WRX
Member#: 19689
2002 GDA TXS stg 4+
280 whp
Do you have a boost controler?
You may have over boosted, that would blow the head gasket, right.
Quick WRX is offline   Reply With Quote
Old 12-10-2002, 01:42 PM   #13
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Sorry to hear about your car! You'll get it sorted out I'm sure. FYI Dave at Rallispec broke his thumb Sat., so you might have a to wait alil bit until they can work on your car since there is only one guy left there to do work until Dave feels better.
PaulRex is offline   Reply With Quote
Old 12-10-2002, 01:47 PM   #14
WWRRXX
Member#: 22665
2002 SUBARU WRX
WHITE
Lightbulb
On my last DSM the turbo developed a coolant leak internally, which caused alot of coolant to be burned out the exhaust. And I also lost some oil to. With your wrx how does it idle, is it rough does it stall, usually thats what happens when you blow your head gasket the car doesnt just lose power it runs very ruff. I would check the turbo first.
WWRRXX is offline   Reply With Quote
Old 12-10-2002, 02:00 PM   #15
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Thanks for the heads up!
Do you know any other shops in the Tri-State area that do swaps or engine work?
Old 12-10-2002, 02:03 PM   #16
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
The car idles very smooth and there is no hesitation. There is also no CEL either.
I'm starting to think that it might not be the trubo since it does still have some pull, just not as much. I would rather buy a new turbo then rebuilt or take apart the engine.
The car does feel like it lost power. It just doesn't haul arse like it use to.
QuickWRX, yes I am using the TXS HPMBC.
My current boost is set at 1.2 bar
Old 12-10-2002, 04:04 PM   #17
ascott
Member#: 6545
Rally Blue Pearl
Any other ideas?
I don't know about your oil problem, but I had a radiator failure at 18K.
The seals at the spot where the plastic end tanks meet the aluminium core of the radiator failed, and were spraying coolant all over the engine compartment when the system was under pressure. Cold and just sitting, the car leaked nary a drop. I just noticed the mess from the dried anti-freeze all over a hose that was in the spray pattern.
Dealer replaced it under warranty, no questions asked. Haven't had a problem since.
ascott is offline   Reply With Quote
Old 12-10-2002, 04:09 PM   #18
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Just a question, do you run an oil catch can?
djerickd is offline   Reply With Quote
Old 12-10-2002, 05:05 PM   #19
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Nope. I was planning on getting a catch can but after running into this problem, that is going to be pushed back.
Old 12-10-2002, 05:07 PM   #20
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I was just wondering id you DID, that may be the problem, Austin had a problem with the way his was routed causing pressure problems causing oil flow problems ruining 2 of his turbos. So I guess you can rule that out...
Old 12-10-2002, 05:11 PM   #21
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
After talking to a few tuners, I am going to test the compression on each cylinder. If compression is good, I am going to check the head gasket and hope that is the cause.
If its a cracked block, looks like I am going to a stroker kit.
Anyone know who makes good head gaskets for the WRX? I am not looking into the factory one eiterh.
Old 12-10-2002, 09:22 PM   #22
DocDetroit
Member#: 24977
2003 WRX
Do you still have the stock turbo laying around? Maybe you could throw that on to rule out a turbocharger problem.
I'm curious to hear what the outcome is.
DocDetroit is offline   Reply With Quote
Old 12-10-2002, 09:43 PM   #23
Austin
Member#: 7089
2016 STi
My problem didn't ruin the turbos - in fact they probably would've been fine without taking them apart and cleaning them up, but I did it anyway as a precaution.
Also, even though all the burning, my car never ate much oil. It oil takes a small amount of oil burning in the turbine housing to make a whole lotta smoke.
Austin is offline   Reply With Quote
Old 12-10-2002, 11:50 PM   #24
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Nope. I sold the stock turbo a few weeks back.
Old 12-11-2002, 12:46 AM   #25
Pat Green
Member#: 5818
2002 WRX, '72 510
I'm still betting on a head/headgasket problem. Might have had a little detonation running at 1.2bar which upset things a little. The fact that you have white smoke leads me to believe that you definitely have coolant going through. I don't believe it is a turbo problem due to your losing both oil and water at the same time. Same diagnosis for a burned piston. However, god forbid, you also might have a cracked block around where the headgasket does it's sealing. It would have the same affect as a bad headgasket that's leaking where the oil and water galleries are closest.
Good luck!
engine is eating oil youngW03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 03-09-2009 03:05 PM
Leaking coolant but not consistently - please help! sd 05 sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 11-05-2008 07:20 PM
Nail in tire, but not leaking. Leave it be, or get it patched? Butt Dyno Tire & Wheel 5 10-22-2003 06:05 PM
Turbo missing oil and coolant feed lines? S-1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-04-2003 06:12 PM
JC Sports turbo kit is burning oil and IC is not working (its cold!) Andrew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-08-2001 10:55 PM
