Old 12-10-2002, 01:48 PM   #1
dhalley
Member#: 23726
2002 WRX Wagon
Default Wheel Spacers
Does anyone know of some wheels spacers for the rear for our cars?
Dave
dhalley is offline   Reply With Quote
Old 12-10-2002, 02:08 PM   #2
Austin
Member#: 7089
2016 STi
H&R makes a 5, 10, and 15mm wheel spacer kit for our 5x100 bolt pattern. Perfectly machined hubcentric pieces, complete with appropriately sized replacement wheel studs.
Austin is offline   Reply With Quote
Old 12-10-2002, 04:32 PM   #3
aspera
Member#: 7879
They also make a 25mm spacer. It is easier to install than the smaller spacers...if you have room in the wheelwell.
aspera is offline   Reply With Quote
Old 12-10-2002, 04:41 PM   #4
dhalley
Member#: 23726
2002 WRX Wagon
Sweet, would it matter if the rear had 10mm and the front had 5mm?
Dave
Old 12-10-2002, 06:04 PM   #5
Austin
Member#: 7089
2016 STi
Dave
I use 15mm spacers on the front and no spacers on the rear. Wider front track should give more front stability, also effectively increasing the rear sway bar rate.
Old 01-05-2003, 12:30 PM   #6
ecfitzgerald
Member#: 1472
2001 2.5RS
BRP
Who sells the H&R spacers? In particular the 5mm.
ecfitzgerald is offline   Reply With Quote
Old 01-05-2003, 12:39 PM   #7
Austin
Member#: 7089
2016 STi
I buy them through a local race prep shop... I would imagine if you went to H&R's website, it'd have a dealer locator you can use.
Old 01-05-2003, 01:12 PM   #8
ecfitzgerald
Member#: 1472
2001 2.5RS
BRP
Just tried that, but no dealer info.
Old 01-05-2003, 05:12 PM   #9
Austin
Member#: 7089
2016 STi
Well, if you can't find a local place to buy from, the race prep shop I got them from is in Bellevue, Washington.
http://www.fordahlmotorsports.com/
That's their website, and I'm sure they'd ship to you.
Old 01-05-2003, 06:42 PM   #10
aj's25rs
Member#: 30160
9900 2.5rs
rbp,srp
just make sure you torque them down. i have seen wheels come off from having spacers on some track/race cars. just be careful.
aj's25rs is offline   Reply With Quote
Old 01-05-2003, 06:55 PM   #11
chrislehr
Member#: 24165
2003 WRX Sedan
World Rally Blue
Wheel spacers put additional stress on CV joints/axles in most cars.. I would say you should just get the right offset wheels to start.
chrislehr is offline   Reply With Quote
Old 01-05-2003, 11:12 PM   #12
aspera
Member#: 7879
Default wide track
I just put 15mm H+R spacers on the front. I've been using 25mm units on the rear for quite a while. The 25mm ones are super-simple to install. The 15mm ones aren't as hard as I thought they'd be.
Getting the proper offset from the start is what I did. I ordered P1 wheels. They are made for Subarus. The problem with offset came when I installed DMS coilovers, which are also made to fit my Subaru. I also lowered the car using the coilovers (that's what they're there for).
Next thing you know old Jed's a millionaire and I have to install spacers or buy a THIRD set of wheels and tires. Should I just throw my old P1's in the dumpster?
Old 03-13-2003, 12:46 AM   #13
jetguy
Member#: 14284
2002 wrx sportwagon
midnight pearl metallic
i just want my rear tires to stick out as far as the fronts. on my wrx wagon it looks as though the rear wheels are tucked in farther than the fronts. plus tomarow I am installing avs es 100 yoko's on my wagon and kind of fear them rubbin on my prodrive springs.
any recomendations as to what size wheel spacers I should go with? 5, 10, 15, or 25mm?
how come the thinner wheel spacers are harder to install?
thanks jetguy
jetguy is offline   Reply With Quote
Old 03-13-2003, 01:13 AM   #14
Austin
Member#: 7089
2016 STi
Rear wheel spacers are a bit harder to install than front - the replacement wheel studs are a bit trickier, to be exact.
There is an ABS wheel speed sensor ring (rear tone wheel) bolted to the back of the rear hub - they're integrated. It needs to come off to be able to press/pound out and replace the rear wheel studs. To remove the rear tone wheel intact, you need to pull off the rear housing, which involves replacing the wheel bearing.
A ghetto way of doing it is to dremel the rear tone wheel in half (be sure not to nick any of the teeth - it's a fairly sensitive system), allowing you to remove the tone wheel in two halves without pulling the rear housing. Easier, but you can screw up your ABS system if you're not careful.
I'd recommend a 5mm spacer in the rear. You can combine H&R part numbers to get the 10mm longer replacement wheel studs with a 5mm spacer (that's what I did). The stock studs really aren't long enough to use even a 5mm spacer safely.
Old 03-13-2003, 10:17 AM   #15
ConeMasher
Member#: 2135
Austin, are you sure about the wheel studs for the 5mm? Or do you just mean you need even longer (10mm) studs for the rear?
I'm looking at the parts listing for H&R, and the WRX application in 5mm thickness is the DRS series (P/N 1025560). The documentation states "This spacer is fitted between the wheel and hub, exchanging the existing wheel studs for longer ones. The wheels are then fitted to the hub/spacer with the existing wheel nuts." This is opposed to the DR series, which requires longer wheel bolts purchased seperately.
I must admit, my concern is primarily for the front, but I'd be curious about the back too.
-- Gary
ConeMasher is offline   Reply With Quote
Old 03-13-2003, 10:55 AM   #16
Austin
Member#: 7089
2016 STi
Impreza/Legacy
Bolt Pattern 5/100
Center Bore 56
Bolt/Stud Stud
Thread Type 12x1.25
Spacer Type Spacer Width Notes Part Number Sug. Retail
DRS 5mm 12 1025560 68.95 pr
DRS 15mm 12 3025560 119.95 pr
10xdrs bolzen 12255134
That is all the info and p/n's I have for H&R spacers...
Conemasher - I'm unsure exactly what you're asking me.
I am sure that I would not use any spacer on either the front or rear without longer wheel studs.
You could fit a 5mm spacer in the rear with 5mm longer studs installed, but there was a chance I'd go with 10mm spacers, so I installed the 10mm longer bolts at the start.
Old 03-13-2003, 11:35 AM   #17
ConeMasher
Member#: 2135
Sorry if I wasn't clear...
I was just trying to confirm if the DRS spacer set for the WRX (5mm) does in fact come with longer studs, as per their claims.
If yes, I take it that you're then recommending that one wishes to use the 5mm spacer on the REAR of the WRX, one should toss those studs paired w/ the 5mm kit, and buy the studs specified for the 10mm kit. (But for the front, the included studs are fine).
And one final q for Austin.. those 10mm studs on the 5mm spacers... were you using the stock lugnuts? Would suck if the 5mm were too short, but the 10mm were too long and the stockers couldn't tighten down enough...(wouldn't have encountered this problem w/ "open" lugnuts).
-- Gary
Old 03-13-2003, 07:22 PM   #18
Austin
Member#: 7089
2016 STi
Yes, the DRS spacer kits come with two hubcentric spacers and 10 replacement wheel studs. (The 5mm spacers aren't hubcentric - they're too thin to be truly hubcentric.)
I measured the studs that came with my 15mm kit, and they're exactly 20mm longer than stock studs.
The 5mm spacer kit does come with longer studs (I would assume they're about 10mm longer than stock studs). Instead of buying a normal 5mm spacer kit and also buying another set of studs (from the 10mm kit), just call up Fordahl Motorsports (I posted their website above) and specify exactly what you want.
Old 03-13-2003, 07:31 PM   #19
Austin
Member#: 7089
2016 STi
I read back over this thread, and there were a few unanswered questions -
As far as H&R spacers go, there is really no difference in install difficulty between 5, 15, or 25mm kits. As I said, the rear wheel studs are a bit more involved to replace than the front studs, but once the studs are installed, the spacer itself is just an alloy disk that slides over the studs and butts up against the hub. The wheel then slides over the studs and is centered when you torque the lug nuts down.
Brand new wheel spacers are just like brand new wheels. You need to re-torque the lugnuts after about 50 miles of driving, and again every 100 miles until you no longer get any lugnut movement. Wheels and wheel spacers will compress (very slightly) when you torque them down for the first time - that causes torqued lugnuts to come loose, which is why you need to re-torque the lugnuts again and again, until the wheel or wheel spacer is done compressing.
Old 03-14-2003, 04:29 AM   #20
aspera
Member#: 7879
I'd have to disagree. The 25mm H&R spacers that I installed were much easier than the 15mm H&R spacers. This is because the 25mm spacers have room to use offest studs. The stock five studs hold the 25mm spacer. The additional five studs (offset mounted in the spacer) clamp the wheel. With the 25mm spacer you have ten studs per wheel well.
The 15mm spacers require pounding out the stock studs and installing longer H&R studs.
Old 03-14-2003, 09:33 AM   #21
Austin
Member#: 7089
2016 STi
Thanks aspera, I didn't know that.
That'd make the 25mm spacer a very easy install.
Old 03-17-2003, 06:29 PM   #22
aspera
Member#: 7879
Yep! They are super-duper easy. As far as I know, the 25mm ones can be used on the rear without bad side effects. The only odd thing that might get your attention is spraying mud on your doors if you are backing up in a field or something.
Old 04-04-2005, 11:45 PM   #23
localsdspec
Member#: 23369
GD impreza
does installing a 5,10, 15 or 25mm spacer change the offset of the rim that a subaru needs? if so how much would the offset be decreased with an addition of a spacer, such as the H&R one?
Or is offset and spacer length directly related to each other in millimeters?
so for example a a 17x9 +30 offset wheel with a 15mm spacer = +45 offset?
or am i totally wrong?
would this type of wheel setup totally throw the geometry off and be bad for the wheel bearings?
localsdspec is offline   Reply With Quote
Old 04-05-2005, 01:37 AM   #24
keyser_soze
Member#: 57445
Anyone knows who makes spacers 5 or 10 mm for 05 STi bolt pattern 5x114.3
keyser_soze is offline   Reply With Quote
Old 04-05-2005, 11:21 AM   #25
RogersWRX
Member#: 31617
2002 WRX Wagon
You can buy all the different H&R Wheel spacers here: http://www.optionimports.com/import-store/1025560.html
got the 5mm spacers - they do come with the longer studs, but are NOT hub centric.... Thinking about changing them out for the 10mm...
RogersWRX is offline   Reply With Quote
FS Socal: Geniune Subaru Wheel lock set, 8mm Wheel spacers. ComTekAuto Wheels/Tires 2 08-23-2007 06:38 PM
wheel spacer on 8" wheel cdogg240 Tire & Wheel 4 02-21-2007 05:46 PM
wheel spacers for work miester s2r wheels...?? 04aspenwrx Tire & Wheel 1 08-09-2006 06:53 PM
Ebay knockoff wheel spacer for my spare wheel? broom_dude Tire & Wheel 1 04-22-2005 03:44 AM
Mayday, Mayday! Wheel Spacers and longer wheel studs needed. Imprezer Bay Area Impreza Club Forum -- BAIC 6 06-22-2001 03:29 PM
