Old 12-10-2002, 03:30 PM   #1
ychan
Member#: 9418
2002 2.5rs
aspen white
Default MRT cat (meow!)
i know a lot of people have been having trouble with the MRT cat. what are some indications that there is something wrong with the cat? what's going on down there? thanks.
-y
ychan is offline   Reply With Quote
Old 12-11-2002, 04:12 AM   #2
slamck
Member#: 1436
'00 RS
'03 LLBean, '05 B4
Post
The cat that came with my MRT exhaust broke in less than six months. To be exact, its the honeycomb catalyst broke into pieces inside the cat converter. You'll hear the broken pieces rattle inside the cat if your cat is broken like mine. The broken pieces may eventually get blown into the downstream exhaust pipe and block the exhaust, then you'll feel power loss. In my case, I ordered a aftermarket universal cat and got it welded on by a shop around here.
hope this help.
slamck is offline   Reply With Quote
Old 12-11-2002, 10:55 AM   #3
ychan
Member#: 9418
2002 2.5rs
aspen white
how is MRT about replacing these? of course if you're having a problem with it, i'm sure you don't want them replacing it. will it make strange sounds?
-y
Old 12-11-2002, 01:21 PM   #4
kickin_81
Member#: 16679
2004 Forester XT
I have had the MRT system on my car since early July '02. I got the rattling a little after installation. It gradually goes away as the car warms up and stops rattling after 15 min. of driving. I checked the bolts, and they're pretty tight. Do you think that the cat was destroyed during shipment? First startup? Maybe the cat was welded the wrong way from MRT?
I don't have a sensative butt dyno, so I won't notice a slight power loss or if some chick slapped my butt. Is there anything we can do to check the cat besides using a hammer?
kickin_81 is offline   Reply With Quote
Old 12-11-2002, 02:18 PM   #5
slamck
Member#: 1436
'00 RS
'03 LLBean, '05 B4
One way to find out is to look inside the cat. I have a picture of my broken cat in this thread:
http://forums.nasioc.com/forums/show...hreadid=133533
Old 12-11-2002, 09:17 PM   #6
ychan
Member#: 9418
2002 2.5rs
aspen white
thanks for the pic.
no, i had some weird noises down there the other day, but it wa just the front o2 sensor. somehow it came out.
i just wanted to do some research on it, since it'll probably end up happening. so what did you guys do? replace it? with what? what's MRT like about it? thanks.
-y
Mother ****er tortures cat meowing on porch StopSweatinMe Off-Topic 51 11-12-2006 01:25 AM
Bad cat, meow? TheLegacy Tri-State Area Forum 8 06-20-2005 09:55 PM
i am going to gut my cat....meow creature546 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-03-2003 01:32 PM
measure this: MRT cat m750 Normally Aspirated Powertrain 4 08-20-2002 06:40 PM
mrt cat toast after 9 months froggert Normally Aspirated Powertrain 10 06-10-2002 12:27 PM
