Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 12-10-2002, 04:58 PM   #1
AWD WROX
Member#: 30284
2002 WRX Wagon
White blurrrr
Question HELP! Wastegate or BOV dumping above 10psi
I just had the equivalent (Up-pipe, Unichip, MRT turbo-back, VF30, STi injectors, etc) of a Vishnu Stage 2 installed and the Stage 2 map is loaded. Initially I saw 2 "overboost" CEL's so I'm keeping out of full boost until I see Shiv Thursday. But now whenever I go over 10 psi I hear a load dump from either the BOV or wastegate. I'm pretty sure it's the wastegate. I reset the ECU but it's still doing it. Anybody else experienced this? Any ideas?
Thanks, Steve
AWD WROX is offline   Reply With Quote
Old 12-10-2002, 06:07 PM   #2
hpracingwrx
Gone... But not forgotten
Member#: 16772
2003 R6
i miss my rex....
are u watching ur boost gauge when u hear the dump? does it shoot down or just go down slowly? does it go to vaccum or just to 0???
it sounds like somethign could be wrong with ur solenoid
but its just a guess
hpracingwrx is offline   Reply With Quote
Old 12-10-2002, 06:34 PM   #3
AWD WROX
Member#: 30284
2002 WRX Wagon
White blurrrr
I'll watch it next time I drive it (this evening) and see. I'm pretty sure it dropped immediately. With that much air it must be sudden. I checked the hose feeding the solenoid and it looks OK.
Thanks for the reply.
Old 12-10-2002, 06:52 PM   #4
GregUnd
Baaleted
Member#: 11800
Default Re: HELP! Wastegate or BOV dumping above 10psi
Thanks, Steve
Does the car feel like it's hitting a rev limiter or fuel cut? You may have a bad boost gauge or bad seal, you may be hitting a lot higher boost than you think. When you overboost the ECU hit's a fuel cut and the BOV releases pressure. The only other thing I would be able to think of it maybe you have a bad manifold pressure sensor.... since that's what the ECU depends on to tell it what kind of boost your putting.
GregUnd is offline   Reply With Quote
Old 12-10-2002, 07:22 PM   #5
AWD WROX
Member#: 30284
2002 WRX Wagon
White blurrrr
I've got a fairly new Omori boost guage and am pretty sure it's not bad - nor is its connection. I'm sure it's not overboosting as I feel it just beginning to build some boost when it happens whereas the CEL's were coming on at full boost.
This is disheartening as I only have 80 miles on the VF30
Old 12-10-2002, 09:29 PM   #6
GregUnd
Baaleted
Member#: 11800
Oh! I thought when you were hitting 10psi you were getting overboost CEL's.
Hm...
Old 12-10-2002, 09:37 PM   #7
AWD WROX
Member#: 30284
2002 WRX Wagon
White blurrrr
Default Solved!
Thanks for the feedback. The intercooler hose clamp came loose. So I re-installed it and unscrewed the MBC a half turn and all is well. No, all is very well (and faster than snot!).
Worn Wastegate or BOV? b5trooper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-07-2010 09:38 PM
FS: (Rochester, NY) Ultimate Racing HPC Coated External Wastegate Uppipe w/Dump Tube garboplateNY88 Engine/Power/Exhaust 8 11-01-2009 10:48 PM
WTB-- tial wastegate and bov or greddy type-s skate enjoi Private 'Wanted' Classifieds 4 08-28-2007 09:24 PM
wastegate flutter or bov flutter-help!?!? odin1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-08-2004 07:25 PM
