Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 12-10-2002, 10:12 PM   #1
chrisdeaner
Member#: 24625
Default How to make my light up switch less light up :)
I put a blue glow switch in to control my radar detector, however it is really bright. Can i put a resistor in line with the power to dim it a bit? Thanks!
-Chris
chrisdeaner is offline   Reply With Quote
Old 12-10-2002, 11:02 PM   #2
brunetmj
Member#: 8023
2004 2.5 RS
I'm not quite sure what that is but could you just paint the bulb a darker color?
brunetmj is offline   Reply With Quote
Old 12-10-2002, 11:34 PM   #3
chrisdeaner
Member#: 24625
I would, but it's a sealed component, and it's the plastic switch that is blue, not the bulb :/
-Chris
Old 12-10-2002, 11:36 PM   #4
scoobieREX
Member#: 25008
orginially
founded by Germans...
That's what duct tape is for
scoobieREX is offline   Reply With Quote
Old 12-11-2002, 01:24 AM   #5
Zypper
Member#: 5201
'02 WRX Wagon
'11 Versys 650
You probably have a high-output Blue LED camping out in your switch, wiring a resistor inline would probably do more harm than good. what you want is probably a frosted LED instead. Diffuse rather than harsh unfiltered light.
Zypper is offline   Reply With Quote
Old 12-11-2002, 01:27 AM   #6
chrisdeaner
Member#: 24625
No dice on the LED, it's a stupid iradescent (sp?) lamp under a blue plastic switch...pretty cheap IMO, but I want the look. So can i wire a resisitor for that?
-Chris
Old 12-11-2002, 03:08 AM   #7
danci1973
Member#: 19018
1995 Legacy Wagon
-Chris
Depending on how much current the lamp draws the resistor should be rated at appropriate wattage and might disipate heat, but generally, yeah, that's what you can do.
If you measure the voltage for the lamp and the current drawn by it, you can calculate the resistance. Then you decide what current you want to flow through the lamp (less current - less brightness) and calculate the appropriate resistor ratings.
D.
danci1973 is offline   Reply With Quote
Old 12-11-2002, 12:46 PM   #8
jeffg
Member#: 2958
2001 WRX (GC8)
Does the switch have a seperate power wire and ground for the light? If so, then you could probably wire in a resistor just fine.
On the other hand if the switch is just a two wire switch with current flowing through for the radar detector, then you would possibly drop the availible power for the detector and it would not work.
So I guess we need mroe details about how you wired the detector in.
J
jeffg is offline   Reply With Quote
Old 12-11-2002, 12:49 PM   #9
chrisdeaner
Member#: 24625
Oh, hmmm, good point, i am pretty sure it had one power wire that provided power for both the detector and the light inside. i could rewire it to so the ground is what flows to the detector and the +power is just for the light...
-Chris
Old 12-12-2002, 09:10 PM   #11
chrisdeaner
Member#: 24625
But wouldn't that one be just as bright?
How to make my WRX exhaust more "throaty" IceWind Newbies & FAQs 60 12-19-2005 12:11 AM
how to make my own air filter? MavWRX Service & Maintenance 7 11-03-2004 04:25 PM
How to make my 3" Flowmaster exhaust quieter fatray Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 01-11-2004 06:51 AM
how to make my Tein FLEX stiffer?? Bumble Bee 03 Brakes, Steering & Suspension 9 11-06-2003 07:39 PM
I need help i want to know how to make my subaru faster? impreza_power Technical Forum Archive 25 09-07-2000 10:07 AM
