Old 12-11-2002, 07:53 PM   #1
garie
Member#: 26607
2002 wrx wagon
Default samco i/c hose install. do i need to use hose clamps??
Hi, i just got my samco i/c hoses in the mail....and i noticed that they dont come with hose clamps. Do i need to get hose clamps? or will the hoses stay secure by themselves? thanks. any help would be great..cuz im going to the hardware tool morrow to pick up tools and stuff....so if i need hose clamps..pls tell me..thanks!!
garie is offline   Reply With Quote
Old 12-11-2002, 08:05 PM   #2
SQUAD_907
Totally Biased
Member#: 10104
WOW! JUST WOW!
I make posts disappear
just use the old clamps...
SQUAD_907 is offline   Reply With Quote
Old 12-11-2002, 08:51 PM   #3
inthememof911
Member#: 14055
2013 Mustang GT
-RIP bug eye-
Of a course you do.
Just like the other guy said, use the stock clamps.
inthememof911 is offline   Reply With Quote
Old 12-11-2002, 09:38 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes, re-use the existing clamps.
Some of the clamps are the spring-loaded type and are best removed/installed with a tool made for the purpose or alternately, pliers that can get around the tabs and compress them fully to release the clamp tension.
The toughest one to deal with is on the bypass (BOV) valve hose. It's easier if you unbolt the valve from the I/C, then remove the I/C from the car. Once it's out you'll have more room to get to the clamps on that hose.
Old 12-11-2002, 11:22 PM   #5
Akiata
Member#: 297
Well, I replaced all of the clamps. Cheap insurance. And now I have extra clamps if something goes wrong.
You should replace the bypass valve hose spring clamps with new ones you can screw on and off, it will make life easier.
p@
www.achtuning.com
Akiata is offline   Reply With Quote
Old 12-11-2002, 11:54 PM   #6
Gargantua
Member#: 15090
2002 WRX sedan
I personally am not a fan of the stock clamps. I like the traditional type with the screw and threads that run along side the clamp itself.
ditto to the bypass clamp. I am not as mechanically inclined as alot of you guys are and got frustrated taking that almost impossible upside down clamp off.
Pay a few bucks and get rid of those stock clamps.
Gargantua is offline   Reply With Quote
Old 12-12-2002, 08:40 AM   #7
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
The BOV return line spring-clamp is a real pain in the butt. Here's a tip from some previous NASIOC thread though which worked very well for me when I did the work:
- Douse spring-clamp area with WD40. While that's penetrating...
- Get a coat hanger and use needlenose pliers to create a hook/loop on one end (a tight one, not a big sweeping one). Try to make the hook in one or two bends so you don't weaken the metal too much
- Insert hook into spring-clamp tab (hard to see)
- Lean over the engine bay and pull straight up on the hanger. Do this until the spring-clamp tabs are up top where you can get to them instead of turned down into the engine.
- Fight with the clamp now that you can work with it, get hose off
- When you replace the BOV line finally, use a worm-screw hose clamp instead of that spring POS.
OR...
Leave the BOV return line stock! There's no reason at all to replace it really. Same with the throttle body connector hose. The main thing you care about is the Y hose.
jblaine is offline   Reply With Quote
Old 12-12-2002, 12:27 PM   #8
digitaltekniq
Member#: 18029
Hehe - that looks like my post after I did Vishnu IC hoses.
Agreed, the spring clamp is a complete PITA, but I didn't bother replacing mine, after my IC has been off like 6 times (don't ask) I think I've got the technique down. Now that I think about it a worm gear clamp might be nicer - not to mention more "consistent" with the rest of the clamps.
Cheers
Rich
digitaltekniq is offline   Reply With Quote
Do i need to use dino oil for turbo swap??? why??? Mike7 Newbies & FAQs 5 05-07-2009 09:08 AM
Do I need to use crossovers? 63Alpine Car Audio, Video & Security 3 01-08-2004 12:59 AM
Help! FAST! Do I need to use gasket sealer, when replaceing my head gaskets?! wighti Tri-State Area Forum 5 10-05-2003 10:19 PM
do I need to use a crossover? Alex L Car Audio, Video & Security 3 06-02-2002 12:56 AM
Do I need to use fuel pump? m750 Normally Aspirated Powertrain 2 05-11-2001 12:22 AM
