Old 12-11-2002, 10:16 PM   #1
SCCARacr
Member#: 27311
2003 WRX
Midnight Black Pearl
Lightbulb Road course tire pressures . . .
Any tire pressure recommendations for an '03 WRX that will run on 225-50-16s Goodyear GSCSs? I'm thinking 34 in front, 30 rear.
The only suspension mod is an Eibach pro-kit . . .
Opinions?
SCCARacr is offline   Reply With Quote
Old 12-11-2002, 10:32 PM   #2
HoRo1
Member#: 15618
I assume that the pressures listed by you are cold. You should measure your pressures hot, so as soon as you come into the pits after your first session check the pressures immediately.
I suspect that your hot pressures will be 6-7lbs higher than cold which translates to about 40 at the front and 36ish at the back. I have never used that type of tyre, but I think that you might experience understeer because your front tyres will have a smaller contact patch owing to the higher pressure. I usually run 40-41 hot fr/rr P Zeros (I have a lot of suspension mods). I feel that I'm still running 1 or 2 lbs too high so I will try 39-40 next time at the track.
HoRo1 is offline   Reply With Quote
Old 12-11-2002, 10:39 PM   #3
SCCARacr
Member#: 27311
2003 WRX
Yes, those are cold . . . will actually probably start at 32/30 and check temps when I come in . . .
Track Day Road Trip HARRIS HILL ROAD COURSE Andres van der Dys Texas Impreza Club Forum -- TXIC 27 12-13-2008 02:53 AM
Tire pressure and road trippin' westy66 Brakes, Steering & Suspension 4 04-01-2002 05:01 PM
tire pressure off road??? srosqvist Brakes, Steering & Suspension 4 11-11-2001 10:08 PM
WRX tire pressure on two mile road raceway? Cjchaps Motorsports 2 08-22-2001 07:08 PM
What tire pressures have you found good with the stock RE92 on Bay Area roads whomR Bay Area Impreza Club Forum -- BAIC 7 07-28-2001 07:16 PM
