Old 12-11-2002, 11:45 PM   #1
newbie sewbie
Member#: 10615
Default changing out rear diff fluid question
ok, it's bout time for me to change my tranny and rear diff fluid. my problem is, i have the rear factory diff protector. how have you guys changed the rear fluid w/that thing in place. i looked at it and it seems like if i undo the drain plug, it's going to pour onto the protector.
so what's your solution to this?
searching didn't help, hopefully someone on here can.
danx
newbie sewbie is offline   Reply With Quote
Old 12-12-2002, 09:32 AM   #2
bluesubie
Member#: 767
04 FXT
Lightbulb
I believe the diff protector can be removed pretty easily by taking out a few bolts.
Anybody know?
-Dennis
Old 12-12-2002, 02:03 PM   #3
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
Default Just get a big oil Pan....
Not sure about the Factory diff protector but I've got duff's and
It was easy to change the dif fluid out,
just put the biggest oil pan that murrays (autostore) has under it.
wait a long time,
flush dif w/ some extra diff fluid,
after refilling and tightening the plugs back up spray the whole area really well w/ simple green,
then hose off into pan
should be just fine and any oil left on the diff protector will be great for preventing rust....
nick
LyveWRX is offline   Reply With Quote
Old 12-12-2002, 03:32 PM   #4
newbie sewbie
Member#: 10615
hmm, i'm a little hesitant bout leaving that much fluid in the diff protector, wouldn't it splatter around once you're moving, and possiblly spill on your driveway?
i think i should craw under there again, iirc, there should be a drain hole in the diff protector(crossing my fingers and hoping they're there)
Old 12-12-2002, 04:16 PM   #5
rhdude
Member#: 6637
2009 Acura MDX Sport
If you wanted, you could drill 3-4, 3/6" holes in the very back, on the bottom of the diff protector... I have heard of a bunch of guys doing this, with no negative results.
rhdude is offline   Reply With Quote
trans and rear diff fluids questions (Amsoil) stixtasy12 Newbies & FAQs 6 05-30-2009 11:11 AM
rear diff fluid question TurboSteve Service & Maintenance 3 01-17-2005 08:37 PM
How to change trans/rear diff fluid wrxpeed Service & Maintenance 21 04-03-2004 05:13 PM
Changing the rear diff fluid RugDoc2003 Transmission (AT/MT) & Driveline 12 11-01-2002 02:29 PM
Tranny and rear-diff fluid change experience jlyttle Transmission (AT/MT) & Driveline 19 04-29-2002 04:57 PM
