Old 12-12-2002, 09:02 AM   #1
Blindeye_03
Member#: 4418
2016 Focus ST
Exclamation pcv valve
I dont know where this belongs, but here goes:
I did my own 30kmile service, and did everything I was supposed to do (change tranny fluid, rear diff fluid, flush the radiator, change the plugs...etc...). But I read somewhere you are supposed to swap out the pcv valve? Is it bad not to change this thing?
ps: I am at 43000miles now.
Someone help me out here
-justin
Blindeye_03 is offline   Reply With Quote
Old 12-12-2002, 09:17 AM   #2
kickin_81
Member#: 16679
2004 Forester XT
PCV Valve
Replacing the PCV valve at regular intervals can prevent rough idle, reduce oil consumption, and prevent air filter contamination. Suggested replacement interval is every 15,000 miles.
It's on www.subaruwrxparts.com "tune-up" section. Not expensive either. I've read somewhere that 50000 miles is ok. As long as it rattles when you shake it, then you're fine.
kickin_81 is offline   Reply With Quote
Old 12-12-2002, 10:28 AM   #3
grimlock
Member#: 2683
2011 STi 5-Door
Hey Justin,
Changed mine out once already. It's about $15 (maybe 11 or 12 from Lisa). Pretty easy to swap out. Just undo the hose clamp, unscrew it, put the new one in, and refit the hose clamp. Mine was still fine when I changed it at 30k.
Ross N.
grimlock is offline   Reply With Quote
Old 12-12-2002, 02:52 PM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Go autozone or other parts place, pay 6 bucks or something and spend 5 min putting it in.....it's cake
Legacy777 is offline   Reply With Quote
Old 12-12-2002, 05:28 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
If you dont know where it is look on the passenger side of the TB, 19 mm wrench will be needed to get it out, and remember dont over tighten it, it doest really 'bottom out' you will be able to crack the TB if tighten it too much.
Jay
Old 12-12-2002, 06:09 PM   #6
sidewayz
Member#: 5810
2001 S366 2.5RS
sidewayz is offline   Reply With Quote
Old 12-12-2002, 10:00 PM   #7
Blindeye_03
Member#: 4418
2016 Focus ST
Cool!
Thanks guys...I lost all my 'cool' links with my last winbloz reinstall .
I appreciate the link.
-justin
Have U seen my PCV valve ? Italiano New England Impreza Club Forum -- NESIC 2 01-23-2002 07:04 PM
PCV Valve Location Richard L. Newbies & FAQs 0 09-10-2001 04:46 PM
want to change PCV Valve and fuel filter, how and where are they, and steps? joostin420 General Forum Archive 6 12-13-2000 11:35 AM
PCV Valve Replacement Interval? Silver2000RS Technical Forum Archive 1 10-12-2000 09:26 AM
PCV Valve Replacement richeich SVX Forum Archive 2 06-26-2000 06:53 AM
