Old 12-12-2002, 12:27 PM   #1
wReXeRw
Member#: 19542
05 GSX-R 1000
02 WRX Gold
Default What are the benefits of a built engine with turbo?
Ive searched around for building up an engine like internals. But all I can find is all this math talk I dont understand. I just want to get back to the basics and ask the n00b question that ive been meaning to ask. With upgrading internals, like the pistons, connecting rods, cam shafts, what benefits should one expect from these upgrades with a car that has turbo? Thanks in advance.
-randall
wReXeRw is offline   Reply With Quote
Old 12-12-2002, 12:42 PM   #2
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
It can survive the a high hp level and the abuse.
Alex...
amelnikov is offline   Reply With Quote
Old 12-12-2002, 12:46 PM   #3
codean
Member#: 10186
The ability to run more boost and resist engine damage during tuning.
codean is offline   Reply With Quote
Old 12-12-2002, 01:11 PM   #4
tdxflex
Member#: 13634
can also rev a little higher safely
tdxflex is offline   Reply With Quote
Old 12-12-2002, 06:09 PM   #5
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
If you build it with a larger block (2.2 or 2.5) you will also see improved throttle response/low end for a given turbo.
Concillian is offline   Reply With Quote
Old 12-12-2002, 06:40 PM   #6
NYC TURBO
Member#: 25214
You would see absolutely no benefits at all if you are not increasing power. The only benefits for this would be that you can add more power to the car than the standard WRX engine can handle.
Lee
SQC #082
www.sqc-ny.com
NYC TURBO is offline   Reply With Quote
Old 12-12-2002, 07:36 PM   #7
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Default Re: What are the benefits of a built engine with turbo?
-randall
As everyone said above, it's all a matter of how far you are going to go. Push 400+hp may require some internal work, depending on your view of reliable. While the math may seen overwhelming, it really is pretty straighforward. Pictures would help a lot, as describing these equations with text is difficult to visualize.
Jeff
sponaugle is offline   Reply With Quote
Old 10-16-2006, 05:39 PM   #8
okaythen
Member#: 63397
so that's the benefits how about the disadvantages of an built engine? milage worse? noise? shaking? anything? I have 06 wrx and this guy is selling his built 06 engine cheap...since I plan to get bigger turbo later I am thinking about getting it but like how many hp can a built engine handle up to? what's the max rpm it can run? I got standalone ecu....I definitely have to upgrade tranny and clutches right? I can upgrade to STi tranny and clutch? how many whp can the sti tranny handle up to? and other parts I need to change/strenghten if I get a built engine and a big turbo? maybe HKS 3037 or bigger . thanks
okaythen is offline   Reply With Quote
Old 10-16-2006, 06:14 PM   #9
Ceyvme
Member#: 88211
06 Evo IX
Wicked White
Everything depends on how it was built and what parts were used along with who built it. As most people know a good builder/tuner cannot be replaced.
Tranny is a huge part of the WRX. If you treat it correctly you shouldnt have problems.
Ceyvme is offline   Reply With Quote
what are the benefits of water/meth injection Subarubaque Water/Methanol Injection, Nitrous & Intercooler Cooling 10 11-17-2006 12:57 PM
What are the benefits of racing shoes? volkl23 Motorsports 11 11-15-2005 01:39 PM
What are the benefits of endlinks? TML Brakes, Steering & Suspension 7 10-16-2003 05:29 PM
what are the benefits of an 18inch rim? BUDLoNG Brakes, Steering & Suspension 39 02-09-2003 02:44 AM
What are the benefits of inverted strut design? edkwon Brakes, Steering & Suspension 11 06-07-2002 01:05 PM
