Old 12-12-2002, 11:25 PM   #1
Austin
Member#: 7089
2016 STi
Default Blackstone Oil Sample Report
Attached is a copy of my most recent oil sample report from
Blackstone Labs.
An explanation of the report is here.
I used a total of 22 gallons of 107 leaded race gas during this oil's life. Included in the 3840 miles on this oil was one full day of severe road track use, and several competitive autocross events.
Is the amount of lead contained in this oil sample commensurate with the amount of leaded gasoline used?
Should I be concerned with the amount of molybdenum in the sample?
Thanks for your knowlege.
Austin is offline   Reply With Quote
Old 12-13-2002, 12:22 AM   #2
mlambert
Member#: 13831
Hrm...guessing the moly could be piston rings?
I wouldnt fret about the lead but I would if the next sample has the same amount in it and you didnt use any leaded race fuel.
Duno austin but that high moly could could mean that its time to think about....a....uhh....
rebuild
What all is moly in our engines?
mlambert is offline   Reply With Quote
Old 12-13-2002, 01:00 AM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
nothing is pure Molybdenum, but it is a VERY common alloying element in steels.
nhluhr is offline   Reply With Quote
Old 12-13-2002, 01:08 AM   #4
teiva-boy
Member#: 22825
Now that is some pretty trick info Austin.
Glad to see you using my FTP for some good. All I use it for is pr0n. Oh wait I didn't give you access to that did I?
teiva-boy is offline   Reply With Quote
Old 12-13-2002, 01:32 AM   #5
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Don't know about the lead, but RedLine oils have high levels of Moly in them. Moly is supposed to help prevent engine wear when the oil barrier breaks down.
Check with the guys on the forums at www.bobistheoilguy.com to be sure, though.
drees is offline   Reply With Quote
Old 12-13-2002, 01:57 AM   #6
Austin
Member#: 7089
2016 STi
Thanks, very much!
Old 12-13-2002, 04:48 AM   #7
Avedis
Member#: 8171
2005 WRX STi
Blue / Gold
Bob (the oil guy) works for Schaeffer's oil (or is at least a distributor for them), but if you've already taken a trip through the link, it becomes obvious before too long.
He is a pretty straight-up guy though. There was a link to a honda tech forum where he and a couple of other guys had about a 14-page discussion about oils. He was quite a bit less biased than I'd have thought he would have been... full of all sorts of knowledge and not afraid to share it.
--jeff
Avedis is offline   Reply With Quote
Old 12-13-2002, 08:04 PM   #8
Austin
Member#: 7089
2016 STi
drees - that's a pretty awesome forum! I've found the baseline numbers for virgin Redline 10w30:
Aluminum 1
Chromium 1
Iron 2
Copper 0
Lead 0
Tin 0
Moly 613
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 22
Boron 15
Silicon 15
Sodium 15
Calcium 2521
Magnesium 7
Phosphorus 1028
Zinc 1005
Barium 0
SUS vis @ 210F = 61.7
Flashpoint *F = 435
TBN = 13.5
And my reply from Blackstone RE: my lead levels -
The lead level is actually fine, as long as you're using leaded gas. It makes it harder to see bearing wear, because if you had a problem with the bearings it would normally show up as high lead. Leaded gas masks the true lead reading, but we don't suspect you have a bearing problem. The other metals common to bearing wear still looked fine.
Results of my Blackstone Oil Analysis eurospek Service & Maintenance 13 11-23-2012 12:30 AM
BlackStone oil report with M1 5W-30 (MY04STi) The_Prodigy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 10-01-2007 04:34 PM
2800 mile blackstone oil analysis 02_Forester Service & Maintenance 6 04-26-2005 10:41 AM
F-XT 30K Blackstone oil analysis Peaty Forester Forum 6 02-17-2005 06:43 PM
'04 STi (stock) engine oil analysis report at 7,323 miles. lstepnio Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 03-15-2004 12:59 AM
