Old 12-13-2002, 01:45 AM   #1
dave_the_driver
Member#: 13588
2002 WRX sedan
Default where is the clutch free play adjusted?
Could someone please tell us where the adjuster is for setting clutch free play on a WRX? Also, might as well say which way to turn it to increase the free play. Thanks in advance! Just saw here that Volume 1 of the service manual has that info and it's cheap. Will be ordering it to answer dumb questions like this.
dave_the_driver is offline   Reply With Quote
Old 12-13-2002, 03:19 AM   #2
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
All the adjustments in the clutch are at the pedal using athe lock nuts on the clutch master cylinder push rod. It's detailed in the clutch pedal play adjustment info which is in Volume 4 (Transmission Manual), pages CL-27 to CL-29. Basically you adjust for pedal stroke length of 130-135mm. There really is NO"free play" adjustment as this is a hydraulic clutch system.
Alan is offline   Reply With Quote
is the clutch adjustable?? new clutch help!!! JT's06sti Transmission (AT/MT) & Driveline 4 05-29-2009 10:13 PM
Where is the clutch slave cylinder on WRX 5 spds? poordna Transmission (AT/MT) & Driveline 10 04-17-2007 03:20 PM
Where is the other headlight adjustment screw? hklaine Legacy Forum 3 03-23-2004 11:13 PM
Where is the Shock Sensor Adjustment? billybob3 Car Audio, Video & Security 5 01-10-2004 12:21 AM
3" of clutch free play = very bad? jey Legacy Forum 4 10-26-2003 03:23 AM
