Old 12-13-2002, 09:59 AM   #1
jayfressh
Member#: 16847
2000 impreza rs 2.5
mach I maroon
Default Intake test!
I am getting a GTECH Pro competion for christmas and I would like to do a test on all the intakes out there for the RS 2.5, has this already been done? If so link the thread. I would like to test HP, temp., and air flow, if anyone from Ohio would like to helpp or maybe donate intake for test reasons drop me a line!
jayfressh is offline   Reply With Quote
Old 12-13-2002, 11:45 AM   #2
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Jay, talk to puck. I know he's done some testing with the OBD-II software, not sure of G-tech or dyno runs. Also, are you using a new one (with the LCD display) or the old-school gtech? The old one will only give you peak hp/torque numbers which don't tell you much. I'd rather have a big fat, flat, curve with a lower peak than a sharp, peaky curve with a higher peak.
Old 12-13-2002, 12:17 PM   #3
jayfressh
Member#: 16847
2000 impreza rs 2.5
mach I maroon
the new one with the lcd screen!
Old 12-13-2002, 12:39 PM   #4
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
better than nothing.
Old 12-13-2002, 01:23 PM   #5
jayfressh
Member#: 16847
2000 impreza rs 2.5
mach I maroon
No better than paying for a Dyno everytime you make a change!
Old 12-13-2002, 01:35 PM   #6
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
true.
Old 12-13-2002, 01:41 PM   #7
jayfressh
Member#: 16847
2000 impreza rs 2.5
mach I maroon
Talking booted
I've been kicked off LERSOC HAHAHAHAHA that sites a joke anyways, you and the other 3 or 4 guys are the only ones who post!
Old 12-13-2002, 01:58 PM   #8
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
no, you got booted cause you were acting like a tool.
Old 12-13-2002, 02:01 PM   #9
jayfressh
Member#: 16847
2000 impreza rs 2.5
mach I maroon
a tool? thats something people don't know how to use on LERSOC!
Old 12-13-2002, 02:23 PM   #10
rhdude
Member#: 6637
2009 Acura MDX Sport
yo, guys, this is a technical forum. keep it related to the thread subject or it's going to get deleted.
what is your plan for testing?
do you have a IR pyrometer to monitor engine temp to keep the tests fair? you need a constant outside temp, and humidity. ECU reset before each test, including the first. but even with all this, using a G-tech is not going to yield very accurate results.
rhdude is offline   Reply With Quote
Results of the cold air intake test Reciprocity Normally Aspirated Powertrain 31 04-06-2002 12:58 AM
The great "cold air" intake test Reciprocity Bay Area Impreza Club Forum -- BAIC 28 03-31-2002 04:21 PM
PE1820 spool up - Injen Intake is superior 15 extra hp! Intake test alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 54 01-01-2002 05:47 PM
My DIY intake tested in heavy rain... 8Complex Technical Forum Archive 6 07-21-2000 10:36 PM
Shiv,a question on intake test methods? Matt Monson Technical Forum Archive 6 06-26-2000 01:09 AM
