Old 12-13-2002, 09:34 AM   #1
9
Member#: 4074
1998 Impreza RS
RBP (one of the first!)
Default valve lash?
I was wondering if some could explain what valve lash is. I remember reading about haveing to reset valve lash when doing something to the heads. Thanks in advance.
Courtney
9 is offline   Reply With Quote
Old 12-13-2002, 10:40 AM   #2
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
basically its the amount of freeplay in the valve tappets. What head work are you doing (cams, port/polish, head gasket)? Unless you're installing cams, or removing them for a port and polish you shouldn't really need to adjust the lash (that is unless its out of spec... your car doesn't sound like a diesel does it?).
Old 12-13-2002, 10:46 AM   #3
rhdude
Member#: 6637
2009 Acura MDX Sport
rhdude is offline   Reply With Quote
DOHC valve lash BG5 Normally Aspirated Powertrain 2 07-25-2001 02:32 AM
How To: Setting Valve Lash on SOHC EJ25 stimpy Normally Aspirated Powertrain 3 06-06-2001 03:58 PM
Where did you people get your valve lash done? dcoty Normally Aspirated Powertrain 3 06-06-2001 12:45 AM
Suby dealers wont do my valve lash (cams) dcoty Normally Aspirated Powertrain 5 05-21-2001 08:50 PM
