Old 12-13-2002, 11:38 AM   #1
phillywrx
Member#: 19876
2014 Audi SQ5
Default Satellite radio antenna install
i read through a lot of the satellite radio posts, but can't seem to find if someone tried to locate the antenna in a more stealth position. i was wondering if someone found that it would work if you mounted it in the trunk or under the car or in the engine bay. i really don't want a shark fin antenna on my roof or some hideous antenna on my windows.
phillywrx is offline   Reply With Quote
Old 12-13-2002, 01:01 PM   #2
WWRRXX
Member#: 22665
2002 SUBARU WRX
WHITE
Smile
Ive seen them installed in the car by the 3rd brake light. seemed to work good.
WWRRXX is offline   Reply With Quote
Old 12-13-2002, 03:14 PM   #3
dust12
Member#: 13417
For best reception it should be mounted outside your car. I remember reading a post where someone mounted the antenna on their trunk lid behind the spoiler and that was pretty stealth and should get good reception. I also heard they were coming out with some different window antenna's that would be almost invisible.
dust12 is offline   Reply With Quote
Old 12-13-2002, 03:15 PM   #4
scoobdo
Member#: 21327
2005 WRX Wagon
i know of people who have it mounted on there dash and don't have a problem with reception.
scoobdo is offline   Reply With Quote
Old 12-13-2002, 03:15 PM   #5
phillywrx
Member#: 19876
2014 Audi SQ5
beauty. thanks guys. i'll research that invisible antenna idea.
Old 12-13-2002, 05:00 PM   #6
snoopydoo
Member#: 29817
Another thing to think about - radome (cover) is glass filled nylon. It has very similar EMF properties as glass filled polyster, aka "fiberglass". If you had a non-metallic car, such as black/white/yellow, you could embed the antenna in something like the rear wing (and attach on aluminum foil ground plane on the bottom side). You could also remove the radome and replace it with something less "XM-like", like a plastic box or other dome. The only requirements are that A. the radome not contain any metal or large amounts of carbon / carbon fiber, and B. a 2 sq ft metal conductive ground plane below it. Beyond that I believe you are free to re-package.
snoopydoo is offline   Reply With Quote
Old 12-13-2002, 09:40 PM   #7
doogdog
Member#: 29308
2005 Outback XT LTD
Champagne Gold Opal
I Have my XM antenna on my trunk lid about 2"-3" from the rear window. For the most part I have no problems with reception, however, you will drop off sometimes under bridges in low areas, and heavy tree cover. This doesn't happen often but it does happen.
DD
doogdog is offline   Reply With Quote
Old 12-14-2002, 12:19 AM   #8
BillyC
Member#: 6111
2008 STEYE
World Rally Blue
Default Best place in zee vorld!
I hate XM antennas. they are ugly. I mounted mine on the back deck beside one of those child safety hooks, ran the wire under the seat, and it's done. Looks great and is real stable. BTW, I used the pioneer xm antenna.
BillyC is offline   Reply With Quote
Re-mount Turk satellite radio antenna after body work? C-daleRidr Car Audio, Video & Security 1 03-08-2005 11:54 AM
Where to get CB Radio antenna installed and tuned? simpreza2 Tri-State Area Forum 11 10-18-2004 01:24 PM
STi owners....will our antenna rear window affect satellite radio?? silver ghost STi Forum Archive 2 07-12-2003 10:48 PM
Satellite radio antenna question DrKicker Car Audio, Video & Security 4 05-31-2003 05:31 AM
Satellite Radio Installed on my 2003 XS professordave Forester Forum 5 03-29-2003 04:12 PM
