Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Closed Thread
Old 12-14-2002, 12:27 PM   #1
rsholland
Member#: 5769
'09 WRX Prem 5-dr
Dark Gray
Default Baja (hoped for) visual upgrades
Current Baja:
Suggested "tweaking:"
New tail lights that work better with the other visual elements. The current tail lights look like they were "rubber-stamped," with no thought given to how they would look. The new light design has the clear area (backup light & turn signal) starting where the silver cladding meets the body. This helps with the "wraparound" look of the cladding, as the clear area is similar in "tone" to the silver that surrounds it. It helps unify the design, which is totally absent now.
The word "Baja" on the tailgate has been raised up higher on the tailgate.
The black "seam" on the "C" pillar was removed.
Revised gas cap. No longer is it goofy looking.
Wheels & tires were scaled up 106% to become 17" units. Tires are now close to 235/60x17. The MDX and Grand Cherokee use 235/65x17" tires.
If you look closely, you'll notice the wheel cut outs have also been increased to match the larger tires. The result is the tires and the cladding now work better together.
Tires are now raised black-lettered, and not white-lettered.
Bob
rsholland is offline
Old 12-14-2002, 02:40 PM   #2
natedawg
Member#: 16629
Very Bule
Post
It's possible, that the 2005 model Baja won't have the cladding anymore.
I don't want to start another rumor though.
natedawg is offline
Old 12-14-2002, 05:37 PM   #3
obyone
Member#: 16523
I like the gas door revision but everything else merits and "Ehh...." from me. I don't like 17's on the Baja. It's not a sports car.
obyone is offline
Old 12-14-2002, 07:13 PM   #4
Pipercub
Member#: 2188
2004 Impreza STI
82 BRAT with 12 in. lift
It needs to have a 4 inch body and 2 inch suspension lift as factory options, as well as the H6. 15x9 wheels with 29x9.5 in MT Baja Belteds.
Pipercub is offline
Old 12-14-2002, 08:39 PM   #5
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
I recently saw a Silver Baja locally in a parking lot. The silver made the cladding less of a visual impact. Even Chevrolet got the picture and pulled the cladding off of the Avalanche. Either offer it body color or don't do it.
Even on the silver car, the fuel filler door stood out like a sore thumb. Right there in the cut line of the cladding, and it was a different texture/color than the rest of the car. Looked like a Pep Boys add on.
blaster88 is offline
Old 12-14-2002, 09:39 PM   #6
rsholland
Member#: 5769
'09 WRX Prem 5-dr
Dark Gray
Default If you change the rear, you should also refine the front too...
Current Baja:
The chrome ring that surrounds the grill is now silver to match the bumper.
The two horizontal chrome strips in the middle of the grille, that flank the logo, are removed. The entire inside of the grille is now black.
Both these changes, while rather subtle, "pops" the logo and simplifies the front end a bit.
Bob
Old 12-14-2002, 10:05 PM   #7
rsholland
Member#: 5769
'09 WRX Prem 5-dr
Dark Gray
Default Body lifts...
and suspension lifts will never happen as a factory option. SOA is just not into that.
The 17" wheel/tires don't have to be "sports car" tires.
There will be turbo, not an H-6, but a turbo, available this summer.
Bob
Old 12-14-2002, 11:25 PM   #8
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
it's a f'in truck,
i needs higher displacement Low end torque...
you can't climb over a rock in a low compression turbo engine at 2000 rpm before the turbo kicks in, and it would be a disaster if you were climbing over the rock as you hit the turbo spool point you're nice and controlled, all of a sudden the car's HP and torque jump in quantity, and BAM you need a new undercarage
nomadtw is offline
Old 12-15-2002, 12:53 PM   #9
liigod
Member#: 30512
01 2.5rs
black
hnmm... maybe we should just put a front end that looks like the forrester on the baja, take off the cladding, give it a supercharger, and then we will start to make a nicer car.
liigod is offline
Old 12-15-2002, 01:09 PM   #10
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
There are lots of "trucks" out there that NEVER see off-road, and Subaru isn't blind like US auto makers in this respect. Since most Bajas will never see a two-track, let alone rocks that need to be crawled over, a Turbo 2.0 is a viable engine that will probably boost sales to the younger crowd.
This isn't a Jeep Rubicon, it's a Subaru Baja.
-Brad
Originally posted by nomadtw
it's a f'in truck,
ChicksDigWagons is offline
Old 12-15-2002, 02:09 PM   #11
rsholland
Member#: 5769
'09 WRX Prem 5-dr
Dark Gray
Default Also...
if it's a light-pressure turbo, not a WRX-tuned turbo, you'll get good power down low, where it's needed. Even more so if it's a light-pressure 2.5 turbo.
Bob
Old 12-15-2002, 04:15 PM   #12
Pipercub
Member#: 2188
2004 Impreza STI
That is the whole problem from my point of view. I wanted Subaru to make a serious off road truck like the BRAT.
Pipercub is offline
Old 12-15-2002, 07:54 PM   #13
rsholland
Member#: 5769
'09 WRX Prem 5-dr
Dark Gray
Default Pipercub
I did too, but I don't think it's in the cards. Especially after seeing the concept STX, the production version has been flat out castrated!
I'm just hoping they'll make it a bit more "capable," using items found in their international parts bin. I would love to see the dual-range tranny brought back. I would also love to see the self-levelling rear suspension offered and made standard. Both these features are on Subies in other markets. I would also like to see a full-size spare being used. We know the turbo is coming, so at least that's good news.
Bob
Old 12-16-2002, 03:29 PM   #14
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
allright here's my list of requests that would make me even close to willing to pay that much for it...
first off, more GC... they're marketing the thing as something to take to places your car can't go, but right now i'd be more comfortable taking my friend's oldsmobile off the road than that thing... the ground clearance is about the same, but the olds weighs less...
second, less weight, it's heavy, heavy equals more body drop when you come down from a bump, and also makes it harder to descend less than high traction down grades.
third, more power, i want to be able to actually tow something other than a 500lb generator w/ the thing, and i want to be able to go over things that i can't go over in my OBS
the overall apperance, i agree they should've made it mroe forester looking, less outback looking, but somewhere inbetween...
i want it to be able to score at least a 65 or better on a flex ramp.
the body cladding doesn't btoher me that much.
dual range gearing. nuf said.
solid rear axle, i don't want CV joints, CV joints are weak. and limit any sort of lifting much more than 2 inches w/o sereously causing tire clearance and camber issues.
the bed is just a huge issue, it's narrow, its short, and the passthrough is all but worthless..
i want to be able to carry a 4x8 sheet of plywood in it, otherwise i'd get something non truck, like a jimmy or something...
and on that note, the STX had the rear seats that folded down and the seat bottom came up and became the front of the bed, thereby allowing for a 4x8 sheet, but now it just has a passthrough. i also liked the window rolling into the seat back to fold down.
the leather is just counterproductive...
leather is no good for anythign messy, i'd be afraid to take it offroad in case (and likely) that it got stuck and i had to climb out into the mud to unstick myself...
there should be a trim level with the interior sripped... the uppolstry should be a sealed foam inside and the cloth covers should be easily removed with a zipper or snaps., the floor should not really even be carpetd in my mind, perhaps a nonslip rubberized spray on plastic coating, and while i'm at it, a drain plug. this trim level should sell for around 17K or so to make it available to the people who would get use out of it...
it should also be very easy to mount a functional stump/brush guard that guards the headlight as well as the raditor
bassically i want it to be 2x more capable to do things that i can't do in my OBS, because it's 2x the price, and a truck
when the STX concept came out i was raving about it, even w/ the SC 2.5 although i'd rahter see the h6, or even the rumored H8, mmmmm H8
nomadtw is offline
Old 12-16-2002, 03:32 PM   #15
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
oh yeah, one more thing...
light bar.
nomadtw is offline
Old 12-16-2002, 04:57 PM   #16
juice
Member#: 1424
1998 Forester
Acadia Green Metallic
We won't see a low range.
How do I know?
Well, look at the JDM models - they have a different center console. On the US models, the dual cup holders occupy the space for the low range lever.
Cup holders are more important in this market, sad but true.
I would like to see a midgate and more power, though.
You'll get your wish for no-leather, I think as early as january they'll start making cloth models.
-juice
juice is offline
Old 12-29-2002, 05:37 PM   #17
Keith99RS
Member#: 9243
05 Nissan Titan
06 B9 (hers)
Anybody have a pic of the new body cladding free Avalanche?? I have yet to see one. Could you possibly be confusing it with the redesigned Silverado? It has the same front end look sa the Avalanche.
The Baja's cladding doesn't really bother me. It is an off shoot of the Outbacks cladding, much like the Baja is intended to be.
Doesn't the Baja have the same ground clearance as the Outback? If it does, it should be more than enough for what most will see. I've never had any issues with ground clearance on my wifes '97 Outback. Goes through 8 or so inches of snow and climbs over medians and parking bricks with no problems as well as confidently handing heavily rutted fire roads.
Keith99RS is offline
Old 01-01-2003, 11:03 AM   #18
rsholland
Member#: 5769
'09 WRX Prem 5-dr
Dark Gray
Exclamation The Baja has "LESS" payload than other Subies!
As noted on the door jamb label, the Baja's payload is only 800 pounds. My '96 Impreza Outback and '01 Forester both have 900 pound payload ratings!
Bob
Old 11-17-2012, 12:39 PM   #19
BK5555
Member#: 323538
Default fuel filler door HELP
I Am A Proud Owner Of A 2005 Baja Sport And This A.m. I Went To "tinker" With It And Discovered That The Fuel Filler Door Was Stolen Last Night....i Am Now Trying To Locate A New One And/or Another Option That Will Look Right...any Help Is Appreciated
Last edited by Flowmastered87GL; 11-17-2012 at 06:41 PM. Reason: Start new thread please
BK5555 is offline
Closed Thread
2004 Subaru Baja Turbo w/ performance upgrades!!! WRXtr26 Private Vehicle 'For Sale' Classifieds 21 06-29-2007 11:54 PM
'05 Baja Turbo ( upgraded to STI edition ) 02_Forester Member's Car Gallery 56 12-10-2005 10:40 AM
Import Image is a Perrin dealer- Upgrade your WRX, STI, BAJA, FORESTER, LEGACY! IMPORTIMAGE Engine/Power/Exhaust 16 03-12-2005 09:53 AM
nice upgrade for the baja 2003Baja Car Audio, Video & Security 5 02-17-2004 09:01 PM
suspension upgrades for the Baja? Kai Baja Forum 3 01-18-2003 08:58 PM
