Old 12-14-2002, 02:41 PM   #1
miRo009
Member#: 19618
1999 Impreza 2.5rs
white
Default Help my car out
I was driving my car to school one morning when my car did somehting really wierd. I was in second gear barely pressing the gas, and then i pressed the peddle about 75 percent. My car started to go but then around 4k rpms my car jerked and it was like the fuel cut out. It happened a week later except i was in 4th and was barely pressing hte gas then floored it and the same thing happened. Each time it happend i got scared and put it in neutral immediatly and i dont know wut exactly happened. Maybe it could be from the cold, but my car was at the normal temperature both times. My car is a 99 rs with 50k miles on it. Another thing is about a week before the first time i took out the intake snorkus stuff, but i havent had time to recet the ecu. Any help would be greatly appreciated, cuz at the moment i feel like i have to drive like a grandma. _MIKE
miRo009 is offline   Reply With Quote
Old 12-14-2002, 03:40 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
sounds kind of like a bad MAF to me...99's were famous for it, the only other possiblity is you have a MAJOR vaccum leak that's causing the car to lean out under load and the ECU is just getting confused and enabling fuel cut to defend itself from damage.
Jeremy
Old 12-14-2002, 05:57 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
www.mysubaru.com
you can put your information in there and see if you car is part of the 99s MAF recall.
Jay McDade
Old 12-14-2002, 06:47 PM   #4
miRo009
Member#: 19618
1999 Impreza 2.5rs
white
Hey, i just remembered, when i took my snorkus out, i also took the maf off. There was a rubber ring that went in between the maf and the filter. I forgot to put that back in. Could that be the answer. Oh, and i already got the new maf about 2 months ago. Hopefully this is nothing serious.
Old 12-14-2002, 08:23 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Put that back in, I doubt that would affect it too much because its before the MAF, it would have to be a substantial vacuum leak 'after' the MAF, as in air being introduced into the engine that the MAF doesnt register, there for the ECU does not 'see' the air, causing it to run lean...
reset the ECU also, check all your other connections.
it could also be an ignition system problem, such as a misfire, your miles getting pretty high and the subaru oem wires are not known for longevity and tend to go bad pretty early.
Thats what I would be looking at next if your not throwing a CEL.
Jay McDade
Old 12-15-2002, 01:03 AM   #6
MattDell
Member#: 16803
My car is doing the same thing, but I've got a MY02. I thought it was just stalling, but when you said "fuel cut," that sounds more like what it is. But I've got a CEL and I'm pretty sure it's my MAP sensor.
MattDell is offline   Reply With Quote
Old 12-15-2002, 09:28 AM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
i would get a "fuel cut" too, and it ended up being my coolant temp sensor. get ur CEL code checked though.
Brent
scoobyimprza is offline   Reply With Quote
Old 12-15-2002, 05:08 PM   #8
miRo009
Member#: 19618
1999 Impreza 2.5rs
white
Thanks for all the input. Well i took apart all the intake and maf stuff and put it back on nice and securly. I did notice my filter was all wet, so i guess i was sucking up some water. Then i noticed my inner fender wall, those plastic peices were all falling off, and it must have been sucking up water right off the street, I treid fixing them but all the srews and stuff are broke. Is there a part number for those peices so i could just order new ones, cuz im sure if i bring it to the dealer there gonna charge me an arm and a leg. Im reseting hte ecu now, and if i dont drive in the rain i wont suck up ne water. I also am due for an ignition tune up, so that could be it too. Well, i hope itll be all right. _MIKE
HELP! My car is crapping out on me synickle General Community 4 12-03-2005 01:27 PM
HELP!My car topped out at 140 today. Rickyh Off-Topic 31 10-30-2003 12:40 AM
Im decking my car out...I need a few parts kevinsUBARU Tri-State Area Forum 8 06-25-2001 06:37 PM
Is my car out of the question for a turbo? GregBolby General Forum Archive 4 01-12-2001 08:58 PM
