Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 12-14-2002, 06:48 PM   #1
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
Default 16 x 7.5? or 17 x 8?
if i was to say that i can get some rims made (ROTA's)...
either 16 x 7.5
or
17 x 8.
you can only pick one?
which one?
and why?
sd
suby_dude is offline   Reply With Quote
Old 12-14-2002, 07:12 PM   #2
jmott
Member#: 6713
2007 Prius
brown
depends
for the street Id go for the cheaper one.
for racing, Id look at the specific class rules, tires available, and make a choice based on that.
jmott is offline   Reply With Quote
Old 12-14-2002, 09:01 PM   #3
angryfist
Member#: 22760
#54 STR S2000
crazymonkeyracing
ooh.. do i see an affordable wheel for us autoXers to mount our wide wheels on...
i would say 17x8 to mount some 245/40/17 kumho mx's or bfg kd's since no one makes a competitive 245/45/16 for us people in STX
angryfist is offline   Reply With Quote
Old 12-14-2002, 09:13 PM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I'd say make Grids in 16x7.5 but it doesn't matter to me much since I already bought 16x8. If you come out with some $500 16x7.5s though I'll have to hunt you down.
Old 12-14-2002, 11:08 PM   #5
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
17x8, perfect for STX and the 245 series rubber, or larger if you run ESP or SM.
Also, they have to be the same weight or less than the stock rims.
ChrisW is offline   Reply With Quote
Old 12-14-2002, 11:25 PM   #6
KC
Member#: 442
from using toxic
chrome spraypaint
15 x 8 - 45 offset.
KC is online now   Reply With Quote
Old 12-15-2002, 12:10 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
I second that KC! If not a 15x8 then a 16x8!
Old 12-15-2002, 05:07 PM   #8
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Same here Storm! 15x8, 16x8 or 16x7.5
The slipstream or subzero would look great in that but be able to fit over the STI 4 pots. That is the key. I see that you said that the slipstream in a 16x7 doesn't fit over the STI 4 pots.
Pat L.
Patrick L is offline   Reply With Quote
Old 12-15-2002, 07:24 PM   #9
AUTOwrXER
Member#: 5817
2005 STi
Anything 8" wide is great. Go ET45 if possible. I'd love to have 15x8s or 16x8s, but the good STX rubber in 245 width is only available in 17".
I guess all that thinking aloud means....17x8.
Now if BFG or Falken would only make 245s in 15" or 16"...
AUTOwrXER is offline   Reply With Quote
Old 12-15-2002, 10:28 PM   #10
aspera
Member#: 7879
Have you looked at tires that are not marketed to the US? It seems that they could be imported like anything else, and some are DOT marked.
EDIT:http://www.yokohamatire.jp/yrc/japan/top.jsp
http://ms.bridgestone.co.jp/ms_tyre/...540s_size.html
aspera is offline   Reply With Quote
Old 12-15-2002, 11:07 PM   #11
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
17x8!!
17x8!!
17x8!!
elgorey is offline   Reply With Quote
Old 12-15-2002, 11:39 PM   #12
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
the 15 er..IF it would fit over WRX stock 2 pots ..
that would be a unique wheel
Old 12-16-2002, 12:23 AM   #13
aspera
Member#: 7879
too bad the Imprezas don't have inboard brakes, then we could run stupid-tiny wheels and tires Yo, rollin' on 12's!
Old 12-16-2002, 10:03 AM   #14
jpimienta
Member#: 7457
Default Wheels
17x8, no question about it.
JP
jpimienta is offline   Reply With Quote
Old 12-16-2002, 02:10 PM   #15
AUTOwrXER
Member#: 5817
2005 STi
That's a good thought, but I'm not sure it would work. First of all, the tires would have to be DOT approved and have a treadwear rating of 140 or higher. Secondly, I believe all tires have to be readily available in the US for a certain amount of time before Nationals to be legal. At least, that's how they do the R compounds. It's worth looking into for the street tire rules however.
Old 12-16-2002, 09:59 PM   #16
aspera
Member#: 7879
Default just a thought...that's all
Ellisnc had a Bridgestone tire in another thread that was DOT stamped, yet was not sold in the US (AFAIK).
So if it has a treadwear rating of 140 or higher, it still has to be readily available? Define readily available.
Old 12-16-2002, 10:24 PM   #17
Cosworth
Member#: 3887
08 Taco, 98 M3/4/5
'00 RC51, '08 KTM
17x8 please...
Cosworth is offline   Reply With Quote
Old 12-16-2002, 10:52 PM   #18
aspera
Member#: 7879
I'm still looking, but it looks like anything wider than 225 in a 16 in size is rare worldwide. 17's are just too easy not to use.
Old 12-17-2002, 04:03 PM   #19
AUTOwrXER
Member#: 5817
2005 STi
Default Re: just a thought...that's all
Here are the rules in all their glory, straight from the rulebook. 13.3F is the only one which Street Touring classes are exempt from (4 diameters, min 6 sizes...):
13.3 Tires
Any tire which is O.E.M. on a car eligible for Stock Category may be used. Non-O.E.M. tires must meet the following requirements to be eligible for use in Stock category:
The tire must not appear on the following list, which may be altered at any time by the SEB upon notification of membership.
No tire models are currently listed.
No tire models will be approved for competition during the rest of the year after April 30 of each calendar year. Each eligible tire model must meet all requirements of section 13.3 by April 30, and must continue to meet them thereafter. A tire model will normally be determined by the designation in the Tire Guide. However, any of the following changes or similar changes (as determined by the SEB) will also be considered to represent a new model for eligibility purposes, even if the designation does not change: Change of tread pattern at either full or partial tread depth; characterization by the manufacturer or distributor of a tire as "new" after April 30.
Discontinued model tires already produced will continue to be eligible for Solo II competition in Stock and Street Prepared categories. This follows years of precedence on eligibility for discontinued tire models.
If a manufacturer reintroduces a tire model which was previously discontinued, that tire will be considered a new model. Therefore, it will have to meet the rules specified in SIIR Section 13.3 including the April 30 introduction date.|
The model of tire must be listed in a current or previous two years of the Tire Guide and Tread Design Guide, or otherwise be approved by the SEB. The tire model must have Department of Transportation approval.
Within each tire model, the sizes which are available must be equally available to all competitors. Tire model variations differing from standard specification, delivered only on a limited basis, or only to selected competitors, may not be used.
No racing tire or recap (on any casing) may be used.
Each tire model must be sold in at least four diameters, with a total of at least six sizes.
Tire must fit the allowable wheels and fender wells without modification.
Each tire must have non-zero measurable tread depth (i.e., points where it is possible to obtain positive measurement values) as described in Section 3.3.D. Tires may not have cord visible at any time during competition.
Old 12-17-2002, 04:06 PM   #20
AUTOwrXER
Member#: 5817
2005 STi
Default In Summary
Availability is not the issue, but one would need to have a tire approved prior to 4/30
Old 12-17-2002, 09:04 PM   #21
aspera
Member#: 7879
I'm glad somebody knows what they're talking about. Thanks.
17 x 7.5 or 8 on wagon with stech? 04ts Tire & Wheel 6 02-16-2006 09:48 PM
17 inch wheel by 7.5 or 8.5 Kenji815 Tire & Wheel 6 07-27-2005 12:36 AM
17 x 7.5 or 17 x 8 horf Tire & Wheel 6 05-25-2005 09:25 PM
16 x 7.5 SSR comp's ? Richard A. Brakes, Steering & Suspension 11 10-24-2001 08:51 PM
