Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 04-06-2013, 03:47 AM   #26
Imprzaboy89
Member#: 241311
95L V6WRXSTI type R
HE?RP DERP
its simple stick two extension on the pully then slip a pry bar between then. then you with your ratchet/breaker bar loosen it while a buddy pulls the other way very easy.
Imprzaboy89 is offline   Reply With Quote
Old 04-06-2013, 06:52 AM   #27
drewmob
Member#: 214192
2003 WRX
Originally Posted by Psychoreo View Post
Use something to hold the flywheel in place
This. I have an extra socket wrench that I've used on several different engines. It works perfectly on Subarus.
drewmob is offline   Reply With Quote
Old 04-06-2013, 09:15 AM   #28
hoffmanEstates
Member#: 122043
04 wagonier
psm
Originally Posted by cmaj7 View Post
Just to reinforce 90-95 ft-lbs.
BTW, you can borrow a torque wrench from autozone for free, just leave a refundable deposit!!
I would rather use my "torque" arm for the tq spec then a autozone
hoffmanEstates is offline   Reply With Quote
Old 04-06-2013, 09:17 AM   #29
hoffmanEstates
Member#: 122043
04 wagonier
psm
This is what i have done, breaker bar jammed in there and used a massive ratcheting breaker from Snapon i had, removed bolt,slid pulley of no puller needed,installed Cobb pulley, tightened by hand, and put 170k on it and no issues
Old 04-06-2013, 11:28 AM   #30
navydub
Member#: 242585
2005 Saabaru
I just made a little bar for the back of the engine. It allows me to put a clutch bolt in the flywheel and thread a trans bolt into the back of the block. With those two tightened down, the engine cannot turn.
Then I just go back to the front and easily undo the pulley bolt with my breaker bar. Granted this only works if you have the trans off too.
If the trans is still attached go with the braker bar on the frame rail + starter method.
navydub is offline   Reply With Quote
Old 02-01-2016, 09:14 AM   #31
BajaShouta
Member#: 436028
I'm confused, is everyone suggesting that you take the crankshaft off while the car is on??
BajaShouta is offline   Reply With Quote
Old 02-01-2016, 09:26 AM   #32
quazimoto
Member#: 70395
No. Your are "bumping" the starter. Basically using the torque of the starter motor to break the bolt loose. Pull the fuel pump relay or pull the ignition fuse to keep the motor from accidentally starting.
Originally Posted by Uncle Scotty View Post
there IS an easy way to get the bolt lose...it really isnt recommended..but it takes all of about 10 seconds
if ya get the socket/breaker bar on the bolt....and laythe breaker bar over across the front so the handle is resting on the frame where the battery mount is
and ya take the 'IGN' fuse out(i dont but..... )
and ya give the key just ONE lil bump...as in ONE short sharp shock, dig it????
the starter will spin the motor...the breaker bar will keep the bolt from spinning and the bolt will break free and you can just spin it right out, thank you very much
DO THIS AT YOU OWN RISK
i didnt come up with this but it DOES work...done it more than once
AND DO NOT LOSE THE WODRUFF KEY
quazimoto is offline   Reply With Quote
Crankshaft Pulley Removal pilotstephen General Community 4 08-15-2007 02:18 PM
Has anyone removed a crankshaft pulley on an Automatic? Rockgod Legacy Forum 20 06-22-2007 06:35 PM
Crankshaft pulley bolt removal? Kayakertom 'Old School' Subaru Forum 5 02-07-2005 01:49 PM
Removing crankshaft pulley llonman Technical Forum Archive 9 08-28-2000 02:23 PM
