Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 12-15-2002, 08:01 AM   #1
Scooby_Treat
Member#: 20676
Unhappy Help:Ran through puddle of water
wussup yall. Just came home at 3 in the morning and it was raining real hard i mean like even with AWD it still had hard time getting traction. Well car ran through a FAT puddle that i couldnt see because the rain was so horrable. Car just F'd up now when i floor it it just jerks around 4 rpm at WOT. when car is not in gear and i gas it till 6 rpm everything is koo. When i listen 2 the engine it sounds the same as no damages. Now when i open my airbox i find out that my MAF sensor is wet. Just wondering how much damage have been caused to my car and if the MAF sensor can be the cause of the reason why my car is jerking at 4 rpm at WOT
Scooby_Treat is offline   Reply With Quote
Old 12-15-2002, 12:35 PM   #2
Seraph
Member#: 12251
That sounds like a good reason, i've hit huge puddles before and i've never had any problems, and we're talking about puddles that are like 3-4 inches deep and big enough to swallow my whole rim at one time, i've hit one at like 45 and had the water come up over the roof, but luckily i've never gotten my MAF wet.
Since its wet, it would read as the car getting less air than it needs, so it might cut back on fuel to keep you from running too rich, hence the possibler jerking, you're simply not getting enough fuel for the air thats actually going into the engine, which means you're running lean and might lead to detonation, my advise is to keep the revs low until you can get the thing to read correctly again.
Seraph is offline   Reply With Quote
Old 12-15-2002, 02:17 PM   #3
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
Last time I did that "muckin" ( ) through some mud holes, I found at least a half gallon of water in my intake. The filter gets wet and can't flow much air. Open the airbox, let the filter dry out, disconnect some of the hoses and let the water out and you'll be fine. No permanent damage.
-Brad
ChicksDigWagons is offline   Reply With Quote
Old 12-15-2002, 02:50 PM   #4
Scooby_Treat
Member#: 20676
i should have stated my speed. I was going 65-70 when i hit that puddle it was like 4-5 inch's deep. When i look in my splash guard on my right wheel tire well(sp) it pushed back and water was acctually getting sprayed into my engine bay.
Old 12-15-2002, 02:54 PM   #5
rexspeedworthy
Member#: 26965
2013 XV crosstrek
I had a bra on mine and in the rain it leaked into intake
getting MAF sensor wet...twice. Made CEL come on.
took to dealer under warranty got it replaced free!!
rexspeedworthy is offline   Reply With Quote
Old 12-15-2002, 02:55 PM   #6
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Um, I dont think the WRX's are MAF based....I thought all Subaru's after 2000 were MAP based?
If so, how could a non existant MAF be wet?
Just a thought
DDMan is offline   Reply With Quote
Old 12-15-2002, 03:13 PM   #7
MPREZYA
SCIC
Member#: 85
Just a thought
2.5 yes WRX no. The WRX has MAF sensor that's attached to the airbox.
MPREZYA is offline   Reply With Quote
Old 12-15-2002, 04:17 PM   #8
DDMan
Member#: 11221
2002 2.5 RS
Ah, you learn something new every day!
Thanks for correcting me
Old 12-15-2002, 07:30 PM   #9
KnightRider
Member#: 28439
Koss Khor
sorry dude, this would be the reason i but my intake resonator back on for the rainy season
KnightRider is offline   Reply With Quote
Old 12-16-2002, 05:20 AM   #10
KillerRex
Member#: 15675
'92 R32 Skyline GTR
Well, just be happy you didn't hydrolock your motor. That would be major sux0rs!
KillerRex is offline   Reply With Quote
Old 12-16-2002, 05:52 AM   #11
Scooby_Treat
Member#: 20676
The car is running great again. All i had to do was just dry the MAF with a hair dryer. Also replaced the Air filter with a K&N 1.
Puddle of water under my car shamrock 05 General Community 20 06-06-2008 11:46 AM
When driving through 15" of water - CLOSE SUNROOF il96 Off-Topic 21 09-30-2004 10:41 AM
Driving through lots of water Odin General Community 24 07-25-2004 09:25 PM
Ran through a puddle of water Scooby_Treat Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 12-16-2002 07:55 AM
Clutch stayed down when shifting through puddle!? Alldidasmc Transmission (AT/MT) & Driveline 0 10-16-2002 06:21 PM
