#1 |
Member#: 16336
Vehicle:2002 WRX Wagon Black |
I’m testing out a Dawes Devices Hybrid Manual Boost Controller (http://www.dawesdevices.com/boost.html) that I borrowed from a friend. I used the directions from Scooby mods and got it in there without a problem. I installed it using the stock hoses. I plug up the hose that ran to the stock controlling device I used one of my spare 3/16th resistors and melted one end shut. I have the stock steering column boost gauge that measures in MPas.
I set it pretty low to start out with about .04 is what I got out of it. My goal is .1 or, from what I gather should be 14.5 lbs (correct me if I’m wrong). So I went out for another run, got it up to .06. Then I got .07 on the next. Finaly I think I got the ratio of turns down and I get it almost perfect at .095. I turn it about a quarter turn more and I’m there. I had been using a pretty big not so busy road to test it at. I didn’t really get out of first. So I go back to my house, grab my roommate (who’s boost control it is) and we go out to get some Jack in the Box. On the way there, I hoped on the freeway to see what it would do at speeds. I noticed that in 4th, I was up to like .105 and in 5th I almost hit .11. From my basic understanding of how this all works, it kind of makes sense. I know the stock gauge isn’t too great. I plan on getting a new vacuum line for it, I hear that helps. I’m going to turn it down so I don’t go over .1 in 5th. Is the behavior normal? What’s happening?
#2 |
Member#: 14141
Vehicle:2002 Impreza WRX e85forum.net |
Its a function of higher engine load in the higher gears ( less mechanical advantage, so the engine has to work harder). More load = more highpressure exhaust to drive the turbo = more boost.
Larry |
#3 |
Member#: 12454
Vehicle:10 Toyota Taco K8 SV650SF |
hotrod explained it pretty well.. My advice would be to tune your boost controller for .1bar in 4th gear to be safe.
#4 |
Member#: 15289
SCIC
Vehicle:02 wrx sedan PSM & grey '11 TDi daddywagon |
according to shiv from vishnu performance, you should set your boost in 4th gear at full throttle. I believe he says 4000 rpm, but with a gutted uppipe, you should get full boost at under 3000.
#5 |
Member#: 16336
Thanks!
| Thread Tools | |
| Display Modes | |
| How high can you get the boost in first gear, large turbo owners speak up!!! | jared nelson | Factory 2.5L Turbo Powertrain | 31 | 10-24-2005 01:37 PM |
| mbc/ebc and peak boost in lower gears? | chrisfranklin | Factory 2.5L Turbo Powertrain | 2 | 08-02-2004 09:29 PM |
| Should I be getting boost in First gear? | cpu77 | Normally Aspirated with bolt-on Forced Induction Powertrain | 14 | 04-09-2003 12:45 AM |
| Can't reach full boost in 1st gear with new BOV, HELP!!! | revelation | Factory 2.0L Turbo Powertrain | 10 | 07-25-2002 12:33 AM |
| STi 7: how to get full boost in 1st and 2nd gears? | GDB | Factory 2.0L Turbo Powertrain | 11 | 05-30-2002 03:18 AM |
