Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 12-15-2002, 03:59 PM   #1
Rexkid
Member#: 13487
2002 WRB Wagon
OZ P1's, Vishnu 0
Default 48mm offset vs. 53mm offset
I have done all the searches but am still left with the question as to what is really the difference between the two offsets in terms of fitment. I realize there is a 5mm difference. But how come shops such as tirerack.com reccommend the exact same tire size??? I would think that the same tiresize would have a higher tendency to rub on the +48s.
Anyone?
Rexkid is offline   Reply With Quote
Old 12-15-2002, 05:16 PM   #2
Frederf
Member#: 15622
2002 WRX SW
Offset has nothing to do with how the wheel and tire fit together. Until you put the wheel/tire on the car offset is not a factor at all. JUST REREAD YOUR POST: The wheel -> tire size calculator always comes up with the same suggestion regardless of the specific vehicle. It's not smart enough to say, "Hey, use a 215 and not a 225 so you won't rub on a WRX!"
Offset is the distance from the center of the wheel (width wise) to the plane at which the wheel bolts up to the car. A big offset would have a very deep concave backside.
High offsets will get the wheel and tire toward the center of the car and out from under the fender. But they, bringing the wheel/tire inward, bring it closer to rubbing on the inside.
The proper tire depends on 1. wheel diameter, 2. wheel width, 3. offset, 4. sedan/wagon
I for example am planning to put STi7 wheels on my wagon. Since that's a ET53mm 7.5" wide wheel on a wagon, I'll probably have to run the least obtrusive tire possible.
It all comes down to "it depends." List your setup and with those specifics someone can tell you what the right tire is.
Frederf is offline   Reply With Quote
04 offset vs 05 offset xrocket21 Tire & Wheel 0 04-05-2006 09:38 AM
35mm offset vs 48mm offset same width wheel? I'VE SEARCHED LukeWRX Tire & Wheel 3 06-07-2005 02:01 AM
38mm offset vs 44mm offset wrxxed Tire & Wheel 14 10-29-2004 06:45 PM
48mm offset vs 51-53mm offset on wagon WRXinEffect Brakes, Steering & Suspension 4 02-09-2003 03:31 PM
Disadvantage of 48mm offset vs. 53mm? EricB Brakes, Steering & Suspension 7 02-08-2001 01:42 PM
