Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 12-15-2002, 11:22 PM   #1
willguidry
Member#: 16388
Default Factory Performance Gauge Pack Questions
Ok, so I just have the empty opening up top with the opening door where the gauge pack SHOULD go.
My questions are as follows:
1: I can buy this from my subaru dealer and install it myself correct?
2: Does this kit come with the replacement top for that area? I.E the replacement for the pop up door, Or do I have to fab my own?
and Lastly...
3: Can I install the oil temp probe in conjunction with my Fumoto oil valve drain?
And I guess I lied, about how much does this kit cost?
Cheers
Will
willguidry is offline   Reply With Quote
Old 12-16-2002, 08:14 AM   #2
willguidry
Member#: 16388
*bump*
Old 12-16-2002, 05:11 PM   #3
DoorKnob
Member#: 395
2000 Impreza 2.5RS
Blue Ridge Pearl
1. Yes
2. No, but the dealer has a cover you can buy.
3. No, oil temp sensor is in a new drain plug
It's listed at the dealer over $500. There really isn't anywhere you can get it execpt from there. Maybe you can find someone that is willing to sell it used.
DoorKnob is offline   Reply With Quote
Old 12-16-2002, 08:44 PM   #4
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
you can buy a gauge pod from jamie for ~$60
then buy an aftermarket faceplate to fit 52mm gauges from derres catalano (pm him) -- or buy the whole gauge pod/face plate combo from him.
Then choose your own 52 mm gauges to install.
This combo should replace the pop up door on top of the center console!
cRayZee is offline   Reply With Quote
FS: OEM factory performance gauge pack Impreza WR Rex Interior/Dressup/Audio & Security 21 01-20-2010 07:36 AM
Stupid Question... on Performance Gauge Pack Digital_Bees Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-17-2009 08:36 PM
Need help anyone with performance gauge pack or oil temp gauge JDM5LugHatch Normally Aspirated Powertrain 5 06-04-2001 02:10 PM
Factory Performance Gauge Pack zephyr451 Technical Forum Archive 7 09-28-2000 01:52 PM
