Old 12-16-2002, 06:38 AM   #1
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Default How to proper wire external pumps
Hi friends!!!!, just a short note to let all your suggestions on how to properly wire my two externals pumps
Car is a Gc8 with N/A ECU, so no controller at all, right?
I want them to prime the fuel system when swicthed on as the intank one does without screwing the stock electrical fuel related components...
Thanks for all possible diagrams, links etc
DJ
DJIMPREZA is offline   Reply With Quote
Old 12-17-2002, 12:15 AM   #2
Austin
Member#: 7089
2016 STi
Easiest way would be to run fused (~30A) (how big are your external pumps?) 10awg wire back to the pumps, through a relay mounted in the trunk.
Switch the new relay off the output of the fuel pump controller. You can wire the relay switch in parallel across the controller output.
Austin is offline   Reply With Quote
Old 12-17-2002, 12:47 AM   #3
Gerry
Member#: 1829
DJ..You need a BOCH or Potter & Blumfield relay..
#86 to Ground
#30 to 12v+
#85 to ECU wire
#87 to 12v+ on pump...
I'll send out some pics tommorow..Gerry
Gerry is offline   Reply With Quote
Old 12-17-2002, 07:14 AM   #4
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Terrific Gerry!! thanks a lot!!
DJ
How to hook up External Hardrive to Kenwood DDX-514 08SubieWRX Car Audio, Video & Security 7 01-08-2010 11:55 AM
how to properly attach copper ends to amp wire nation1979 Car Audio, Video & Security 11 02-28-2009 05:45 PM
How to properly wire a radiator fan with a switch? Kwyjibo Electrical & Lighting 0 08-26-2005 07:16 PM
How to properly paint Calipers? Jasno999 Interior & Exterior Modification 17 08-09-2002 12:17 PM
How to properly break-in my baby RedlineRex Newbies & FAQs 8 09-19-2001 09:56 PM
