Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 12-16-2002, 03:09 PM   #1
Steppin Razor
Member#: 24035
2002 GGA 5MT
Seal Gray
Default Subwoofer harness
Does anybody here know about a wiring harness that will allow you to connect a subwoofer and amp to the back of the stock head unit?
Steppin Razor is offline   Reply With Quote
Old 12-16-2002, 04:51 PM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Line Out Converter (LOC)
It requires some splicing and running wires, but that's the only option, there is no low-level output on the stock head unit.
www.davidnavone.com
I have the N777 in my car. It is definitely superior in sound quality to the PAC LOC that I had before (got from Circuit City) that thing sounded awful in comparison.
Concillian is offline   Reply With Quote
Old 12-16-2002, 05:52 PM   #3
Steppin Razor
Member#: 24035
2002 GGA 5MT
Seal Gray
Default N-777 Install
Did you do the install yourself? If so I would like to talk you. Does it require running a power source directly from the battery? What do you have to tear out in order to run the wires? I am very curious?
TIM
Old 12-16-2002, 07:52 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Install myself -- yes, with some help from someone who had before. For the LOC itself, if you're only adding a sub, you just have to tap the wires into the pair you want the sub output coming from (likely the front) Just a standard wire tap will work fine. IF powering speakers in addition to the sub, you need to cut the wires and route them from the head to the LOC, then from the amp back to the speakers.
Power from the battery -- yes, ANY amp or seperate sub will require a direct power line + a remote power line. The LOC itself doesn't require power, but any amp you use it with will.
Removal for install -- center console, stero console and driver's seat, all are easy to remove. Center console is a few 'pop outs' and four screws, the driver's seat is 4 14mm bolts. Stereo console is two screws for the cupholder, pop off the plate, and 6 screws for the head unit. I also had to remove the rear seat to run wires to my sub in the rear, but that's easy also (6 12mm bolts)
Obviously my amps are under the driver's seat. Installation elsewhere may require more.
wtb: stock subwoofer harness yellowrxo2 Private 'Wanted' Classifieds 0 08-17-2004 02:15 AM
Subwoofer Harness pn: H6300LS320 javawinq Private 'Wanted' Classifieds 0 06-14-2004 04:22 PM
Subaru subwoofer harness Canbaru Private 'Wanted' Classifieds 0 09-18-2003 02:25 PM
WTB: OEM subwoofer + harness dookiebob Tri-State Area Forum 12 05-28-2003 05:33 PM
Factory subwoofer harness impynave Car Audio, Video & Security 2 11-03-2002 12:42 AM
