Welcome to the North American Subaru Impreza Owners Club Saturday September 20, 2014
Old 12-16-2002, 09:59 PM   #1
WRCwannabe
Member#: 28349
2003 Peice-o-sht WRX
Selling it for a Hyundai
Unhappy wierd noise over 130mph
I have noticed a wierd noise coming from the drivers side at around 130 mph. It isn't a gradual noise, it just comes on. It sounds like the beep from the "emergency broadcast system". I was just wondering if this is some kind of warning tone, or if my car sucks. I've never seemed to notice this sound in the past.
WRCwannabe is offline   Reply With Quote
Old 12-16-2002, 10:01 PM   #2
Austin
Member#: 7089
It's the space between your side view mirror and the mirror mount whistling. Stick a piece of foam in it to shut it up.
Austin is offline   Reply With Quote
Old 12-16-2002, 10:07 PM   #3
CrXWrX
Member#: 24876
-- imprezza wrx
will be black
Default windows?
i was told it was the windows being sucked off the molding due to the fact that we have framless doors. the speed of the air creates a vacum, sucking the windows out.
or atleast thats what i got out of a post about a week ago bout this same thing.
CrXWrX is offline   Reply With Quote
Old 12-16-2002, 11:17 PM   #4
mikkyo
Member#: 25399
2003 Impreza WRX
I really wish the mods would get together and make stickies, update FAQs etc, especially for the questions that are asked over 100 times.
The passenger side mirror whistles. It is known. You can fold it in and check for protection plastic left over from the dealer, fold it in and out and see if it goes away, stick a piece of foam in it, put thick black tape over the cracks, custom order a rally mirror from Japan, or just use it to scare folks that you pass or your passengers.
I don't think you can suck out your windows until the pressure difference between the cabin and the exterior is pretty huge. Maybe around 200mph?
mikkyo is offline   Reply With Quote
Old 12-17-2002, 09:50 PM   #5
j-wrx
Member#: 14180
2002 Stg.1 WRX Wagon
Platinum Metalic Silver
Keep on the gas, the noise will go away when you bury the spedo past 140...
Just think of it as a way to keep you on your toes when your nearly doubling the speed limit.
j-wrx is offline   Reply With Quote
Old 12-18-2002, 01:34 AM   #6
M3sum
Member#: 18226
2001 M3
Laguna Seca Blue
and of course all this is done on the track right!
M3sum is offline   Reply With Quote
Old 12-18-2002, 02:02 AM   #7
ZERO26D
Member#: 28476
WRBlue
if you just tap down on the window button real quick like it will go away works for me
ZERO26D is offline   Reply With Quote
Old 12-18-2002, 02:18 AM   #8
Massimo
Member#: 23122
02 WRX Wagon
Midnight Black
I usually get that at EXACTLY 100MPH. (sorta like my warning ) Sounds like its coming off the antenna or up by the roof rack...
Just my $.02
Massimo is offline   Reply With Quote
Old 12-18-2002, 11:49 AM   #9
araknyd
Member#: 24483
2008 STi
Dark Gray Metallic
It's the voice inside your head screaming, "Slow down before you get arrested or killed!"
araknyd is offline   Reply With Quote
Old 12-18-2002, 03:27 PM   #10
WRCwannabe
Member#: 28349
Thumbs up 140mph?
So, just hammer it down to 140 then?
...GOT IT!
Old 12-18-2002, 06:51 PM   #11
aREX4X
Member#: 18781
I get that noise too. I will try that foam deal. It's good to know someone has figured it out. I posted about this a few months ago.
aREX4X is offline   Reply With Quote
Old 12-18-2002, 08:12 PM   #12
WRCwannabe
Member#: 28349
I've found the fix!
I noticed if my car starts making noise around 130mph, I just drink some beers and it goes away.
Old 12-21-2002, 01:50 AM   #13
WRCwannabe
Member#: 28349
drinkin beers?
Old 12-21-2002, 02:00 AM   #14
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
If you can hear it, your radio isn't loud enough.
slowmike is offline   Reply With Quote
Old 12-21-2002, 06:58 AM   #15
mlambert
Member#: 13831
Originally posted by WRCwannabe
I've found the fix!
best reply evar
mlambert is offline   Reply With Quote
Old 12-22-2002, 12:55 AM   #16
sick1.8t
Member#: 22345
2003 RSX
black
my drivers' side mirror did it, so i just covered it with a piece of electrical tape.
sick1.8t is offline   Reply With Quote
Old 12-26-2002, 08:12 PM   #17
inandhra
Member#: 24766
2002 WRX Wagon
Colored with Dead Bugs
Default tape did it? Like.... where?
I get this noise at 127mph under certain atomospheric conditions (dunno what yet though )
So.... where did you put the tape on the mirror?? !!
Thanks
inandhra is offline   Reply With Quote
wierd noise and jerking the spacecowboy Normally Aspirated with bolt-on Forced Induction Powertrain 5 01-03-2003 10:22 AM
Wierd Noise! Plese Help! wrxstacy Factory 2.0L Turbo Powertrain 4 10-21-2002 07:32 PM
wierd noises coming from the back wheels advance Brakes, Steering & Suspension 4 07-02-2002 10:07 PM
Wierd noise tifosi77 Factory 2.0L Turbo Powertrain 2 01-14-2002 02:02 AM
Help guys! Wierd noise! Iluminus Tri-State Area Forum 19 12-28-2001 06:12 PM
