#1 |
Member#: 7879
#2 |
Member#: 25128
NWIC
Vehicle:1983 911sc Matte Mexico Blue :) |
not quite sure what you mean. do you mean space them out a little more than they are? if so than yes, you can take your fender off and make the mounting holes a little large with a dremel or something and through them back on. but by doing this you will also have a larger gap between your fender and your hood.
#3 |
Guest
Member#: 23351
Vehicle:Pika Chu! TEAM DARRIIFFFTAA |
yep, you will need some money and a good metal worker/ body shop. check with normal custom shops to see if they can do it... if not, then find a hot rod shop... ones by my house can do anything with metal.
| Thread Tools | |
| Display Modes | |
| is it possible to swap a front end from a saab?? | bereda | Interior & Exterior Modification | 31 | 12-05-2008 06:56 AM |
| Is it possible to bring the 4pots close to the stopping power of Brembos? | Hyper | Brakes, Steering & Suspension | 2 | 10-31-2006 03:20 AM |
| is it possible to get the WRX letters on to the IC? | Carbon888 | Interior & Exterior Modification | 41 | 04-05-2005 02:07 PM |
| Is it possible to remove the front swaybar w/ the tire still on? | MF-DIF | Brakes, Steering & Suspension | 8 | 03-31-2005 09:26 AM |
| How is it possible to mount the car body six inches the left of the frame? | scaryfastskier | Off-Topic | 16 | 10-26-2004 08:30 PM |
