Old 12-17-2002, 11:35 PM   #1
Subarusalesman
Member#: 30918
1983 Mercedes Benz 3
Midnight Blue
Default Engine specifications - Bore & Stroke etc.
What is the bore & stroke of the normally aspired 165 hp Subaru 4 cyl. engine, & how does the WRX 2 litre engine differ from it, besides being turbocharged?
What is the bore & stroke of the new H6 engine?
Subarusalesman is offline   Reply With Quote
Old 12-17-2002, 11:53 PM   #2
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
The bore of the NA EJ25 is 9.96, and the stroke is 7.9, the WRX engine has a bore of 9.20, and the stroke is 7.5. I don't have info on the H6 though.
-Wes
RebelINS is offline   Reply With Quote
Old 12-18-2002, 10:46 AM   #3
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
in what units are you speaking? I KNOW those aren't inches and they don't look metric either...
mrbell is offline   Reply With Quote
Old 12-18-2002, 12:34 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
They're in centimeters.
Old 12-18-2002, 02:05 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
The normally aspirated 4 cyl Subaru engine that is rated at 165 hp in the US is called the EJ25 by Subaru, the H6 engine is called the EZ30 and the 2 liter engine is called the EJ20.
Here are some 2002 specs:
Bore x Stroke (mm), compression ratio
EJ20 - 92 x 75, 8.0:1
EJ25 - 99.5 x 79, 10.0:1
EZ30 - 89.2 x 80, 10.7:1
The EJ20 and EZ30 both have dual overhead camshafts in each head whereas the EJ25 uses a single overhead camshaft. The EJ20 and EJ25 both utilize a single belt to drive all of the camshafts whereas the EZ30 uses a separate chain for each head. The EZ30 employs a variable-length induction system while the EJ20 and EJ25 both use a fixed-length induction system.
Jon [in CT] is offline   Reply With Quote
Old 12-18-2002, 02:16 PM   #6
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
ah-ha... I should have figured that one out... sometimes I wonder if my brain still works...
Old 12-19-2002, 02:00 AM   #7
RebelINS
Member#: 2953
2000 Impreza 2.5RS
I probably should have included the units in my original post, sometimes I just don't think when I am typing.
-Wes
The OFFICIAL USDM Subaru Engine Specification Thread (Hp/Torque/Designation/Etc.) Kostamojen General Community 54 10-02-2010 12:55 PM
EJ20G Specifications-Bore, journals, etc turboL Subaru Conversions 2 09-11-2007 12:07 PM
EJ22/25 bore & stroke Olson Subaru Conversions 8 08-29-2005 06:14 PM
EJ22T bore & stroke? jeff22 Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-25-2002 12:07 PM
NA Engine design: revs, bore & stroke, and what not kgb Normally Aspirated Powertrain 100 11-01-2001 01:22 AM
