Notices
Old 12-18-2002, 06:12 PM   #1
jatyrx
Member#: 23382
2003 ej207
Question flow limit valve in the hydraulic clutch line (how to take it out?)
hi,
can anyone answer this ? i know on the 03 there is a flow limit valve in the hydraulic clutch line. is there anyway to remove that? or what should i change? thanks
-jayson
jatyrx is offline   Reply With Quote
Old 12-19-2002, 09:39 PM   #2
gpd323
Member#: 9878
2002 WRX/GTX
WRX Wagon/Mazda GTX
I don't know about the WRX but my GTX had the same thing. I unbolted the line into the slave cylinder and there was a spring and check valve that I took out. The check valve had a very small hole in it. It was like a orifice. It was one of the 1st things you did with the 323GTX to make the clutch action more positive and direct.
I bet you can order a slave for a 2002 WRX and get it W/O the check valve. And I bet its a direct bolt up. Something to think about.
Greg Downing
gpd323 is offline   Reply With Quote
Old 12-20-2002, 08:14 PM   #3
downshift1
Member#: 15607
I'm not the type
to make angry
The easiest way is to install the STi clutch line or something similar. The hydraulic actuator in the line is exactly like the unit that Mitsu was using on the 2nd gen eclipse/talon. Dont try and dissasemble it as you will probably ruin it.
-Dylan
G7 Motorsports
downshift1 is offline   Reply With Quote
droped some small particles in the engine chamber what the best way to take it out? 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-15-2007 11:01 PM
On the upside, he's probably used to taking it up the ass beachbum Off-Topic 23 05-16-2006 05:18 PM
How to take cage out of inner CV? subbySTi44 Transmission (AT/MT) & Driveline 0 01-09-2005 07:32 PM
How to take studs out from header->head mcu81 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-15-2004 10:51 PM
anyone in the naperville area know how to change out the side skirts? yuns555 Mid West Subaru Owners Club Forum -- MWSOC 5 02-21-2002 03:34 PM
