Old 12-19-2002, 01:25 PM   #1
mike270
Member#: 12863
2002 2.5RS
Default Exhaust questions
If i got a stromung exhaust and a ganzflow intake would i still pass emissions?
Also would I notice an improvement in performance without getting headers, etc.???
Thanks a lot
mike270 is offline   Reply With Quote
Old 12-19-2002, 01:30 PM   #2
cvalle-sd
Member#: 420
2001 Cr-V
Noticeable improvement in power - not major, but you'll feel a difference. Emissions should not be affected.
cvalle-sd is offline   Reply With Quote
Old 12-19-2002, 01:36 PM   #3
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Agree....but if you live in a state where the inspector must look under the hood you will fail the VISUAL part of the inspection.
Albert is offline   Reply With Quote
Old 12-19-2002, 05:43 PM   #4
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
I don't know why you'd fail... it does not affect any emissions controls. AFAIK, anything not between the throttle body and the cats are fair game(as long as they dont' cause noise problems)
mrbell is offline   Reply With Quote
Old 12-19-2002, 06:02 PM   #5
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Not true, [at least in California], the intake MUST have a EO# (CARB) before the inspector can procede with the inspection. And of course if he sees it you automatically fail,
If your state has a visual inspection I would double check the criteria before presenting the vehicle for inspection. The sad part is that most vehicles with intake will still pass the sniff test.
Old 12-19-2002, 07:21 PM   #6
mike270
Member#: 12863
2002 2.5RS
would this setup reduce reliability at all?
Old 12-20-2002, 03:22 AM   #7
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
mike270 - generally your reliability shouldn't be affected w/ just a Ganzflow and a cat-back. Word of advice. If you get a Stromung, don't get mild steel. It pays to get stainless the first time. Just take a look for yourself ->
http://forums.nasioc.com/forums/show...threadid=90727
GTBGUY is offline   Reply With Quote
Old 12-20-2002, 06:16 AM   #8
nate49509
Member#: 22452
2016 WRX
Why not just take off the intake for the inspection? It only takes a couple minutes.
nate49509 is offline   Reply With Quote
08 STI exhaust on 08 WRX Exhaust Questions J-Rod 555 Newbies & FAQs 6 06-08-2009 03:58 PM
Exhaust Question for a QUIET Exhaust.. The Blue Pilot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 01-19-2008 11:54 PM
Full OBX Exhaust? General exhaust questions. stoney98 Normally Aspirated Powertrain 12 06-18-2007 11:39 AM
Aftermarket exhaust question. The older the exhaust gets, the raspier? 2005wrbluesti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-12-2006 10:16 PM
Aftermarket exhaust question. The older the exhaust gets, the raspier? 2005wrbluesti Normally Aspirated with bolt-on Forced Induction Powertrain 0 12-12-2006 03:52 PM
