Old 12-19-2002, 06:32 PM   #1
teamslow wrx
Member#: 18986
2002 wrx
sliver i Have 4 cats!!!
Default Morette help
I just installed my morette head lights and the left side doesnt work on the brights and the brights are even bright on the right side help me please
Paul
teamslow wrx is offline   Reply With Quote
Old 12-19-2002, 08:29 PM   #2
brunetmj
Member#: 8023
2004 2.5 RS
Paul,
I probably canít answer your question , but for anyone to help you will have to give more information.
1. Do the Low Beams work?
2. Are you using an wire adapter or did you splice into the stock wires?
3. Have you checked the wiring to make sure you have it connected to the correct fitting on the non working bulb?
4. If one beam is working have you tried swapping the bulb in the working light and putting it into the non working one?
brunetmj is offline   Reply With Quote
Old 12-19-2002, 08:58 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Assuming you got your lights with plug-in adapter harnesses, most likely one of the adapters is wired incorrectly. This has happened to many people who got Morettes. Check the wiring on both adapters, if they do not match that is your problem. Hopefully at least one of them is correct so you can fix the other one to match it.
Morette help!! ATXWRX Electrical & Lighting 7 06-02-2005 02:49 PM
THANKS OMAN!! & Morette help ATXWRX Texas Impreza Club Forum -- TXIC 0 06-01-2005 09:16 AM
morette help GotTurbo Legacy Forum 9 05-24-2005 09:23 PM
Morette help WRXminion Interior & Exterior Modification 4 05-10-2004 10:55 PM
Do Morettes help you see better? rtam Interior & Exterior Modification 3 11-06-2002 05:13 AM
