Old 12-21-2002, 12:03 PM   #1
Redneck Ricer
Member#: 21458
2011 Jeep
Smurf Blue
Default Big Problem: Engine revs, cutting out..HELP!
OK, got a big problem on my 99 2.5 rs. the engine revs great till 4000 rpm, and then dies out completely, like it is bogged down.
Also, when idling, it will fluctuate between 200 and 1500 rpm on its own, revving itself. Under the hood, the throttle cable is not moving at all, could it still be the throttle body though?
Please help!! Any ideas so I can fix this right away?
The only mods to the engine is a 5zigen CAI.
thanks a million in advance!!
p-rex
Redneck Ricer is offline   Reply With Quote
Old 12-21-2002, 12:36 PM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
Check your fuel filter, Spark plugs, and spark plug wires... those are usually the three main problem causers... Possibly your PCV valve but I doubt it.
rhdude is offline   Reply With Quote
Old 12-21-2002, 12:44 PM   #3
Redneck Ricer
Member#: 21458
2011 Jeep
Smurf Blue
Just installed new plugs and wires, still doing the same thing afterwrads as before....
possible they are gapped wrong? I used factory settings like reccomended
any other suggestions?
P-rex
Old 12-21-2002, 01:56 PM   #4
rhdude
Member#: 6637
Have you ever changed the fuel filter... my car bogged and idled funny, I changed the fuel filter, and bam, problem was gone... other than that possibly a blown MAF( a commen MY99 problem) or a idle air sensor... Try the fuel filter first.
Old 12-21-2002, 02:44 PM   #5
Redneck Ricer
Member#: 21458
2011 Jeep
Smurf Blue
ok, so did the wires and plugs this morning....
now did the fuel filter and the pcv valve...now the car will not start I am guessing since the fuel filter has no fuel pushing through it???
how can I remedy this to get it started now
thanksagain
p-rex
Old 12-21-2002, 02:55 PM   #6
twizzstyle
Member#: 18941
2005 Lotus Elise
Orange
i don't know about the whole not starting at all thing, but make sure you check this:
make sure all the hoses from the intake are all connected properly ("vacuum hoses"?, i don't actually know the name or function) when installing my k&n air filter, those hoses came off because I pulled the top of the airbox up so much (i have a 98). the car idled very funny (just like you said), and it would cut out around 4000 or so. but if it's not starting, it might be something else. be sure to check the hoses just in case though!!!
hope it all works out!
twizzstyle is offline   Reply With Quote
Old 12-21-2002, 04:27 PM   #7
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Yeah the 99 maf's do not like intakes. When you remove all the stock intake peices you remove the intake pelnum. So when you get around 5000rpm, somthing about the air flow causes the MAF it get a bad reading (lean I think). And the ecu kills the engine. You can fix the problem with the Apex'i S-AFC, which intercepts the bad reading from the MAF and corrects it for the ecu to see.
But the Maf is also very fragil, and if it is not braced good, it will break.
How long was the intake on befor it started idleing bad? It sounds to me like you MAF is bad.
Anthony C
Bobalouy is offline   Reply With Quote
Old 12-21-2002, 06:18 PM   #8
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Defiantly sounds like a bad Maf and the car is running in limp mode. I posted about possible causes in your other thread for not starting.
Buster
EvasionOfTruth is offline   Reply With Quote
HELP! Why is my engine surging/cutting out?? HannesRacing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-19-2005 11:04 PM
Problem: Cant rev past 3K-P1301,P0545,P1544..Help! vipernj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 09-22-2005 08:51 PM
engine cutting out WARIAT12 Normally Aspirated Powertrain 19 12-30-2002 10:47 AM
Problem: Amp cutting out? deck skipping? Orbiter Car Audio, Video & Security 6 10-10-2000 09:59 PM
