Old 12-22-2002, 01:44 PM   #1
ImprezaTs
Member#: 1086
99 Impreza TS
Black Diamond Pearl
Default Works needed for 2.2L?
I am just thinking what would I need to do to my 2.2L in order to make it as strong and powerful as the EJ22T.
ImprezaTs is offline   Reply With Quote
Old 12-22-2002, 02:10 PM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
ouch.... the EJ22g (turbo motor) has oil squirters, not sure where you would get those... and It has forged rods, but not pistons. I'm probably getting the block and putting my EJ25 heads on it and use it for a turbo motor But as far as I know the only differences are the Oil squirters and Forged rods. The compression ratio may be different as well, given it is a turbo motor...
rhdude is offline   Reply With Quote
Old 12-23-2002, 12:15 AM   #3
ImprezaTs
Member#: 1086
99 Impreza TS
Black Diamond Pearl
what if I rebuild the engine with parts of Legacy EJ22T?
Old 12-23-2002, 08:42 AM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
There are much more differences then just oil squirters, compression ratio, & rods.
The bore & stroke are going to be different. The pistons are coated with a special coating to reduce friction. The obvious is that the block is closed deck.
Just a little FYI if your thinking of putting EJ25 heads on the EJ22T. The coolant & or oil passages do not line up perfectly. I suppose you could do the swap, but if you're spending the money to do a motor.....i wouldn't want to do it half arsed.
One of the members on the BC-BF list was goin to do the same thing.....he got the heads all redone, and then found this out, and decided to just keep the 2.2T heads. With a little bit of work, the EJ22T heads can be made to flow as well as the EJ25 heads.
Also.....you would reduce your compression ratio if you use the EJ25 heads over the EJ22T heads.
If you want to ask any specific info or have questions about the EJ22T, first gen legacies. www.bbs.legacycentral.org is the place to do it.
Josh
Legacy777 is offline   Reply With Quote
Needed ASAP: Manual Transmission to work with 96 2.2L Local_Skater 1993 - 2001 Impreza Specific Parts 1 02-25-2009 11:14 PM
2.5 injectors in a 2.2l SOHC OBS? cams for 2.2l? kaisersouse Normally Aspirated Powertrain 3 04-02-2006 09:10 PM
Need a spark plug wire for 2.2L Ru fan New England Impreza Club Forum -- NESIC 2 05-14-2002 11:20 AM
Will high flow cat work with 96 2.2L? 96Lconversion Normally Aspirated Powertrain 6 02-20-2001 08:35 PM
Bought TEC-II, crank pulley for 2.2L needed badly! BobR General Forum Archive 2 12-04-2000 10:19 PM
