Old 12-22-2002, 02:54 PM   #1
jin88
Member#: 29784
Default Need Help ASAP with borla system
Just bought borla headers and borla cat back exhaust system and tried to put the whole thing on and the headers was no problem but when looking under the car the headers make a 90 degree turn from the borla cat back system, so I thought, did they leave somthing out, then I look under the car and thought I use the stock primary cat, so when I took that off, it doesn't fit, it's like SPO motorsports left something out or didn't tell me I needed a flang of some sort, I maybe could take the primary cat off and have a pipe shop make a L pipe, but they would also need to make a nipple for the O2 sensor with threads to screw in. This is becoming a big problem. Has anyone installed the borla cat back and exhaust on a 2.5 RS. SPO company told me that I would not need anything else, but during installation, they either left the part that replaces the primary cat or a something to make them fit, OR AM I'M A DUMP-ASS AND JUST MISSING SOMETHING
ANY THOUGHT WOULD BE APPREICATED!!
jin88 is offline   Reply With Quote
Old 12-22-2002, 03:16 PM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
headers>Stock cat section>Borla mid pipe> Borla exhaust... Is that what you are trying to do right now, but its not working? Leave your stock cat section on the car... The headers have have like a 90bend into the cat section, which connect straight to the mid pipe and so on... can you take pics? it would help explain your problem alot better..
rhdude is offline   Reply With Quote
Old 12-22-2002, 03:28 PM   #3
Rick G
Member#: 3122
2016 Crosstrek
Hyper Blue
Do the hangers on the cat back line up?
How different does it look from your stock exhaust?
Sounds like you got the wrong parts
It is suposed to be a CAT back so no other parts are needed.
Rick G is offline   Reply With Quote
Old 12-22-2002, 06:06 PM   #4
huckedup16
Member#: 20612
2012 Impreza Sedan
Just throw the headers on and forget about anything else!!
No but if you can take some pics it would help. Im trying to vision what you are saying but I can't.
huckedup16 is offline   Reply With Quote
Old 12-22-2002, 06:45 PM   #5
tsuanosuke
Member#: 25473
1998 Impreza L
Not to sound rude, but I think you are mistaking the borla system as a replacement of the whole exhaust system. You replace the headers, and retain the stock cat after the headers, replace everything from the midpipe back. Thats what should be happening. It should line up fine. I've seen a few.
tsuanosuke is offline   Reply With Quote
Old 12-22-2002, 09:50 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
agreed, you didnt get a 'header back' system.
You got borla headers and a borla cat back.
you have to keep the stock cat in there.
headers go into stock cat, then you replace the stock midpipe and muffler with the borla.
Jay
Old 12-23-2002, 01:13 AM   #7
rhdude
Member#: 6637
yeh! like 4 people posted the same exact thing I said
Jin- you get it working or what? and update???
~Brian
Old 12-23-2002, 10:47 AM   #8
jin88
Member#: 29784
All you guys are great, I'm going to take some pics in about a hour and then I will post them!! Thanks, just give me a little while to get the post of pictures!
Old 12-23-2002, 10:53 AM   #9
jin88
Member#: 29784
Oh right, so I keep the cat, well in that case, the people must have not send the right part, or left something out, I'm calling the company today and let you'll know if I'm just missing something or what? Thanks for all the help
Need help ASAP with smoking engine problem! PLEASE HELP! DJS_02_WRX Newbies & FAQs 14 10-10-2009 10:59 AM
NEED HELP ASAP!!! With 02 sensors. impreza4show Normally Aspirated Powertrain 2 09-19-2005 11:01 PM
NEED HELP ASAP with RHD/LHD pedal box diffs?!! hail2theTheif Subaru Conversions 8 09-02-2005 12:08 PM
NEED HELP ASAP with oil feed line onyxhunter Tri-State Area Forum 2 09-28-2004 08:06 PM
Need help ASAP with uppipe/turbo install jmaiken Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-20-2002 03:25 PM
