Old 12-22-2002, 06:35 PM   #1
Racewaypark
Member#: 30256
Default AFC question
I got a used AFC and it doesnt have the male female fittings on the wires that connect to the ECU MAF wire. Can i just tap it?
Racewaypark is offline   Reply With Quote
Old 12-22-2002, 07:29 PM   #2
NotoriousWRX
Member#: 9026
You need to cut the car's MAF wire (E13 - Blue/Pink Stripe) and connect the SAFC's yellow wire to the end closer to the ECU, and the SAFC's white wire to the end that goes into the harness.
NotoriousWRX is offline   Reply With Quote
Old 12-23-2002, 01:24 PM   #3
Racewaypark
Member#: 30256
Yes i know that but in the instructions it says to use a male female connection which I dont have. Can I just solder them?
Old 12-23-2002, 01:25 PM   #4
NotoriousWRX
Member#: 9026
Yes, it's better to solder them anyway.
Old 12-24-2002, 02:27 AM   #5
brazymstrp
Member#: 18860
2002 WRX Wagon
WR Blue
i remeber seeing a harness for 16 dollars somewhere, I'll try looking for it. If not search for S-afc harness on google or yahoo. Just do it this way, it'll help you transfer it to another car if you plan to.
-Jack
brazymstrp is offline   Reply With Quote
Old 12-24-2002, 02:20 PM   #6
Sharky NRK
Member#: 29549
2003 WRX
Not meaning to hi-jack a thread, I have a AFC from my old car and plan on using it for fuel issues since I already have it. Can anyone post a wiring diagram/install guide, or even what color wires to what ecu pins, it would be much appreciated. I was also wondering if the AFC's ability to monitor manifold pressure could double as a boost gauge and if so would it be reliable (am getting a regular boost guage so it isn't a big deal I am just curious). Thanks in advance.
Sharky NRK is offline   Reply With Quote
Old 12-24-2002, 03:29 PM   #7
NotoriousWRX
Member#: 9026
The SAFC does not connect to/monitor the car's MAP signal.
Old 12-24-2002, 03:43 PM   #8
brazymstrp
Member#: 18860
2002 WRX Wagon
WR Blue
here is the link to the diagram
http://www.northursalia.com/m...ng/wrxpin.html
-Jack
Have another S-AFC question??? Xscreamer Normally Aspirated Powertrain 4 03-14-2001 10:11 AM
A couple AFC questions ac_gohan Bay Area Impreza Club Forum -- BAIC 1 01-24-2001 12:12 AM
AFC Question for MY00/01 RidinLow Normally Aspirated Powertrain 4 01-15-2001 07:04 AM
installed my super afc.....questions...... the spacecowboy Normally Aspirated Powertrain 20 11-06-2000 10:27 PM
S-AFC questions..... Fitz New England Impreza Club Forum -- NESIC 6 11-05-2000 07:28 PM
