#1 |
Member#: 8679
Vehicle:2004 Impreza WRX STi WRB w/ silver wheels |
My father is looking at small SUVs under $25,000. He's looking at the Toyota RAV4, Geo Tracker (I hate these POS's), and the Honda CRV. He does do a little offroad traveling. Which of these SUVs is best when the pavement ends? I've heard a nasty rumor in the SUV thread that the CRV has 3 open diffs
#2 |
Member#: 717
NESIC
I love our Forester off road. But it's not on your list.
#3 |
Mazda Tribute!
#4 |
Member#: 25792
Vehicle:1993 Legacy L Winestone |
Don't touch the CRV, garbage. I'd take a look at the Liberty 4WD. It's the only mini SUV I'd consider for under 25 grand.
-Faast |
#5 |
Ummm...they all Suck
Get an OBS or Forester A jeep wrangler Spend a little more on a Land Rover Freelander but if you must.... The tracker is by far the best, has body on frame construction, a real truck suspension, and a real 4wd system..it's not a sissy car based sport ute |
#6 | |
Member#: 8679
#7 |
Member#: 3154
SORENTO!!
Nice warranty, nice build quality (really!), nice interior, and it's a real truck. ![]() ![]() |
#8 | |
Member#: 4585
Vehicle:2003 Mazda 6s |
#9 | |
Member#: 717
NESIC
#10 | |
Member#: 4585
#11 |
Member#: 717
NESIC
No, the Jeep.
#12 | |
Member#: 692
I don't think a CRV has three open diffs, just two. Either way off-roading one is asking for trouble. However, I have a feeling your dad's idea of off-roading is a gravel road so it should be fine. Trackers would be best of the three off-road, but I doubt reliability is strong. RAV4s, same as the CRV. Weak in real off-road, but fine for a dirt road. IIRC, the Forester has more ground clearance than a CRV or RAV4 BTW. JC |
#13 | |
Member#: 692
JC |
#14 |
Member#: 22404
Vehicle:06 Legacy 2.5i wgn Silver |
My wife's got a RAV4 and it's way underpowered (especially with an automatic). It struggles to get up little mountains in West VA.
Can't comment on the off-roadability since it never goes there. For under $25K I'd go with the Liberty. For a little over $25K I'd go with a supercharged Xterra. |
#15 |
Member#: 1846
is safety a consideration? (amazingly its not for some people)
check out the escapes crash test results...not good |
#16 |
Member#: 29983
Vehicle:2003 WRX Silver |
reliable, superb in the snow, good gas mileage, lots of room (especially compared to the RAV)...highly recommended!!!!! Keith
#17 |
Member#: 8679
Is the Forestor 3 LSDs, or 2 LSDs and open front diff?
Also my dad was saying something about positive traction Is that some kind of hillbilly term for limited slip differential? |
#18 |
Member#: 329
Vehicle:1999 C5 |
Positraction... 1960's or musclecar for LSD.
#19 |
Member#: 8679
Ok I see the forestor is rear LSD only in the XS or better series, so the front must still be open
#20 |
Member#: 23007
Does your father do a lot of serious offroading? If not, tell him to stop with the SUV fad. He would be much better off with a WRX. Too small??? Tell him to buy a Madza6. Mini utes don't offer anything worthwhile of their cost, unless he drives on a lot of muddy rugged trials which I seriously doubt. And even if he doe, most small utes can't even do that well.
#21 |
Member#: 29983
posi-track is limited slip.
This is a drawback on the CRV...it does not have limited slip. If both tires on one side slip you a screwed. That is why it is great on paved roads or gravel roads...but ain't too good off-road. But since I don't off road, it works for me. I have driven in a lot of snow. I also have taught to teens to drive in it. I took both out TRYING to get stuck in the snow with it but couldn't. I had to go home and switch car to show them 2 wheel drive short-comings in the snow. The CRV is a great all-around small SUV. My second choice would be the Sante Fe by Hyund. (I thing that is the name). The RAV is super but too small. The Liberty's ride sucks, too rough. The Escape/Tribute are second rate compared to Honda and Toyota. My two cents!!! Like I said, I have two CRV's, one WRX, and one Town & Country Mini Van (two teenage driver's, my wife and I). |
#22 |
Member#: 25675
Vehicle:2003 WRX Sport Wagon Aspen White |
You didn't list it, but it's under $25K, and it is lumped in with the "mini-SUV" group, although no self-respecting owner would ever call it that.
Jeep Wrangler. No question. ![]() And "positraction" or "Posi" as it's more commonly known is a term for limited slip. Try mattsauto.com for more automotive terminology basics. "A positraction differential is a special traction differential. Its purpose is to improve the way your differential performs under adverse conditions. When one wheel starts to slip, these differentials transfer the torque to the wheel that is not slipping. The car can then continue to go forward. There are several different kinds of positraction differentials, but all of them are based on a friction device to provide resistance to normal differential operation. A positraction differential provides better traction, which is handy when roads are slippery. It also lends itself to fast acceleration. One type uses four differential pinions instead of two, with two pinion shafts. It also uses a series of four clutch discs. The differential pinions run into resistance when they try to turn the axle side gears. The resistance gets transferred to the pinion shafts driving the pinions. The shafts are forced to slide up little ramps. This action moves both shafts outward. The pinions cause the clutches to lock. Other types use cone clutches, or disc clutches under pressure from coil springs. By restricting the differential action, torque is delivered to the slipping wheel." Last edited by TeeWReX; 12-22-2002 at 11:20 PM. |
#23 | |
Member#: 25792
-Faast |
#24 | |
Member#: 6351
Vehicle:2004 Tacoma 2xCab \m/ \m/ |
I would say if he wants an offroader, get a Toyota Tacoma 4x4 extended cab with TRD offroad pkg and 4 cylinder. Skip the SUVs if he is going wheeling. If he isn't doing a ton of wheeling I would go with the Tribute too. If he wants to go used but fun find a very late-model Isuzu Amigo/Rodeo Sport 2 Dr. with the 3.5. Those things are pretty quick. And fun too. But if he is gonna do much wheelin, make it a Toy or Jeep.
Or spend a little more and get a Jeep Rubicon. I am not much for Jeeps short wheelbase myslef though. Quote:
#25 | |
Member#: 692
JC |
