Old 12-23-2002, 07:57 AM   #1
gumby647
Member#: 2532
2001 2.5RS-T
BRP
Default Crank HP from chassis dyno
I build race engines for a living and use a dyno on a daily basis. The only thing is that I do motorcycles. In the motorcycle world everyone pretty much ignores the manufacturers claimed crank HP figures and assumes they are inflated. The only way to know what a bike makes stock is to dyno it stock.
One year we were building 3 bikes for a major team. We got 3 brand new bikes, put 300 miles on each and put them on the dyno. the highest was 119 and the lowest was 112. That's what 8-9% differance. What's 8-9% at 165hp.
I just don't see why you car guys are all wrapped up in crank hp. The only number that matters is at the wheels. If you had 500 at the crank and 100 at the wheels you'll still have a slow ass car. I just think it's mot realistic to use your dyno numbers as your baseline rather than claimed crank numbers.
It is possible to increase power to the wheels without working on the motor. I'm sure you could pick up some power by Superteching the the tranny and diff parts. If you're really well off you could use all ceramic bearings on all four corners and in the tranny and diffs. Motorcycle dragracers say they pick up 2 tenths just going to ceramic wheel bearings.
gumby647 is offline   Reply With Quote
Wheel HP to Flywheel HP or Crank HP Ultimate Newbies & FAQs 16 12-13-2007 05:46 PM
FS: Dyno Dynamics AWD Chassis Dyno performanceefi Non-Subaru Stuff 1 11-13-2006 11:29 AM
KONG turbo dyno plot about 320 crank hp at 18PSI Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 56 02-22-2004 01:33 PM
What is the conversion factor to go from Wheel HP to Crank HP? makofoto Proven Power Bragging 11 06-11-2003 03:19 AM
Road Dyno measures HP from ECU Jon Bogert Technical Forum Archive 5 10-11-2000 06:48 AM
