Old 12-23-2002, 07:10 PM   #1
RugDoc2003
Member#: 3628
2005 Impreza WRX STi
grey
Default Need help with a CEL code
Does anyone know were i can check up on these?
i have a my00 2.5 rs
and got my codes pulled today
P 0130
P 1442
P 1133
These all happened after my car was towed...
the recent upgrades i've done in the last 2 months include
borla headers, Cobb cat, Apex'i N1
now i had these on the entire time and even had an exhaust leak (at the cat/midpipe jxn) and no codes... this happened all after my car was towed (on a flatbed)
thanks for the help guys
rug
RugDoc2003 is offline   Reply With Quote
Old 12-23-2002, 07:13 PM   #2
LargeOrangeFont
Member#: 28475
86 RX-7, 07 Yaris,
2010 CTS-V
hold on ill go get the book
LargeOrangeFont is offline   Reply With Quote
Old 12-23-2002, 07:20 PM   #3
LargeOrangeFont
Member#: 28475
86 RX-7, 07 Yaris,
2010 CTS-V
p0130 02 sensor circit bank 1 sensor 1
gotta look around 4 the other 2
Old 12-23-2002, 07:23 PM   #4
LargeOrangeFont
Member#: 28475
86 RX-7, 07 Yaris,
2010 CTS-V
sorry i cant find the info on the other 2
Old 12-23-2002, 07:36 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
you will probably have more luck in here.
try doing a search in this forum, i know there where quite a few threads posted with resource material you can use to find the codes.
Jay
Old 12-23-2002, 07:58 PM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
P1133 Front oxygen sensor heater circuit high input
P1442 Fuel level sensor circuit range/performance problem 2
The P0133 and P1133 DTC's are most likely caused in part by your leaky exhaust. My car stopped throwing P0133's when I had my cracked header rewelded. The P1442 is probably related to the tow- there are a few wiring harnesses on the rear right of your car near the gas tank, and coincidentally, the tow hook . One is probably unplugged .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
http://www.deniedmywarranty.org
Old 12-23-2002, 08:08 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
your front 02 sensor doesnt happen to be unplugged does it?
if not sounds like you will be needing one. There was a recall on them.
put your info in at www.mysubaru.com and see if it applies to your car.
Like Brian said, check the plugs on the evap canister.
ive had that code or a similiar one on my rs a few times, and i just cleared it from a friends car...from talking to a subaru tech he told me they have been replacing the sending units on both pumps to fix this problem.
Jay
Old 12-23-2002, 09:06 PM   #8
RugDoc2003
Member#: 3628
grey
i am going to look at these next thing tommarow...
the P1442: what does the plug look like and what should i do about it?
as far as the front and rear O2 sensors... what can i do about that?
maybe i'll look to see if there are any more leaks down there...
it was funny... when it was leaking i didn't have any CEL's...
but the day i got my car towed (the same day i fixed the leak for a state inspection) was the last time i saw it without the CEL...
hmmmm....
i'll check this out...
thanks all
keep the hot info coming...
rug
Need some help with a CEL code! boostin23 Newbies & FAQs 16 05-17-2009 03:07 PM
Need Help Guys RE: CEL Code reader subie1kenOO-B Southern California Impreza Club Forum -- SCIC 5 05-25-2007 05:23 PM
Help with a CEL code Needles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-24-2005 06:10 AM
help with EGT CEL code FreeBMW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-14-2002 11:09 PM
Need Help With Subaru Paint Codes North Ursalia Interior & Exterior Modification 14 06-13-2001 01:24 PM
