#1 |
Member#: 9596
NWIC
Vehicle:2007 Toyota Prius |
Hey tonight while driving I noticed my speedometer reads zero. All the time. I also noticed my odometer isn't spinning. A couple hours later (I am a delivery driver so I had to keep driving) I got a check engine light.
What now?! Is this sounding expensive or really really cheap? Any ideas smart Gods of the Cars?
#2 |
Member#: 23212
Vehicle:2002 Impreza RS |
Maybe you could tell us what you're driving....
My wife's Jetta had a bad speedo, fairly common with that year. Required replacing the instrument cluster. $$$ |
#3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
Probably a bad vehicle speed sensor which is located on the transmission. It is an input to the ECU so when it fails you get a CEL. First thing to try would be unplugging the connector and then reconnecting. If reseating the connector doesn't get it working the sensor will most likely have to be replaced. It shouldn't be that expensive, depending on how much the sensor costs. The labor involved is minimal.
#4 |
Member#: 11858
NWIC
Vehicle:1998 Silver Legacy |
Check your altenator to see if it's going on the caput
/M |
#5 |
Member#: 6570
South East
Vehicle:04 WRXSW 9.3 TRB0 CNV |
I second the alternator check, the speedo and odo are the first to go when juice is running low.
#6 |
Member#: 11858
NWIC
Symptoms of bad altenator - Speedo/Tach/Temp gauges go out, then CEL's & ABS lights, then lighting fails with the engine stuttering as well.
/M |
#7 |
Member#: 11216
Vehicle:1991 SS 1998 BG 1996 BD |
I think it's definitely the speed sensor....see if you have a RPM limiter around 4200...thats another symptom of a bad speed sensor.
The part is like $40 and labor is VERY easy. The sensor is located on the passanger side of the transmission and has a wire coming out of it. |
#8 |
Member#: 660
Update???
I know it's been a while, but my speedo just died yesterday...and now I can't go past 4000 RPM! so please.... any updates? |
#9 |
Member#: 4800
TXIC
Vehicle:1990 Legacy & 97 OBS AWD 5MT EJ22T AWIC Swap |
according to what people posted in this thread, I'd say your speed sensor went out. Get another one and replace it and your problems will go away.
#10 |
Member#: 15543
Vehicle:90BJ Legacy LS ABS AWD 946 Rio Red Jpn built |
The speed sensor is prett easy to replace too. If you have ever done a coolant sensor it will look familiar
| Thread Tools | |
| Display Modes | |
| Speedometer,odometer and Cruise control just went out | redrex002 | General Community | 14 | 12-19-2007 09:40 AM |
| My 1st and 2nd gear went out! Need help went taking out tranny? | Kavaoski_08 | Transmission (AT/MT) & Driveline | 4 | 09-29-2007 10:16 PM |
| Taken motor apart, but still can't figure out why #4 went out ... (pics) | jefersun | Factory 2.0L Turbo Powertrain | 15 | 07-20-2005 12:49 PM |
| 97 Legacy - Speedometer freaking out | hotsam | Legacy Forum | 1 | 10-25-2003 02:15 AM |
| Yikes, I'm maxing out my fuel injectors | Revision | Mid West Subaru Owners Club Forum -- MWSOC | 32 | 12-11-2001 02:13 PM |
