Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 03-28-2005, 10:13 AM   #351
BIGSKYWRX
Member#: 7958
09 GH B+
^^ nice- that's a good drop! I need to weigh mine (04 wagon)- I've figured I've shed close to 200 lbs (a portion of that running 1/4 tank of gas vs full and emptying the trunk of spare/tools/etc)- should be ~ 2970ish
Old 03-28-2005, 04:12 PM   #352
RC0310
Member#: 63479
08' WRX
keep it up..
RC0310 is offline   Reply With Quote
Old 04-01-2005, 01:24 PM   #353
bemani
Member#: 5673
02 bug eye, 05 LGT
I'm going to take off my brake pads' backing plates the next time I do brakes.
bemani is online now   Reply With Quote
Old 04-01-2005, 03:57 PM   #354
BIGSKYWRX
Member#: 7958
09 GH B+
I don't know- they may be advantageous as far as heat transfer is concerned. Race shops sell custom titanium pad backing plates just for that purpose.
I think ours were designed for "squeal" resistance, but can't help but think they may help w/ preventing heat transfer as well????
Old 04-01-2005, 08:38 PM   #355
bemani
Member#: 5673
02 bug eye, 05 LGT
That would depend on the pad itself wouldn't it?
Old 04-01-2005, 09:24 PM   #356
cencalballer
Member#: 84131
old
green/brown
i dint read the whole thread but plexiglass or lexan windows, swaybars if u only drag race, carpet, dynamat material in trunk and other places. different seats and theres a lot of other things u an do i just cant remeber alllof them right now.
cencalballer is offline   Reply With Quote
Old 04-01-2005, 10:24 PM   #357
exhacker
Member#: 33725
2008 Impreza WRX 5dr
Well, it never hurts to shed unsprung weight first... there's your best way to improve handling. Trade everything under the chassis for stiff, lightweight components. Of course, for an Impreza you're talking $$$$.
exhacker is offline   Reply With Quote
Old 04-02-2005, 12:39 PM   #358
BIGSKYWRX
Member#: 7958
09 GH B+
Not really- the shims should help as a thermal barrier regardless of pad choice. How beneficial this would be is purely speculative, but did find it interesting that there is a prety good market for pad backers just to provide that barrier. The barrier is more to prevent heat from the pads/rotors from going into the calipers- helping the seals and reducing fluid temp. Again how much the oe shims help in this matter (if any) is speculative..
Old 04-03-2005, 02:39 PM   #359
exhacker
Member#: 33725
DBA has 2-piece rotors, for those of you ready to do a brake job. Get you some cryo-treated rotors & pads. I did, but I have the "Cobb Stage 2" kit, which aren't 2-piece The 2-piece rotors are "ultra-light" according to the site. I would be interested for someone to compare the weight of an un-used stock rotor with the rotor and hat from DBA. Shawn? Do you have the weight of yours?
http://www.dba.com.au/
Old 04-03-2005, 03:00 PM   #360
BIGSKYWRX
Member#: 7958
09 GH B+
I have the DBA 5000 rotors (for the four pots- 5010 is for the oem 2pot sliders)- they are slightly oversized vs oem 295mm vs 294 and 25.4 vs 24mm, they still provide ~ 1.5 lbs/side weight reduction. The other benefit is temp reduction in the wheel bearing They are spendy, but when the discs go you just buy the outer disc and reuse the hats.
Old 04-05-2005, 12:19 AM   #361
aspera
Member#: 7879
Good point about protecting the wheel bearings from heat. That would push 2 piece rotors to the top of the list for weight reduction. They are a reduction in unsprung, rotating mass AND save your bearings (and life?)...all while improving the cars braking.
And they look sweet.
aspera is offline   Reply With Quote
Old 04-05-2005, 01:31 AM   #362
abaxter34
Member#: 34723
fwd FTL!
how much did the front dba 5000's run you?
abaxter34 is offline   Reply With Quote
Old 04-05-2005, 08:56 AM   #363
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Bemani is talking about the brake dust shields that cover the backside of the rotors - I think that's what he means, the shims weigh nothing - so that's pointless. I already removed my brake dust covers.. they aren't that heavy, but I figured both fronts and bolts weighed like 1.5 lbs.
Jay
Diversion is offline   Reply With Quote
Old 04-05-2005, 10:22 AM   #364
BIGSKYWRX
Member#: 7958
09 GH B+
Dust covers are a differrent story altogether They do help w/ air getting to the bake of the rotor, I take mine off every spring (put them back on in the fall).
The 5000 run $450-500. I can't remember what the outer discs are, but pretty reasonable.
Old 04-05-2005, 11:50 PM   #365
bemani
Member#: 5673
02 bug eye, 05 LGT
Jay
Hey, you're talking about the guy that even pulled the fog lamp fuse and has no spare fuses in the car
Anything unimportant in the interior that is held on with 4 screws, I made it down to 3 ...
So yes, I'm talking about the shims But that sounds like a bad idea so I'll give that up.
My dust shields are LONG GONE.
My next step ... get a sheet of carbon fiber and see what the hell I can replace with it.
Old 04-05-2005, 11:52 PM   #366
bemani
Member#: 5673
02 bug eye, 05 LGT
I weighted the DBA 2 piece rotors (slotted), it was heavier than the DBA 1 piece (cross drilled & slotted). Of course, the 1 piece was used, 2 piece was new too ...
5010 (new) - 14 lb 11.2 oz
650x (used) - 13 lb 12 oz
Old 04-09-2005, 04:47 PM   #367
aspera
Member#: 7879
How about the floor of the trunk? Cut out the spare tire tub and slap some CF down.
Also in the trunk...has anybody removed the bracket for the jack? What did you use to drill out the spot welds?
Old 04-10-2005, 02:20 PM   #368
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
You answered you own question
Trunk_Monkey is offline   Reply With Quote
Old 04-11-2005, 07:32 PM   #369
aspera
Member#: 7879
They make special drill bits for drilling out spot welds. You can also get short bits. That's what I was getting at.
Old 10-19-2005, 10:30 PM   #370
BIGSKYWRX
Member#: 7958
09 GH B+
Quick update- the FHI two pot rear upgrade is essentially a wash. The oe rear calipers w/ pads are 6.8 lbs, the two pots w/ pads 4.1 lbs- the oe rotors 9.7 lbs, the two pot rotors 12.2.
Not bad considering rotor size went from 266X10 (solid) to 290x18 (vented)
Old 10-19-2005, 10:56 PM   #371
SolidSnake
Member#: 74034
2004 426whp 403wtq
Top Speed Tuned STi!
Impreza WRX STi
SolidSnake is offline   Reply With Quote
Old 10-19-2005, 11:57 PM   #372
aspera
Member#: 7879
Originally Posted by SolidSnake
Welcome to...like 3 or 4 years ago.
Old 10-20-2005, 12:51 AM   #373
SolidSnake
Member#: 74034
2004 426whp 403wtq
At the Track
1 year, but your welcome anyway.
Old 10-20-2005, 02:45 PM   #374
aspera
Member#: 7879
Well, it was posted when this was I-Club.
Old 10-20-2005, 11:23 PM   #375
dudical26
Member#: 37934
Any one know how much the stock WRX spolier weighs?
Also someone suggested taking out swaybars if you onlydrag race.
If I am on stock suspension, can I do this for my day at the drag strip or will the car be un drivable?
dudical26 is offline   Reply With Quote
Total weight reduction or F/R weight distribution more valuable? soslow General Community 17 12-11-2007 01:40 AM
('93-'01) Weight Reduction Questions subarumantoo Impreza Forum 5 05-01-2001 12:02 PM
Some interesting facts about weight reduction Imprezer WRX Forum Archive 5 02-25-2001 11:33 PM
2.5RS Weight Reduction info and questions. Frank General Forum Archive 21 02-16-2001 01:53 AM
