Old 02-18-2003, 06:59 AM   #76
aspera
Member#: 7879
Yeah, I got it. That last screw was a booger. I bent the bracket and twisted it around for a couple of minutes...why cussing.
aspera is offline   Reply With Quote
Old 02-18-2003, 07:05 AM   #77
aspera
Member#: 7879
Default better anti-theft idea
It looks like rear door handles can be used for the front doors. If you only did the passengers side, you could get rid of an extra lock. Have you ever used that lock?!!?
From looking at Subiegal's Burnsie buildup, it looks like the door handles come pre-painted. With all of the exterior locks removed you might confuse a theif or two...and look smooth doing it. The locks are useless anyway. Frameless doors and glass windows will stop no theives.
If the price is right, I plan on putting my door locks in the same pile as my trunk lock.
Old 02-18-2003, 10:04 AM   #78
ImprezedRS
Member#: 2771
2003 BMW Z4
Why don't you just shave the door handles? I will be doing that as soon as I finish shaving the side molding, already did the antenna and trunk key hole.
ImprezedRS is offline   Reply With Quote
Old 02-18-2003, 01:29 PM   #79
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
I got rid of the handle bars on the ceiling and the center sun visor! I hate those damn things, espeically the handle bars because people actually use them and then press their arms on my window leaving a big fat oily stain. Now they don't have anything to hang on to their dear life!
bemani is offline   Reply With Quote
Old 02-18-2003, 06:02 PM   #80
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
I try to stay semi legal in SM
Removing visible parts of the interior is not the way to do it
ellisnc is offline   Reply With Quote
Old 02-19-2003, 05:33 AM   #81
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
Originally posted by STiSuBiEwRx
There thats what i was missing. Where can you get lightweight front and rear beams? How much does the a/c weigh exactly?
http://www.isrperformance.com/main.html
click on body/dressup
RokketRide is offline   Reply With Quote
Old 02-22-2003, 12:38 PM   #82
ellisnc
Member#: 4229
2003 S2000
hey aspera...
just took out the assitant airbag today, pretty easy and it's huge and weighs quite a bit, plus it's pretty high up in the body so it should move the CG down a little as well.
here's how to do it if anyone is interested:
-take the glovebox part down and unclip the airbag coupler
-there are 3 10mm bolts the hold the airbag module to the IP beam. Take those out then push up on the whole module
-the plastic part that attaches to the dashboard should pop out with a little bit of persuasion.
-unclip the plastic clip that keeps the harness attached to the IP beam.
-pull the whole assembly out from the top
-now remove the plastic cover from the module by prying each of the holes over the hooks. You'll have to bend the plastic a little but it'll fit with a little bit of persuasion, you don't have to cut anything.
-once the plastic is off go put it back in the dash so you're not left with a huge hole. Then put a 3 ohm resistor in the coupler and you're all good to put everything back together.
Old 02-23-2003, 11:43 PM   #83
aspera
Member#: 7879
Default the kill the passenger mod :)
Hey Ellis, you should submit that to Peaty at Scoobymods. Maybe they can make a "Racer's Mods" section with stuff like that in it. I think it would be nice to have a "one-stop-shopping" list for guys prepping a race car.
Old 02-23-2003, 11:49 PM   #84
ImprezedRS
Member#: 2771
2003 BMW Z4
for the light weight beams go to www.subaruparts.com they have them for the cheapest.
Old 02-24-2003, 06:46 AM   #85
ellisnc
Member#: 4229
2003 S2000
Default Re: the kill the passenger mod :)
if they can't figure this out they shouldn't be prepping a race car
Old 02-24-2003, 05:04 PM   #86
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
You're saying that removing the handles is not legal in SM, yet removing the air bag is?
I'm don't really care anyway, I'm not going to mod my car around some autox event that I go to maybe 5 times a year, max. I'll just drive in the next group.
Old 02-24-2003, 07:18 PM   #87
ellisnc
Member#: 4229
2003 S2000
Yes that's correct...
Old 02-24-2003, 08:03 PM   #88
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
hey aspera...
Snip
Can you contribute that to our site or can I cut and paste it there? Good info that.
Peaty
Peaty is offline   Reply With Quote
Old 02-24-2003, 08:45 PM   #89
ellisnc
Member#: 4229
2003 S2000
what site is that?
sure I don't care
Old 02-24-2003, 09:22 PM   #90
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
www.scoobymods.com
If you go there you can contribute mods.
Peaty
Old 02-27-2003, 10:21 PM   #91
aspera
Member#: 7879
Scoobymods always makes me think of cartoon great danes riding around the UK on mopeds, with attitude.
Old 02-27-2003, 10:33 PM   #92
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Hee Hee I get it
Old 02-27-2003, 11:36 PM   #93
aspera
Member#: 7879
Default big baller weight reduction
http://www.tatomotorsports.com/carbon.asp
Fancy some carbon fiber door cards?
Old 02-28-2003, 12:31 AM   #94
peanut
Member#: 24758
on 2002 wrx. there are a couple pounds to be had by removing the front belt cover in the engine compartment (brackets and cover).. but that leaves the throttle cable just chillin there to get rubbed to hell and there is really no way to move it away.. i had an idea to use a legacy throttle cable.. it should fit fine.. im gonna go to the junkyard saturday and see whats up to make it work.. my question is.. is the throttle cable easy to replace.. and does anyone know where you get to it from inside the vehicle.
has anyone even thought of this???
peanut is offline   Reply With Quote
Old 02-28-2003, 03:02 AM   #95
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
just a thought on the shaved door handles idea......you can't race on any real racetrack with shaved handles.....
ScreaminFast is offline   Reply With Quote
Old 02-28-2003, 06:20 AM   #96
ellisnc
Member#: 4229
2003 S2000
I have the accessory belt shroud removed and I don't have any trouble with the throttle cable rubbing on it
Old 02-28-2003, 06:26 AM   #97
ellisnc
Member#: 4229
2003 S2000
Default Re: big baller weight reduction
yeah I've seen these before....
the problem is unless you're running in Prepared classes at auto-x you can't use these. And then why not just remove stuff all together?
anyway, they are badass!
Old 02-28-2003, 11:37 AM   #98
peanut
Member#: 24758
ellisnc
please explain more on what you did.. cuase the throttle cable does infact hang out.. i was planning on getting something around it then from that piece zip tie it to something to keep it out of the way.. but it just looks out of place and im anal retentive about my car haha.. i am interested in what you did please explain further..
thanks
Old 02-28-2003, 08:14 PM   #99
ellisnc
Member#: 4229
2003 S2000
the cable is pretty stiff
it's a good 1.5 inches from the belt and I haven't seen any rubbing upon inspection
if the only reason you want to remove that cover is for weight just forget it, it doesn't weigh that much.
I have no way to attach it to anything anymore so that's why it's gone now.
Old 02-28-2003, 10:53 PM   #100
peanut
Member#: 24758
i dont want to remove just the cover.. but all the brakets to.. there is a couple pounds right there.. and well every little bit adds up right
Total weight reduction or F/R weight distribution more valuable? soslow General Community 17 12-11-2007 12:40 AM
('93-'01) Weight Reduction Questions subarumantoo Impreza Forum 5 05-01-2001 11:02 AM
Some interesting facts about weight reduction Imprezer WRX Forum Archive 5 02-25-2001 10:33 PM
2.5RS Weight Reduction info and questions. Frank General Forum Archive 21 02-16-2001 12:53 AM
