Old 04-17-2011, 11:19 AM   #1051
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Originally Posted by SoCal_Scooby
What do you guys think are the top 10 weight reduction mods? car needs to pass smog though so no air pump delete
What I did or have and is planned:
-Racing seats
-Firewall insulation
-Insulation under carpet
-Single exit exhaust (muffler delete drops more lbs)
-Lightweight battery
-remove spare tire kit
-DD stereo (I removed mine)
-Carbon fiber hood
-carbon fiber/aluminum driveshaft (not installed yet)
-lightweight rotors (planned)
u2_m4r1n3 is offline   Reply With Quote
Old 04-17-2011, 11:36 AM   #1052
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Carbon fiber is heavier than stock most of the time.
You do not need or want lightweight rotors.
XanRules is offline   Reply With Quote
Old 04-17-2011, 11:49 AM   #1053
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
That obviously depends on whether you have an aluminum STI hood or steel WRX hood.
Lightweight rotors are fine as long as you know what they're limits are and your intended uses. I've been using The Brake Man 2 piece front rotors on the street for almost 2 years without a single issue and they have both the lightest top hats and rotors available. I use Girodisc 2 piece on the rear.
A-man07 is offline   Reply With Quote
Old 04-17-2011, 12:29 PM   #1054
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
my WRX hood is light as crap. I this its the rs that has the steel hood
SUBYS R US is offline   Reply With Quote
Old 04-17-2011, 05:56 PM   #1055
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
2008+ has steel hoods
That's why I said what I've done.
Old 04-17-2011, 10:00 PM   #1056
gtasti
Member#: 152036
2004 Sti
DBA front 2 piece rotors are very nice as well
gtasti is offline   Reply With Quote
Old 04-19-2011, 03:14 PM   #1057
68Cadillac
Member#: 95901
Originally Posted by JDwhiteWRX View Post
Nice. I'm copying that.
68Cadillac is offline   Reply With Quote
Old 04-19-2011, 04:27 PM   #1058
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Agreed ^^^ I might have to copy that as well!
Old 04-19-2011, 07:04 PM   #1059
girodisc
Member#: 177674
I have come to terms with the fact my Legacy is a tank and there isn't much I can do so I spent my time dropping as much rotational mass as I could and then removing weight from the higher points on the car and relocating heavier bits to lower COG areas.
DBA Rotors are bolted and not directional vane. If you are lightening your car for better gas mileage and street use they are fine but if you are doing to attack the race track as hard as you can then get a set of 2pc floating directional vane rotors. They will cool better and not be as likely to warp when you start hammering on them.
Johann @ Girodisc
girodisc is offline   Reply With Quote
Old 04-19-2011, 07:47 PM   #1060
gtasti
Member#: 152036
2004 Sti
Old 04-19-2011, 08:07 PM   #1061
A-man07
Member#: 271525
07 STi
Have to say I really like my Girodisc 2 piece rotors I have on the rear, and if I hadn't already purchased The Brake Man fronts I woudl have gone with Girodisc 2 piecers there as well.
Old 04-19-2011, 09:19 PM   #1062
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
Cool I have been getting ideas from you too
Looking at the lower rad support brackets now, should be some good savings there as they are twice the size.
JDwhiteWRX is offline   Reply With Quote
Old 04-19-2011, 09:31 PM   #1063
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
Johann @ Girodisc
Johann do you have any plans to make your 2-piece rear rotors to suit 06 wrx 4pot/2pot setups?
Old 04-19-2011, 11:18 PM   #1064
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
I just installed a Helix full Ti catback weighing 11.5 lbs. It replaced the greddy evo2 which weighed about 35lbs. It also got rid of that 2.5" taper that was on the greddy midpipe. Im sitting at about 2820lbs low on gas. I still need to remove my ac components.
Alot of lightness in this pic, aluminum DS and Ti midpipe.
Added some weight with this new shiftknob
Str8Gone is offline   Reply With Quote
Old 04-20-2011, 12:12 AM   #1065
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
Nice, how much weight does the aluminum DS save you?
Old 04-20-2011, 03:58 PM   #1066
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
Idk maybe 12 lbs, It frees up a good bit of hp... about 5%
Old 04-20-2011, 09:36 PM   #1067
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
I just ordered 10kg of dry ice, doing the sound deadening removal this weekend and hopefully the pad behind the dash.
Old 04-20-2011, 09:46 PM   #1068
A-man07
Member#: 271525
07 STi
The lightest DS available, ACPT CF DS, saves 10 lbs over stock (14 lbs total since you have to ditch the heavy protection plate as well). The aluminum one won't be more than 7, maybe less.
5% hp gain would be about 15hp on an STi. Not even close. I could barely feel it when I swapped mine out. Let's try to avoid hyperbole as most of these changes we make by themselves make only very small differences.
Old 04-20-2011, 10:17 PM   #1069
DamnThatRevLimiter
Member#: 174294
02 WRX , 2013 FXT
VF30 Stage 8 billion
That obviously depends on whether you have an aluminum STI hood or steel .
My 2002 wrx has a aluminum and as far as i know it is stock ,to check use a magnite ,it stuck to my fenders but not my hood. also aluminum does not spark when grinding on ,but steel sparks yellow/orange and titaniumsparks white. about 2008 hood idk check them out.
Some of those weights seem more drastic than i remember i have an aluminum one and I Hate it . Fitment is horrable you have to bang on this cut that blah blah. Should fit like a glove. Also mine causes a vibration from 80mph to 120mph that i have notice .I would take a stock Sti one over mine 10 times out of 10. The weight difference of mine was not more than a couple pounds . I also could have a poor quality one , i imagine quality control is not a high priorty search the forums and other people have had problems too.
I am Not trying to hate or be a jerk i just want to make fellow subaru owners aware of my experience.
DamnThatRevLimiter is offline   Reply With Quote
Old 04-20-2011, 11:43 PM   #1070
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
The aluminum DS is lighter than the carbon but it a pita to fit properly. I managed to gain a tenth in the quarter by switching to alum DS. I run very consistent so I can notice small improvements.
Old 04-21-2011, 03:17 AM   #1071
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
So I took off the big horse shoe (u-brace) and drove around for a week with it removed while waiting for the h-brace to show up, didn't notice any difference without it except the steering feels lighter because I dropped another 11kg off the front end
The h-brace is not meant as a replacement for it, it is meant to bolt to it and tie it all together. What I have done is remove the u-brace altogether and use a couple of cheap sockets as spacers where the u-brace would usually be (see below).
I also bought one of these so I can still mount the plastic undertray http://oswaldperformance.com/WRXUNDERTRAYMOUNTKIT.aspx
Old 04-21-2011, 05:31 AM   #1072
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
Post whoring now but Just knocked this up before dinner, came out pretty good
Replaced solid steel bonnet prop with hollow aluminium home made one.
Cost me $10 for material and about 40 minutes of my time :-D
Old 04-21-2011, 06:10 AM   #1073
A-man07
Member#: 271525
07 STi
I'm afraid you may have defeated the purpose of the H-brace by having to use the spacers (sockets). Under load you'll get lateral deflection there as the mounting tab isn't flush to an area of frame.
Whiteline makes a brace that can be used with the subframe removed.
Old 04-21-2011, 06:25 AM   #1074
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
I looked at the whiteline version (like yours) but because I have a 5-speed gearbox it means I would have to remove the brace each time I changed gearbox fluids and because the way it bolts up with the bolts that go through the front control arm bushings this would be a major PITA.
I could possible make up some better aluminum spacers that lock the brace against the chassis more in a lateral direction.
Old 04-21-2011, 06:42 AM   #1075
Supraru
Member#: 23313
99' 2.5Rs
black
Don't believe everything you read please. That comment is lol funny.
Supraru is offline   Reply With Quote
Total weight reduction or F/R weight distribution more valuable? soslow General Community 17 12-11-2007 12:40 AM
('93-'01) Weight Reduction Questions subarumantoo Impreza Forum 5 05-01-2001 11:02 AM
Some interesting facts about weight reduction Imprezer WRX Forum Archive 5 02-25-2001 10:33 PM
2.5RS Weight Reduction info and questions. Frank General Forum Archive 21 02-16-2001 12:53 AM
