Old 12-17-2011, 06:46 PM   #1251
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Does no one read post around pictures? o_O
u2_m4r1n3 is offline   Reply With Quote
Old 12-17-2011, 10:23 PM   #1252
vicious_fishes
Member#: 158864
2003 SOHC destroker
evap system just allows the fual tank to pressurise right? i.e when fuel goes out, air's gotta go in?
vicious_fishes is online now   Reply With Quote
Old 12-18-2011, 08:38 AM   #1253
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
It let's controls the fumes by circulating it back to the intake/throttle body and lets pressure out of the tank.
Tht fuel and fuel pump make plenty of pressure, but when the pressure gets to high, it needs to be released. Supposedly the gas tanks fuel cap lets air in and out, but I would play it safe and not plug the fuel tank hose (EVAP to fule tank, once the EVAP is removed) and put that one way vaccume valve in. let's pressure out, but won't let air in.
Old 12-18-2011, 09:51 AM   #1254
vicious_fishes
Member#: 158864
2003 SOHC destroker
here i thought the tank would actually be under negative pressure as the fuel was pumped out... interesting.
so a 1 way valve to let air out but not in, and that's all there is to it?
Old 12-18-2011, 11:35 AM   #1255
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
From my weeks of internet research, yes. lol.
basically the fumes of the fuel create the pressure and the fuel pump helps as well. Not sure of the science behind it, but they work hand in hand... makes sense I guess.
there are 2 ways to go about it, put the 1 way valve or plug the hose. I've read people doing both, some plugging the hose and claiming fuel cap lets air in and out and will last just fine and others saying that plugging it will cause too much pressure and weaken the gas tank quicker (not months) than if it was vented; hence why some people vent it. I've also read that some people just leave the hose as is and zip tie up some where open.
I prefer to start with the 1-way vent, it's a good middle area to start; if it doesn't work i can always plug it. worst than can happen with the 1-way vent is that there isn't enough pressure. If thats the case (which I'm sure it wont be) then i know leaving the hose open to flow both ways would not be good either, since the air pressure would be equal to the exterior, therefore no pressure in the tank.
I'm doing it to my car next week sometime; hopefully by Wed.
Old 12-18-2011, 11:30 PM   #1256
gtasti
Member#: 152036
2004 Sti
u2_m4r1n3
do a write on it when you do it and yes I can read
I just want to make sure I no what I'm removing..
also this doesnt throw any codes with the sensor being removed for the evap
talking about the sensor right by the alternator
gtasti is offline   Reply With Quote
Old 12-19-2011, 09:09 AM   #1257
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Originally Posted by gtasti
u2_m4r1n3
I will do a write up, issue is I have a M3 now. So other than hose comparison, the vehicles placement of the EVAP could be different. But I'm pretty sure the basic idea the same; I don't think they would make each EVAP completely different (connection wise) for every vehicle. They all serve the same purpose, so hopefully it is for both our vehicles.
Old 12-23-2011, 02:04 PM   #1258
68Cadillac
Member#: 95901
Is that a question?
Yes removing the EVAP system will throw codes.
ECU throwing codes for a system you've disabled?: RomRaider
68Cadillac is offline   Reply With Quote
Old 12-31-2011, 08:15 AM   #1259
vicious_fishes
Member#: 158864
2003 SOHC destroker
just started ripping all the firewall sound deadening out. man is that stuff dense! there's a lot of weight in there, and right up the front of the car too.
Old 12-31-2011, 02:29 PM   #1260
gtasti
Member#: 152036
2004 Sti
Originally Posted by 68Cadillac View Post
Is that a question?
yea it was a question
my tuner can prob delete the codes for me either way
can someone post some pics of the evap removed from under the hood
Old 12-31-2011, 05:23 PM   #1261
68Cadillac
Member#: 95901
EVAP removed from under hood IGNORE THE ARROWS
More EVAP missing. Yes. PS Fluid, please ignore.
Old 12-31-2011, 07:37 PM   #1262
gtasti
Member#: 152036
2004 Sti
Beauty got to do this mod
Old 01-01-2012, 12:17 AM   #1263
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
What are the benifits of removing the EVAP?
SUBYS R US is offline   Reply With Quote
Old 01-01-2012, 12:22 AM   #1264
68Cadillac
Member#: 95901
What's the title of the thread?
Old 01-01-2012, 12:38 AM   #1265
SUBYS R US
Member#: 99591
2003 18g w/38EWG
PSM(siver)
That's my point!!
It does nothing other then weight issues...
Old 01-01-2012, 12:41 PM   #1266
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
That's my point!!
Ok....
Old 01-01-2012, 05:16 PM   #1267
vicious_fishes
Member#: 158864
2003 SOHC destroker
just did a battery relocation: very easy. you can actually cut the standard tie-rods and then place the ends in a vice and bend them around to give them hooks. then just drill a pair of holes in the floor and voila, side mounted battery under the passenger seat!
Old 01-05-2012, 01:09 AM   #1268
1x2
Member#: 73564
2003 WRX
black-no wing no badges
I've been watching this thread for a long time and read every post- you guys are wild!
I threw in the towel at 2,788 lbs.
Keep it up!
1x2 is offline   Reply With Quote
Old 01-05-2012, 03:54 AM   #1269
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Keep it up!
Your car must be stripped down quite a bit, to be sitting at that weight.
Old 01-05-2012, 11:39 AM   #1270
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
A lot easier to get a WRX down to that weight :P 6MT + r180 is heavy
Splinter is offline   Reply With Quote
Old 01-05-2012, 12:08 PM   #1271
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
subscribbed...
i have done quite a bit on my old rs.. and the l is even better..
any ideas for a frame? this will be a rally car
There is no tar left or anything.. glass will be replaced with lexan.. its already been pulled off.
bue car is offline   Reply With Quote
Old 01-05-2012, 01:19 PM   #1272
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Haha, true. I'm using the app, so I can't see anyones car on the left side. :/
When I had the 09 STI, I only got down to about 3140 lbs, full tank, no driver. Might of been able to do another 100-150 lbs... But it would have been a lot more money than I had already put in... Some more CF was needed, lol.
Old 01-05-2012, 01:41 PM   #1273
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Old 01-05-2012, 03:06 PM   #1274
Hold_Fast
Member#: 175837
#61 9.5% FP
Originally Posted by JDwhiteWRX View Post
Inspired by 68Cadillac I used a spot weld removal tool on my engine bay to shave off a few brackets I no longer use.
Link to the tool you used?
Hold_Fast is offline   Reply With Quote
Old 01-05-2012, 03:43 PM   #1275
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
They're available from any auto parts store that deals with body work stuff.
Pro-Tek JMC001 is one type.
It's just a really tiny holesaw essentially. They're very pricey, but if you use LOTS of PROPER lubrication (not effing wd-40), go slow they should last a long time.
Total weight reduction or F/R weight distribution more valuable? soslow General Community 17 12-11-2007 12:40 AM
('93-'01) Weight Reduction Questions subarumantoo Impreza Forum 5 05-01-2001 11:02 AM
Some interesting facts about weight reduction Imprezer WRX Forum Archive 5 02-25-2001 10:33 PM
2.5RS Weight Reduction info and questions. Frank General Forum Archive 21 02-16-2001 12:53 AM
