Old 02-06-2012, 06:55 AM   #1376
gotsboost
Member#: 307550
2004 STI
Originally Posted by vicious_fishes View Post
or if you're married, 110 lbs in the first year and 10lbs more for every year of marriage after that.
Man you called it.
gotsboost is offline   Reply With Quote
Old 02-06-2012, 10:45 AM   #1377
KentuckyFriedSTI
Member#: 287038
2006 Impreza WRX STI
World Rally Blue
Originally Posted by gotsboost
Man you called it.
Haha so true
KentuckyFriedSTI is offline   Reply With Quote
Old 02-09-2012, 02:00 AM   #1378
68Cadillac
Member#: 95901
The hardware from just one side of the Tumble Generator Valve system weighs in at 311 grams. So for the both that comes to 622 grams (1.37 lb) if you just delete the TGV hardware.
Progress occurs in the intake manifold install/swap. Wasn't as bad as I thought to get the manifold off. Took about 90 minutes. But it took HOURS to get off the old gasket residue without scratching up the port mating surface on the heads.
While I wait for epoxy to set up, I looked at the unused cruise control throttle cable cam, the coolant passages and brass fitting on the throttle body. Started at 1063 grams.
Deleted the above, then a port and "polish" removing the lip and shaping the inlet to be more airfoil/less brick,
and ground down a bit of the throttle plate shaft and it's hardware.
Ended up at 930 grams. A savings of 133 grams (0.29 lb).
68Cadillac is offline   Reply With Quote
Old 02-09-2012, 07:43 AM   #1379
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
one day I will get around to installing this, maybe you have inspired me again 68Cadillac
JDwhiteWRX is offline   Reply With Quote
Old 02-11-2012, 08:27 PM   #1380
68Cadillac
Member#: 95901
We inspire each other JD. Now, get that **** installed.
Back on topic: FINALLY got my modified intake installed. Took way longer than I thought.
As you saw above I lightened the throttle body 133 grams
Hardware for the intake/TGV to head 288 grams
Reduced to 208. Saved 79 grams. Meh.
Fuel rails and injectors. 1227 grams.
Reduced to 1141 grams. Saved 86 grams by removing the last of the EVAP system from the fuel rails. Yes I tared out the box.
The intake manifold wiring harness. 1059 grams.
Deleted all TGV, EVAP wires, and PCV detection wires from the harness. I still run the PCV. Reduced to 815 grams. I found an additional 10 grams after the photo. Coppers heavy. I never suspected I'd remove 244 grams from the harness. Additional photo 01, photo 02, and photo 03.
Old 02-11-2012, 08:28 PM   #1381
68Cadillac
Member#: 95901
TGV's, hardware, and gaskets: 2590 grams
Intake Manifold: 3404 grams I had to weight the three seperately because it maxed out my scale (>5kg). But altogether the OEM intake/tgv system weighs 5994 grams. Almost 6 kg.
Reduced mine to 4310 grams. Saved 1684 grams. Those are Grimmspeed phenolic spacers epoxied to the bottom.
Installed it all. It runs, well. Nice pickup in acceleration too.
Me looking up torque specs. Altogether removed 2256 grams or 4.97 lb.
Side by side photos of the two intakes: Photo 01, Photo 02, Photo 03, Photo 04, Photo 05.
And yes it is possible to port match the intake ports on the heads with the engine still in the car. Photo 01. Photo 02. Photo 03. Photo 04.
Old 02-11-2012, 09:18 PM   #1382
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
so sexums
bue car is offline   Reply With Quote
Old 02-11-2012, 10:08 PM   #1383
PD5015
Member#: 198372
2006 WRX TR VF43
WRB Camo
wow you guys are determined for max weight reduction, very nice work!
PD5015 is offline   Reply With Quote
Old 02-12-2012, 12:28 PM   #1384
gtasti
Member#: 152036
2004 Sti
thats awesome caddy you sir are the new weight king
gtasti is offline   Reply With Quote
Old 02-12-2012, 05:08 PM   #1385
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
I agree with the statement above!
u2_m4r1n3 is offline   Reply With Quote
Old 02-12-2012, 09:57 PM   #1386
gtasti
Member#: 152036
2004 Sti
caddy u should do a dyi on the evap delete so i dont **** mine up
Old 02-12-2012, 10:21 PM   #1387
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
+1
Did you lose any mpgs?
Old 02-12-2012, 10:42 PM   #1388
68Cadillac
Member#: 95901
For the whole system or just the under intake/fuel rail portion? What section should it go in? Here? 2.0 engine? Built Motor? Mewbs?
I didn't know that was a concern for EVAP delete. I didn't monitor for mileage loss. Is that just a rumor? Why would you lose mileage? What's the reasoning?
Old 02-12-2012, 11:01 PM   #1389
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Because evaporated fuel just gets vented to atmosphere instead of being burned.
I've given up weighing every little thing I've taken off my car, because it's hard to do delta-weights (i.e. remove 3lbs of wiring, put in 1lbs of wiring, 2 lbs delta). I'll weigh my car when I'm at a happy plateau.
Current projects include:
Removing carpet and painting floor pan
Another wiring overhaul
Removing fog lights
Removing heater core (pretty much only drive the car in the summer anyway)
Shaving intake manifold
Decomplicating throttle body (that's a trademarked term )
Splinter is offline   Reply With Quote
Old 02-12-2012, 11:15 PM   #1390
68Cadillac
Member#: 95901
The ECU doesn't lessen the amount of fuel fed to the injectors based on what's coming in from the EVAP charcoal canister. The ECU doesn't even know how much is coming in from the EVAP system. Plus it's only cylinder 1 that gets any of the EVAP fuel vapors. I hypothesize that the car (e.i. cylinder 1) would run slightly richer with the EVAP intact. Delete it and the mileage would stay unchanged according to my hypothesis.
Old 02-12-2012, 11:36 PM   #1391
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
I'm just saying that's the theory, not that I subscribe to it.
Old 02-12-2012, 11:52 PM   #1392
68Cadillac
Member#: 95901
I'm going to look in to this. It really did suprise me how much mass was in the sub-harness attached to the intake manifold. I've got wires everywhere that don't connect to anything anymore because of the amount of systems I've removed.
Examples:
Fog Lights
Cruise Control
Daytime Running Lights
EVAP All the way back
TGV on the Main Harness
PCV detection on the Main Harness
Old 02-12-2012, 11:56 PM   #1393
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Just be careful. A lot of wires are joined mid-harness and you might think you're cutting out either end of the same wire, and accidentally cut power to something else!
I've stripped a couple dozen pounds of wiring and modules out of my car, although I am running a full standalone so it's easier to get rid of stuff.
Old 02-13-2012, 01:15 AM   #1394
NICO TURBINE
Member#: 15445
1986 Leone STi EJ22T
JDM White
990kg buy doing nothing. 29,000kms OEM.
NICO TURBINE is offline   Reply With Quote
Old 02-13-2012, 11:49 AM   #1395
gtasti
Member#: 152036
2004 Sti
I guess the whole thing and you can post it here that be cool of you
Old 02-13-2012, 01:10 PM   #1396
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
Epson salt bath FTW!!!
Just to piss off a certain person. Rasmus I have to say you are so motivated when you want to get something done. I am amazed at how meticulous you are with the weight.
nosmo is offline   Reply With Quote
Old 02-13-2012, 05:13 PM   #1397
68Cadillac
Member#: 95901
Thanks Mike.
Well the J.B. Weld failed.
After only 18 miles the car started idling weird. Searching. Boost would only go up to .2 kPa.
Hooked up Learning View and my A/F Trims were running +14.99 in some of the boxes which means I have an air leak somewhere and the car was running lean off boost.
So hooked up my pressure tester. The white PVC endcap with an air fitting on the end. And ran 1 kPa to the system and started spraying places with soapy water.
Bingo. Leaks all around the TGV bodies and the intake manifold right where I J.B. Welded them together. On the right side; cylinders 1 and 3.
Sadbanana day
I'm off to find a GTAW guy.
Old 02-13-2012, 05:16 PM   #1398
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
i sad
Old 02-13-2012, 07:39 PM   #1399
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
That sucks mate, so you are going to weld it now?
Old 02-13-2012, 08:55 PM   #1400
68Cadillac
Member#: 95901
Yep.
GMAW(MIG) with a spool gun. Going to pick up a bottle of argon, some scrap aluminum, and a new stainless steel brush tomorrow. It's all coming off tonight and the old back on. I'll practice for a day or two on the scrap then V groove out the mating line betweenthe TGV bodies and the Intake and weld them together.
Total weight reduction or F/R weight distribution more valuable? soslow General Community 17 12-11-2007 12:40 AM
('93-'01) Weight Reduction Questions subarumantoo Impreza Forum 5 05-01-2001 11:02 AM
Some interesting facts about weight reduction Imprezer WRX Forum Archive 5 02-25-2001 10:33 PM
2.5RS Weight Reduction info and questions. Frank General Forum Archive 21 02-16-2001 12:53 AM
